Procopius Posted August 31, 2018 Share Posted August 31, 2018 I was wondering about the Italeri 1/72 SM.79 family of kits, as I was struck by a passing whimsy and contemplated buying one. Do any of the various boxings represent an aircraft involved in operations against Malta? How is it for accuracy? How well does it go together? Any input you have is most appreciated! Link to comment Share on other sites More sharing options...
3DStewart Posted August 31, 2018 Share Posted August 31, 2018 I've never built one, but I've owned and sold two of them. Detailing is quite good, but the thing that made me sell them is the pronounced fabric sagging. This is realistic for an aircraft in flight, where the air pressure forces in the fabric, but not on the ground. Link to comment Share on other sites More sharing options...
Graham Boak Posted August 31, 2018 Share Posted August 31, 2018 The air pressure flowing past an aircraft's fuselage will tend to make the fabric bulge out rather than in, as it will on top of the wing (but not on the bottom). There was a photo on the net some time ago showing this quilting effect on the upper wing surface of a Wellington. However most kit representations of this effect, which are always in and never out, overdo this effect. I don't know about the S.79, but fabric sagging as badly as (say) the Hasegawa Hurricane, would mean the aircraft would be judged as unserviceable. 1 Link to comment Share on other sites More sharing options...
3DStewart Posted August 31, 2018 Share Posted August 31, 2018 (edited) 1 hour ago, Graham Boak said: The air pressure flowing past an aircraft's fuselage will tend to make the fabric bulge out rather than in, as it will on top of the wing (but not on the bottom). There was a photo on the net some time ago showing this quilting effect on the upper wing surface of a Wellington. Not on the SM.79. The wings were plywood skinned. The Italeri kit has more exaggerated fabric sag than this and it's done (in my view) in a rather unconvincing way. SM.79s photographed on the ground have the fabric quite tight. The Airfix kit is better in this respect, but has other faults, including a rivetted wing! Edited August 31, 2018 by 3DStewart 2 Link to comment Share on other sites More sharing options...
Mark Joyce Posted August 31, 2018 Share Posted August 31, 2018 Here’s one review that I plan on referring to when I get around to building mine: https://modelingmadness.com/review/axis/ity/pabsm79.htm Link to comment Share on other sites More sharing options...
Chuck1945 Posted September 1, 2018 Share Posted September 1, 2018 It has been several years since I built one of the Italeri S. 79s, but I don't recall any issues putting it together. Did mine pretty much OOB. Link to comment Share on other sites More sharing options...
dalea Posted September 1, 2018 Share Posted September 1, 2018 Re boxings. Series I for Spanish Civil War, Series III for Aviazone RSI; After market:-Eduard exterior for engine supports Pavla exterior for trumpet shaped engine intakes Link to comment Share on other sites More sharing options...
Procopius Posted September 1, 2018 Author Share Posted September 1, 2018 58 minutes ago, dalea said: Re boxings. Series I for Spanish Civil War, Series III for Aviazone RSI; After market:-Eduard exterior for engine supports Pavla exterior for trumpet shaped engine intakes Is the aftermarket necessary? Does it correct flaws? Link to comment Share on other sites More sharing options...
dalea Posted September 1, 2018 Share Posted September 1, 2018 I'm away from home at the moment so I can't check. Just going by what I have bought. Not so much corrections as omissions. That"s why I didn't mention Quickboost cowlings. I know I bought them but can't remember whether they really correct any shape issues. Link to comment Share on other sites More sharing options...
72modeler Posted September 1, 2018 Share Posted September 1, 2018 Procopious, Here is a link to a pretty detailed build. I have the kit, and it looks pretty good in the box; I did get the Pavla interior set, and it will address the issues mentioned in the build article. I think I also got different torpedoes for it, but don't recall whether they were also Pavla or taken from a Italeri/Hasegawa Ju-88/He-111 kit that had better torpedoes. I think there were also resin cowlings and engines available, but I would imagine they are OOP. It is a handsome beast, I think. Mike http://hsfeatures.com/features04/s7972dp_1.htm 1 1 Link to comment Share on other sites More sharing options...
TISO Posted September 2, 2018 Share Posted September 2, 2018 There is also QuickBoost set of corrected engine cowlings QB 72 106 1 Link to comment Share on other sites More sharing options...
ksc Posted September 3, 2018 Share Posted September 3, 2018 (edited) One thing I noticed, most of the Italeri releases only include the extended exhausts typical of torpedo bombers. If you want to build a conventional bomber you might have to use the exhausts from the "I Serie" or an after market set (as they say, check your references). Edited September 3, 2018 by ksc Link to comment Share on other sites More sharing options...
dogsbody Posted September 3, 2018 Share Posted September 3, 2018 5 hours ago, TISO said: There is also QuickBoost set of corrected engine cowlings QB 72 106 Got'em! I've also got the Eduard PE. set. Chris Link to comment Share on other sites More sharing options...
Procopius Posted September 3, 2018 Author Share Posted September 3, 2018 6 hours ago, TISO said: There is also QuickBoost set of corrected engine cowlings QB 72 106 What's wrong with the normal cowlings? 1 Link to comment Share on other sites More sharing options...
Sturmovik Posted September 3, 2018 Share Posted September 3, 2018 I built the SM 79 when I was younger, I don´t remember it having bad fit, other than the ones self induced because of my use of tube glue. Thanks to you, I want to build it again. Link to comment Share on other sites More sharing options...
