Sign in to follow this
Mike
Bf.109G-6/U4 Essentials (SIN64845 for Tamiya 1:48)
Bf.109G-6/U4 Essentials (SIN64845 for Tamiya)
1:48 Eduard Brassin
Tamiya's new 109G in 1:48 is a bit late to the party, but I'm sure it's a good one.  Eduard have already done the research for their own G series and their various updates, and it would be a shame to waste it, so they've adapted it to the new kit, improving the main focal areas in a modular fashion.  If you wanted to throw the kitchen sink at the kit (and why not?), this Essentials Brassin set brings almost everything you'll need, which when you add the engine I reviewed earlier here, will make your 109 stand out from the crowd.  As usual with Eduard's SIN resin sets, they arrive in a rectangular Brassin tray box, with the resin parts safely cocooned on dark grey foam sheets, and the instructions on top, providing just a tad of extra protection.  All in, you make a healthy saving on buying the individual sets.
Bf.109G-6 Wheels (648400)
The narrow track of the 109 was well known as a danger during ground handling, and later on a set of wider diameter wheels were fitted with smaller hubs to help with this unwelcome characteristic. The tyres are fitted with large diameter shallow hubs and thin radially recessed treaded tyres, with the raised manufacturer's data faithfully reproduced, and the hub detail is superb.
Bf.109G-6 Exhaust Stacks (648402)
If you don't want to go all the way and open up the engine, but want those nice hollow exhaust stacks and the feint glimpse of the engine within the cowlings, then this set is for you. It contains two backing plates for the exhaust slots with engine detail visible, and 12 individual exhaust stacks that fit into slots in the manifold. A pair of PE flame damping strips are added above and below the exhaust stacks, which require a slight widening of the slot, as shown on the accompanying instructions.
Bf.109G Gun Pods (648403)
Containing one MG 151/20 cannon in each pod under the wing, these bolt-on weapons upped the 109's offensive armaments significantly, and gave it a more aggressive look into the bargain. This set contains parts for both cannons, and each one can be posed open or closed at your whim. To build them closed is simple – just add the barrel to the fairing and scribe a small circular access hatch in the lower wing using the template provided.
Bf.109G-4/U4 cockpit (648411)
A complete resin cockpit to replace the kit parts with more highly detailed resin and PE parts, with eighteen parts in grey resin, four in clear resin, two sheets of PE, one pre-painted and nickel-plated, the other bare brass, a small sheet of acetate, and the instructions.  The new cockpit replaces the old, and necessitates the removal of all the interior detail before it can be installed, with a choice of resin instrument panel with decals, or a resin and PE sandwich that has realistic detail on the individual dials.  Crew seatbelts are included, as are delicate rudder pedals and details far beyond what styrene alone can achieve, such as the combined resin/PE and acetate Revi 16b gunsight, or the alternative Revi 12c.  The inside of the canopy is detailed with head armour, padded headrest and grab-handles on the inside corners of the windscreen, while the sloping rear of the cockpit can be depicted as early or late designs, with a different stowage panel inserted after making space for it by removing the early version that is moulded into part B25 of the kit.  In both cases the two sill sections are removed beforehand, as these are included in the resin parts of the cockpit.
Masks (EX583)
Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape.  In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort.
Review sample courtesy of
Nice set, pity it costs as much as the kit, Eduard prices are really shooting up lately
