Julien Posted September 19, 2018 Share Posted September 19, 2018 P-61B Update sets & Masks 1:72 Eduard for Hobby Boss Kit The new tool P-61B is welcome for those who build WWII American Aircraft, Eduard are now along with some sets for it. Get what you want for the areas you want to be more of a focal point. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. Interior Set (73638) This set has one pre-painted fret, and one brass one. You get cockpit details, seat belts (for both stations), instrument panels, and the other panels. There are parts for the turrets and many internal features. New sides are provided for the inside of the gunners station. A new entry hatch is provided, as many internal parts. Zoom! Set (SS638) This set contains a reduced subset of the update set, namely the pre-painted parts that are used to improve on the main aspects of the cockpit, as seen above, with the seat belts. Whatever your motivations for wanting this set, it provides a welcome boost to detail, without being concerned with the structural elements. Exterior Set (72674) This set contains as the name would suggest parts for the aircraft exterior. There are new interior parts for the main gear wells, mud guards for the wheels, engine vent panels. engine wiring harnesses, main gear brake lines & links, a new fuselage aerial, wing radiator inlets, and flap guides Masks (CX519) Supplied on yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the glazing. In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort. Review samples courtesy of Link to comment Share on other sites More sharing options...
