Shar2 Posted September 10, 2018 Share Posted September 10, 2018 Flettner Fl-282 Kolibri detail sets Eduard 1:35 MiniArt’s release of the Flettner Kolibri was a wonderful surprise when they showed it off at Telford in 2017. This surprise turned to a fair amount of joy when it was actually released. The model is great, straight from the box, but is their way, Eduard always try to help the modeller make a great model into a greater one. They have since released three sets for the kit:- Interior Set (32927) The parts are contained on two sheets of relief etched brass one being quite a bit bigger than the other, with one being unpainted and the other pre-painted, and not self-adhesive as Eduard seem to have dispensed with that feature. Starting with the pre-painted sheet, this contains a new instrument panel which comes in front and rear sections, the rear section painted with the various dials. You will need to use the original panel as backing but with the moulded detail removed. The same goes for he side panels. The sheet also contains a very nice set of seatbelts, there are both lap and shoulder straps plus the clasp protection panels. The straps are very nicely printed, complete with shading and stitching. The clasps and attachments are picked out in steel, which all looks quite realistic. The larger unpainted sheet contains a selection of panels which can be posed open and give a much closer scale thickness than plastic ever can. Some of the panels will need to be rolled to shape and fitted with internal bracing and frames. It you wish, you can leave these panels next to the aircraft to form part of a diorama, allowing the frame work and interior visible. Lastly, the engine is provided with a wiring harness which is fitted between the engine casing and the push rod ring. Interior Zoom (33195) This single sheet set is for those modeller who just want to enhance the cockpit area, and thus contains just the pre-painted sheet mentioned above. Masks (JX216) This set of yellow Kabuki tape masks for the wheels. As with most masks the tape is only provided for the surrounds of the wheel or covering a painted wheel, the rest being made up from masking fluid. Conclusion Once again it’s proven that there’s never a kit release without an Eduard set or two being designed for it, they are so prolific. Whilst not as comprehensive as some of the previous releases, they will add that extra level of detail sought by some modellers. Review sample courtesy of Link to comment Share on other sites More sharing options...
