AN/AAQ-28(V) Litening
1:32 Brassin
(632-126) – LITENING is an integrated targeting pod that mounts externally to the aircraft. The targeting pod contains a high-resolution, forward-looking infrared (FLIR) sensor that displays an infrared image of the target to the aircrew; it has a wide field of view search capability and a narrow field of view acquisition/targeting capability of battlefield-sized targets. The pod also contains a CCD camera used to obtain target imagery in the visible portion of the electromagnetic spectrum. An on-gimbal inertial navigation sensor establishes line-of-sight and automatic boresighting capability.
The pod is equipped with a laser designator for precise delivery of laser-guided munitions. A laser rangefinder provides information for various avionics systems, for example, navigation updates, weapon deliveries and target updates. The targeting pod includes an automatic target tracker to provide fully automatic stabilized target tracking at altitudes, airspeeds and slant ranges consistent with tactical weapon delivery manoeuvres. These features simplify the functions of target detection and recognition, and permit attack of targets with precision-guided weapons on a single pass.
The single sniper pod comes in the blister style pack normally used for the smaller items, well protected by foam pads inside.  It is really well detailed, as we have come to expect from Eduard and the parts are very neatly moulded.  The pod comes in two grey resin parts, a small etched brass fret and decal sheet.
Once the two resin parts have been removed from the moulding blocks and cleaned up, assembly begins with the fitting of the brass end piece to the main body of the pod. The seeker head is the glued to the front of the main body, at whatever position you want, although it can actually be just push fitted allowing it to be moved as and when the modeller wants. The whole pod is then painted in overall grey and the decals added.
Conclusion
This is another very useful piece of kit to add to your 1:32 aircraft. They are, or have been fitted to so many types now; everything from the F-16 via the A-10 to the Harrier GR-7/9 so could be of interest to a whole host of modellers.
