Hewy Posted September 7, 2018 Share Posted September 7, 2018 I'm going out side of the comfort zone on this one, and I'm going to attempt to rivet it, and do an oil canned effect, I've been busy gathering blueprints, fingers crossed i dont mess it up, its the old and gold tamiya kit, i picked it up for the princely sum of £9-00,so if it does go belly up its no big deal, the markings will be painted on I'll make my own masks, and only use the tail decals, if it fits within the scope of the gb it will be an aircraft from kagoshima base in February 1944 and painted in the later dark green scheme, suitably weathered of course, I'm unsure at the moment if I'll do gear up with a pilot, I'll tackle some riveting first I'll be doing the lower scheme, hopefully 6 Link to comment Share on other sites More sharing options...
Greg Law Posted September 7, 2018 Share Posted September 7, 2018 This will be good. I am doing the A6m3 in the mottled green scheme. I will do gear down. Just a thing with me, I like to see 1/48 planes with their gear down.it feels more natural. 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 7, 2018 Author Share Posted September 7, 2018 Thanks greg, is yours the newer tamiya kit?, this one is basic at best, no aftermarket that i can see so far for it either , hence I'm pondering on a closed up cockpit, and gear up, although i reserve the right to change my mind several times along the way, im thinking of getting any old zero cockpit etch sets though and making it fit! All the best with yours greg I'll be watching closely, Glynn Link to comment Share on other sites More sharing options...
Greg Law Posted September 7, 2018 Share Posted September 7, 2018 Mine is one of the older models like yours. One of the reasons I'm doing it. Right now simple is good for me.Hannat has one of the Yadna instrument panels for your kit.(forgive the spelling I can't check it at the moment.) Very early morning here. I will be trying to talk you into a wheels down as we go along. How about a take off setup with closed cockpit, pilot and wheels down. 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 7, 2018 Author Share Posted September 7, 2018 22 minutes ago, Greg Law said: Mine is one of the older models like yours. One of the reasons I'm doing it. Right now simple is good for me.Hannat has one of the Yadna instrument panels for your kit.(forgive the spelling I can't check it at the moment.) Very early morning here. I will be trying to talk you into a wheels down as we go along. How about a take off setup with closed cockpit, pilot and wheels down. Ohh i like the taking off idea, I'll look into hannants, cheers greg Link to comment Share on other sites More sharing options...
modelling minion Posted September 7, 2018 Share Posted September 7, 2018 I look forward to seeing what you can do with this classic kit Glynn. I also like the sound of building it taking off, very interesting. 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted September 7, 2018 Share Posted September 7, 2018 Good choice Glynn and posed in the take off position will be a most striking effect. Although quite elderly, this is still a really nice kit and is one I 'started' when I first got hood-winked to dabble in 1/48th scale. Unfortunately, the crazy voices in my head told me to cut the wing tips off and reposition then in the stowed position. I did such an awful job of it that I packed it away and have never returned to it over ten years later. Good luck and nice to meet you again within another GB. Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
LDSModeller Posted September 7, 2018 Share Posted September 7, 2018 Hi Glynn, Wow - that sounds really cool with what you have planned. The only IJN Zero I have is the old Monogram kit Look forward to see what you do and final reveal Regards Alan 1 Link to comment Share on other sites More sharing options...
trickyrich Posted September 7, 2018 Share Posted September 7, 2018 7 hours ago, Hewy said: " if it fits within the scope of the gb it will be an aircraft from kagoshima base in February 1944 " Hi Hewy Unfortunately Kagoshima Base is in the south of Japan, way outside the boundaries of this GB. But this aircraft was so widely used in SEA and New Guinea that you should be able to find a correct scheme pretty easily.....they didn't vary all that much markings wise. Someone here will probably be able to help out with schemes and locations The scale is wrong for these, but you get the idea of the different schemes these aircraft operated with out of Rabaul, NG. You have the basic decals already so it should be a really quick change. Zero's over Rabaul Other than that small detail welcome aboard. I do like what you have planned, lots of work bit it should look amazing when done So good luck with the build and I will be following with interest as I'd like to see how this effect is done. 1 Link to comment Share on other sites More sharing options...
Greg Law Posted September 8, 2018 Share Posted September 8, 2018 Hewy I have your kit. Looking at it you do have D which is a Rabaul plane you could do. The one I have seen and like is C this is the Bali Island plane. I know it is not green, but the blue strip looks good. 2 Link to comment Share on other sites More sharing options...
Hewy Posted September 8, 2018 Author Share Posted September 8, 2018 Thanks for the encouragement guys, ok kagoshima it isn't, yes the decals are in the box for a rabaul and bali aircraft, so I'll keep the markings from one these in mind, I'm going to get underway today scribing some of the panel lines a little deeper, i forsee a lot of sanding, and some of the shallow lines may get obliterated in the process 1 Link to comment Share on other sites More sharing options...
PlaStix Posted September 10, 2018 Share Posted September 10, 2018 Interesting looking project Glynn. Looking forward to trying to keep up with your progress! Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 10, 2018 Author Share Posted September 10, 2018 6 hours ago, PlaStix said: Interesting looking project Glynn. Looking forward to trying to keep up with your progress! Kind regards, Stix Thanks stix, I've probably bitten off more than i can chew here, and I'll be absolutely astonished if i pull this off to an acceptable stantard, but if we dont challenge ourselves every now and then i suppose the old mojo can tail off, I've scribed all the raised panel lines on the wings, and given the recessed lines a run through to deepen them a little, on the upper wings ive marked with a fine tip marker the rivet lines I've rubbed a bit of indian ink on the panel lines so i can see a bit clearer, and I'm ready to start scraping away with a curved blade on the top of the wings, i'll have to dig out a reserve hellcat if it goes pear shaped. Glynn 4 Link to comment Share on other sites More sharing options...
