AdrianMF
Airfix MIG-21
Hello again!
At the weekend I dropped into Hannants in Hendon and bought three kits from their second-hand selection. One of them, the Airfix P-51B Mustang, I have already finished in the 2018 Blitzbuild GB. This one is the second:
B60012_F3-2_A91-45_BD-_A32_D-4104_B204_D
This is a 1967 mould in a 1975 box. It has raised panel lines and the undercarriage is a bit weedy, but it fits together well. I am going to keep the raised panel lines but probably replace the undercarriage legs. The canopy may make it on to the model but it is a good candidate for plunge moulding. Some detailing will occur...
Thanks for looking,
Adrian
The fin has some delicate IFF aerials moulded on, sadly broken or short shot, so I have filed some openings so that I can add them later from wire. There is also a second location under the fuselage, so I did that as well:
714_F02_F9-8_AA4-4_AF5-8_EC7-98_DF8_FE0_
9_A324_B66-_D47_E-410_A-8_ECE-4_C36_CC3_
Thanks for looking,
Adrian
It is a truth universally acknowledged that a toy pilot in possession of a minimalist chair is in need of a cockpit. Thus it was that the spares box was raided and a cockpit pulled together with the aid of some walk around pictures. There is a kit part hiding in the middle of the chair:
AD07_B5_B4-40_D3-4588-8_D6_B-_F2_E6_F659
Thanks for looking,
Adrian
Great work on the cockpit Adrian and the kit seat disguise kit is working well. :D
Thanks for looking,
Adrian
We don’t get a lot of Austen on BM!
Nice addition to this GB Adrian.  I’ve got a feeling your enjoying yourself here. The 21 is looking great so far and am sure when finished, it’ll look like nothing like what most would have achieved back in 1967!
Cheers.. Dave
And painted:
13_DD07_B0-_DD8_C-4_B0_B-8852-2_DEDADCC9
5_ECD034_D-_B35_F-40_C5-_B052-9_ED52_FF8
The control column is an old Airfix Blenheim exhaust pipe.
...must remember to add nose weight this time...
Thanks for looking,
Adrian
That'll confuse the instrument fitters. Or, possibly, the pilot.  :D
Looking very nice indeed, Adrian.
Excellent scratching.
Excellent addition to the GB, Adrian. Big brother to the Mig 15 and if you do it in the Red Star scheme then our only representative of the Russian Air Force so far - what's the correct name?
Another Airfix memory jerker appears!
I built one of these when they first came out, it was my first attempt at a spray finish. I used a car aerosol over bare plastic, not being familiar with the concept of primers. The finish was bright, shiny and free of any brush marks. It was also wrinkled to death by the paint solvents attacking the bare plastic! Ho Hum. Lesson learned.
It's going to be good to see one built properly.
Some very nice work going oh here! 👍
I don’t think nose weight is going to be an issue with this one!
6_B239240-14_FE-485_E-912_D-4_FDCD237_B0
Thanks for looking,
Adrian
I’m also replacing the “washer” Airfix provided for the tail end with a paper jet pipe:
E627_E4_C9-6_BCB-4_DD1-835_D-03_BB11_CE5
Thanks for looking,
Adrian
Thanks for looking,
Adrian
WOW - Now that is a weight :thumbsup:
I found some replacements for the kit buttons, donor kit unknown:
36_E95_D48-8_BC9-463_D-_AFAF-_E44_F116_E
Thanks for  looking,
Adrian
[edit - I remember now. I bought a super cheap Frog Sea Vixen kit at a show and spares’ed it after finding it had no upper wings.]
I have closed up the fuselage and blocked off the end of the jet pipe with a Yak-9 wheel with scribed spokes to look a bit like a flame holder:
04735_AB5-7948-4069-995_C-_C00289_B23760
Thanks for looking,
Adrian
Great job with making this kit better - I remember being bitterly disappointed with this kit when bought as a youngster. I had neither the resources for research nor the skills to improve it!
Brilliant progress Adrian - I'm loving that tailpipe detail :goodjob:
13 hours ago, nimrod54 said:
improvements
I’m enjoying it. It is simple but nicely engineered. For instance the -2 degree dihedral is set in the wing tabs and they glue in exactly right, unlike the B-25 for example...
12 hours ago, BIG X said:
tailpipe detail
Thanks! The Yak-9 wheels have fluted tyre edges which kind of reflect the corrugated “stuff” in the real tailpipe, but you can’t tell in reality, not that anyone’s going to look.
Sorry to hear that! I can sort of see how, because it is an extremely basic kit with some over simplified bits. But I do appreciate as an adult how the bits that work , work well, and the other bits like the undercarriage can be fixed because I have a bigger spares box now than I did back then.
Regards,
Adrian
I had been trying to make a plunge mould better canopy. While failing to do that I put some stress fractures in the kit canopy, so I got out my home-brew vac kit today and made a couple of new canopies, amongst other things. The one on the kit will do after some more trimming, but the one still stuck to the kit canopy will in all probability be better. Whittling starts now!
299_F04_AB-7754-49_AE-8957-2_C339_EF9_DC
The new thinner canopy means that I now have space to model the enormous piece of armoured glass just inside it.
Thanks for looking,
Adrian
Absolute wizardry 🧙‍♂️
It turns out that there isn’t enough space to add the extra armoured glass. I will add a black outline to the frame instead. I have done the jumble of fuel lines behind the cockpit, so when they are dry I can put the canopy on:
00092_E1_D-1_E59-4_EEC-_AC93-_C90_C22_EC
Airfix moulded the underside air brake in three pieces. It actually fits together pretty well, contrary to my expectations:
26_DBEE8_A-_B575-4_EDB-_A31_E-_AEF444_F7
Thanks for looking,
Adrian
I also cut away the bump at the base of the fin and replaced it with an air intake made from slightly bent plastic rod:
4_BA8_D564-_DA6_C-46_CF-_B1_B2-_F483_BBD
Thanjs for looking,
Adrian