72modeler Posted September 3, 2018 Share Posted September 3, 2018 14 minutes ago, Procopius said: What's wrong with the normal cowlings? I was wondering the same thing- I thought the kit cowlings looked good. Sometimes the Quickboost parts are no different or aren't an improvement over the kit parts. Guess I can pull mine off of the shelf and look them over- I'm thinking they must have been OK, or I would have bought the cowlings the same time I bought the Pavla interior set. Mike 2 Link to comment Share on other sites More sharing options...
dalea Posted September 3, 2018 Share Posted September 3, 2018 Actually, the Quickboost cowlings are smaller (in diameter) and shorter (in chord); just compared them Link to comment Share on other sites More sharing options...
TISO Posted September 3, 2018 Share Posted September 3, 2018 Also if you are in S&M you have PART PE (also has different bomb bay (2x500kg), "typewriter" bomb release etc. ) PART SM-79 set with instructions 1 1 Link to comment Share on other sites More sharing options...
TISO Posted September 4, 2018 Share Posted September 4, 2018 (edited) Also if you are exotic plane lover you can build it as Royal Yugoslav AF (VVKJ) plane or soviet VVS plane. For VVKJ there a few sets of decals by serbian company Lift-Here: 745-LH “Sun City”, April War Escapees, part 2 Has one SM-79 (no.3702 black 14) that escaped to Middle East and was later used by RAF 772-LH “Defectors”, 1941 VVKJ Bombers Escaped To Hungary Has one SM-79 (white 30) that tried to escape to SSSR but landed in Hungary by mistake 706-LH “Bombers”, Royal Yugoslav Aircraft, part 5 Has one SM-79 (No.3728 white 12) JRKV Set III Has one SM-79 (no.3741 white13) plane bellylanded in Neretva river few days before the war F-72LH ROYAL YUGOSLAV AIR FORCE part II has 2 SM-79 (no.3705 black 9 & no.3741 white13) Most sets are sold out by the producer, but might still be obtainable over the net. At least 1 (possibly 2) of VVKJ Savoias acctually managed to land in SSSR at one was pictured in service with 69. IAP during defence of Odessa (plane was destroyed in october 1941 during evacuation of Odessa) A cople of pic's of soviet machine http://makete.si/viewtopic.php?t=7937&highlight=savoia Edited September 4, 2018 by TISO 2 Link to comment Share on other sites More sharing options...
Giorgio N Posted September 7, 2018 Share Posted September 7, 2018 On 9/3/2018 at 3:33 AM, Procopius said: What's wrong with the normal cowlings? The problem with the cowlings is that Italeri reproduced all 3 cowlings as identical while on the real Sparviero the fuselage and wing cowlings are different. The fuselage cowling is slightly longer and at the trailing edge the diameter of the section is very slightly larger than the section where the front ring meets the cowling The wing cowlings are slightly shorter and at the trailing edge the diameter of the section is slightly smaller than the section where the front ring meets the cowling This difference is not easy to spot but it's there. Have a look at some of the pictrues on this page and you'll see what I mean http://www.alieuomini.it/AJAX/catalogo/dettaglio2_catalogo/8 The Italeri cowling is correct for the fuselage mounted engine but not for the wing ones. I don't have the quickboost set but I've read that their cowlings are still all 3 identical. Don't know if they correctly reproduce the wing cowlings or not, if so they could be useful to replace the corresponding italeri parts on the wings while leaving the Italeri cowling on the fuselage. However from pictures they look too cylindrical Of course as this is a detail that is not easy to spot, you may just decide to leave the model as it is or do the modification yourself 3 2 Link to comment Share on other sites More sharing options...
Lanmi Posted September 7, 2018 Share Posted September 7, 2018 (edited) I did it while ago and don't remember any significant building problem (it was almost decade ago). I remember it took me more time to research colours for concrete airoplane, because SM were notorious for their exemptions i camouflages and markings. Very good kit, a lot of interior details and endless colouring possibilities. For me, S.M.79 is a synonym for Italian WWII aviation, also online stormo magazine is good reference site. I did not bother with the cowlings. Unfortunately, a lot of my pictures were lost in photobucket, but there are several on http://www.ipmssrbija.com/?page_id=251&album=7&gallery=19 Edited September 7, 2018 by Lanmi 2 1 Link to comment Share on other sites More sharing options...
Nanond Posted September 7, 2018 Share Posted September 7, 2018 Mine went together quite well. I went for closed dorsal gun position and it required a bit more filling/sanding. 8 2 Link to comment Share on other sites More sharing options...
occa Posted September 8, 2018 Share Posted September 8, 2018 Giorgio N said: The problem with the cowlings is that Italeri reproduced all 3 cowlings as identical while on the real Sparviero the fuselage and wing cowlings are different. Just a side note: Italeri made a similar mistake with their SM 82. The fuselage cowling there is quite different from the wing engine housings with somehow squared off rounded trailing edges instead of being circular. 1 Link to comment Share on other sites More sharing options...
72modeler Posted September 8, 2018 Share Posted September 8, 2018 Lanmi, That is a very, very nice Sm-79! Beautiful paintwork! Mike 1 Link to comment Share on other sites More sharing options...
RAGATIGER Posted September 26, 2018 Share Posted September 26, 2018 Hi there Well I got mine at good price at Houston Texas and also got the Model Master paints for it, later I got the Quickboost cowlings but still unsure to start it, certainly some encourage is coming from this post, mine is Serie I, but I really like the one for bombing Malta Cheers Armando Link to comment Share on other sites More sharing options...