Greg Law Posted September 10, 2018 Share Posted September 10, 2018 Good to see you started. I'm going to keep mine basically out of the box with this one as I will also be doing the P40-N, which will be more full on. I will get started today on my Zero. This will be a strange process for me as I have to wait for the seat belts which are the only extra part I will use. 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 10, 2018 Author Share Posted September 10, 2018 8 minutes ago, Greg Law said: Good to see you started. I'm going to keep mine basically out of the box with this one as I will also be doing the P40-N, which will be more full on. I will get started today on my Zero. This will be a strange process for me as I have to wait for the seat belts which are the only extra part I will use. I've got a feeling that in the near future I'll wished I'd built mine oob too, there'll be some better photos too, when the daughter remembers where she put my camera, Cheers greg Link to comment Share on other sites More sharing options...
trickyrich Posted September 11, 2018 Share Posted September 11, 2018 it does look like an awful lot of work But I know it's going to look amazing when done! 1 Link to comment Share on other sites More sharing options...
modelling minion Posted September 11, 2018 Share Posted September 11, 2018 A very ambitious project Glynn but if anyone can pull it off its you. Glad to see you got hold of a good set of plans, I have every confidence in you mate. 1 Link to comment Share on other sites More sharing options...
PlaStix Posted September 11, 2018 Share Posted September 11, 2018 Now that is dedication to the art of modelling! Looking forward to more! Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 14, 2018 Author Share Posted September 14, 2018 Well, I'm still chewing the lump I've bitten off, and I'm so outside my comfort zone it's off the richter scale, but the adventure continues, now I've learnt a great deal during scribing and riveting on this so far , I've left my mistakes and errors to be seen,but i feel I've improved quickly, it's true I've not found this easy, but I'm seeing this through to grisly end, i just hope i can pull off a decent paint job to take the eye away, i used a curved blade to scrape away grooves where the riveting goes, and then a polish with some car scratch tcut Nearly all the scribing is done, this early tamiya kit is mainly raised lines, theres only the one half of the fuselage left to distress and rivet, and both back wings, all the riveting is done freehand without a guide (but you can tell that) i used some dyno tape and a rb panel line engraver tool for the panels, I'm not going to alter or amend any mistakes until the final assembly is done, and then I'll weigh it up, (worth it) also I'm fully aware as I've lightly sanded the rivets after, that they may almost disappear, zeros were flush riveted anyway (in my defence) Some pictures so far Scraping of the riveting lines, 7 or 8 pases witha curved blade, trying to maintain an even pressure After sanding, turns out not being precise with 7 or 8 passes has made it look a bit more random Wings riveted, and given a wash so i could see how it went, I've missed some lines i know Fuselage engraved One Fuselage side riveted, with the wings Bad Comments are welcome too Cheers Glynn 2 Link to comment Share on other sites More sharing options...
Greg Law Posted September 14, 2018 Share Posted September 14, 2018 (edited) No bad comments here. You are making a smashing job of those rivets. I've jumped in boots and all and ordered the expensive kit. This is only because I have to wait for my paints. I might complete the existing one in the colour scheme you liked using Tamiya paints as a comparison. I will still do my original scheme on the new one. The kit should arrive on Tuesday from a local hobby shop all going well. Edited September 14, 2018 by Greg Law 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 14, 2018 Author Share Posted September 14, 2018 3 minutes ago, Greg Law said: No bad comments here. You are making a smashing job of those rivets. I've jumped in boots and all and ordered the expensive kit. This is only because I have to wait for my paints. I might complete the existing one in the colour scheme you liked. I will still do my original scheme on the new one. The kit should arrive on Tuesday from a local hobby shop all going well. I reckon on getting a 32nd scale one for my collection greg and the new 48th scale one too, in the near future, I'm keen to see how the new one builds up, look forward to that Thanks Glynn Link to comment Share on other sites More sharing options...
Greg Law Posted September 14, 2018 Share Posted September 14, 2018 Stupid me. I just remembered the one you liked is the A6M2. So I will do one of the other Rabaul one. Keep it in theme. 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 14, 2018 Author Share Posted September 14, 2018 2 hours ago, Greg Law said: Stupid me. I just remembered the one you liked is the A6M2. So I will do one of the other Rabaul one. Keep it in theme. Greg I'm cool mate, you choose your scheme and build away, Glynn Link to comment Share on other sites More sharing options...
trickyrich Posted September 14, 2018 Share Posted September 14, 2018 that looks super impressive!!!! You've done a great job so far, evenness isn't an issue here, I reckon it needs to be a little bit patchy. I know someone who'd be getting all excited seeing all the rivet lines! 1 Link to comment Share on other sites More sharing options...
Greg Law Posted September 14, 2018 Share Posted September 14, 2018 (edited) Just to make sure I haven't miss lead you. I'm talking about the A6M3 Rabaul one. So we won't double up anyway. I will do the A6M2 one later. Rich, Those rivets are full on aren't they. I had one look in my book and said not for me. Edited September 14, 2018 by Greg Law 1 1 Link to comment Share on other sites More sharing options...
