Mike Posted September 1, 2018 Share Posted September 1, 2018 Bf.109G & G-10 Update Sets (for Eduard) 1:48 Eduard & Eduard Brassin Following on from our review of the new Bf.109G-10 Mtt Regensburg kit from Eduard (read that here), here are the additional detail sets that have been patterned on the kit parts, and are available to those that can't get enough detail. As usual with Eduard's larger resin sets, they arrive in their black rectangular box, while the Photo-Etch (PE) and Mask sets, arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. Bf.109G-10 Cockpit (648422) This Brassin set gives you all the parts for a complete replacement to the kit cockpit in one handy box, including seventeen grey resin parts, four clear resin parts, two sheets of PE, one painted and nickel-plated, a small decal sheet and a slip of clear acetate for the gunsight. Everything is of a higher level of detail due to the flexibility of resin moulding, although there is a small amount of duplication in the seatbelt and instrument panel department, but these are slightly improved from the kit parts. The rest of the cockpit is generously appointed with moulded and PE detail that will look stunning under a few coats of paint if you're careful not to make it too dark in there. The set just needs you to remove the moulded-in detail that's present in the fuselage halves, and while in the mood to replace things, it provides a more detailed set of head armour with a clear resin block taking the place of the clear styrene part. The rear "parcel shelf" of the cockpit is also replaced with a more detailed part that fits in place just as easily as the kit part. Upgrade Set (48961) This large bare brass set contains some important upgrades that go beyond the kit's already excellent detail levels, such as a detailed radio compartment bezel and replacement door with internal mechanism; wheel bay "spats"; in-scale radiator cooling flaps; scale-accurate flap sections with ribbing and hinge mechanism, which are shown assembled in scrap diagrams; a new set of main gear bay covers, which are laminated and joined by new oleo-scissor links, tie-down loops and brake hoses on each leg, and finally a trim flap actuator for the rudder. Masks (EX608) Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape. In addition you get a set of hub/tyre masks for the tail wheel, allowing you to cut the demarcation perfectly with little effort. This will be useful for those getting Overtrees or Weekend kits down the line. Masks Tface (EX609) Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with everything above, but also give you another set of canopy masks tailored to fit the interior of the glazing so that you can paint the interior and give your model that extra bit of realism. Review sample courtesy of Link to comment Share on other sites More sharing options...
