bigbadbadge Posted November 16, 2020 Author Share Posted November 16, 2020 More work on the Camel with some decals going on and leather padding around cockpit opening. Spitfire U/C legs and doors being worked on too. Just started the very cute little Eduard Kunkadlo too, no photos as just cut off the parts from the tree at the mo, very nicely moulded and very small!!! Chris 8 Link to comment Share on other sites More sharing options...
Quiet Mike Posted November 16, 2020 Share Posted November 16, 2020 Just catching up, good work on the Spit Chris! I'm taking notes on the Sopwith, but still trying to pluck up the courage to make a proper 'wood and canvas' kite. 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted November 16, 2020 Author Share Posted November 16, 2020 Thanks Mike, very pleased with the way gge Spitfire is finally turning out. Not too far to go now. The Camel is coming well and I am enjoying this build although we will see when it gets to the struts!!!, cables and Vertical tailplane next then some weathering and then I will see if I have any fingernails left for the main event the top wing!!! Looking at your Gladiator I am sure you will be fine with your Biplanes fella. Chris Link to comment Share on other sites More sharing options...
Johnny Tip Posted November 16, 2020 Share Posted November 16, 2020 This one - i mean, this lot, has been under my radar... Looking great! Of course I looked especially closely at the Camel. Sadly, my cowling doesn't look as good as yours... 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted November 16, 2020 Author Share Posted November 16, 2020 Thanks Johnny for your kind comments, the cowling was a bit of a pain but plenty of dry fits and some paring away with a knife fixed it it is far from perfect though, although practice for my 2F1. You Camel looks great too fella. Chris 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted November 21, 2020 Author Share Posted November 21, 2020 Some more progress The underside of the Camel upper wing done The areas either side of the centre are going to be the upper surface colour. More progress on the Spitfire too with the undercarriage legs and doors united and break line and I presume a hydraulic line added along with the door to leg mounts added from brass rod Also added photo etch tree for the braces I have also started this little beauty. Can't belive how tiny it is, but from what I have seen and read a beautiful kit, the Eduard 72nd scale Kunkadlo or Buzzard. Thanks for popping over. Chris 3 Link to comment Share on other sites More sharing options...
Biggles87 Posted November 21, 2020 Share Posted November 21, 2020 I like the brake lines, what did you use please? You're new addition reminds me of one of the obscure ( to me ) french types I recently inherited from my friend. I plan to build at least one of them in next year's French Fancy II GB as a tribute to his late father. John 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted November 21, 2020 Author Share Posted November 21, 2020 1 hour ago, Biggles87 said: I like the brake lines, what did you use please? You're new addition reminds me of one of the obscure ( to me ) french types I recently inherited from my friend. I plan to build at least one of them in next year's French Fancy II GB as a tribute to his late father. John Thanks John The Kunkadlo is a unusual but kind of cute machine and when I saw this being released I just had to purchase. I have been painting the woodwork in the tiny cockpit in the tiny model. What is the model you are doing? The brake lines are 5 amp fusewire and the hydraulic pipe is a single strand of multistrand copper wire, quite pleased with the overall look, not quite accurate but an impression. Chris Link to comment Share on other sites More sharing options...
Biggles87 Posted November 21, 2020 Share Posted November 21, 2020 A Breguet 27 is the most likely. I have two choices, the Azur kit or a resin version which has been started and has a badly warped upper wing. The Azur version would obviously be easier but if I can do something with the resin wing then I might take a chance with that. John 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted November 21, 2020 Author Share Posted November 21, 2020 4 hours ago, Biggles87 said: A Breguet 27 is the most likely. I have two choices, the Azur kit or a resin version which has been started and has a badly warped upper wing. The Azur version would obviously be easier but if I can do something with the resin wing then I might take a chance with that. John They are quite an unusual looking machine, nice to do a tribute build though, hats off to you fella. Chris 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 4, 2020 Author Share Posted December 4, 2020 Hi all More work, the Spitfire is nearly all together and the weathering can start. Note the really small Kunkadlo cockpit internals between the Spitfire wheels. Thanks for looking Chris 9 Link to comment Share on other sites More sharing options...
mark.au Posted December 5, 2020 Share Posted December 5, 2020 That looks absolutely fantastic Chris. As for the little bits and pieces between the wheels, I’m not sure I can make them out even by zooming in! My eyes aren’t sufficient for 72nd scale, even on zoom! 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted December 5, 2020 Share Posted December 5, 2020 Superb ‘ factory fresh ‘ Spitfire Chris. John 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 5, 2020 Author Share Posted December 5, 2020 8 hours ago, mark.au said: That looks absolutely fantastic Chris. As for the little bits and pieces between the wheels, I’m not sure I can make them out even by zooming in! My eyes aren’t sufficient for 72nd scale, even on zoom! Thanks Mark, I am pleased with how this is turning out. I know what you mean I have to wear glasses and an Optivisor to do close up work nowadays Here is a larger image of the Kunkadlo cockpit floor,seat etc 3 hours ago, Biggles87 said: Superb ‘ factory fresh ‘ Spitfire Chris. John Thanks John, very kind fella, it's about to get dirty!!! Although not too much though, this could be tricky trying to get the right balance. Thanks both. Chris Link to comment Share on other sites More sharing options...
Dunny Posted December 7, 2020 Share Posted December 7, 2020 Spit's looking great Chris - almost there! Cheers, Roger 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 7, 2020 Author Share Posted December 7, 2020 Hi Roger, hope you are well. Thanks fella, yes she is having the last bits added and bits of weathering done and then will be finished at last. Chris Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 7, 2020 Author Share Posted December 7, 2020 Made the mirror 5 Link to comment Share on other sites More sharing options...
DMC Posted December 8, 2020 Share Posted December 8, 2020 Nice work on the Spit, Chris. Camel next? Dennis 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 8, 2020 Author Share Posted December 8, 2020 2 hours ago, DMC said: Nice work on the Spit, Chris. Camel next? Dennis Ha ha thanks Dennis I have put the Camel to one side for now as what with this and the Camel the old Mojo was a bit low. I will finish the Spit tonight or tomorrow night and then have two yellow perils planned an FAA Anson radar trainer and a lockheed Ventura Target tug so may pick up the Camel for some respite from yellow paint!!! Link to comment Share on other sites More sharing options...
Marklo Posted December 8, 2020 Share Posted December 8, 2020 (edited) I hate yellow schemes. look great but so hard to get good coverage. Haven’t tried it yet but apparently pink is the best undercoat for yellow. I think my special hobby Gloster Whittle will be my next yellow model when I get around to it. Edited December 8, 2020 by Marklo Damn you autocorrect 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted December 8, 2020 Share Posted December 8, 2020 What’s the best undercoat for pink though? 😜 2 Link to comment Share on other sites More sharing options...
Marklo Posted December 8, 2020 Share Posted December 8, 2020 (edited) Based on a sample of one, 1960s Airfix bottle green plastic and lots of coats ( although there might be a coat or two of neutral gray in there too) Edited December 8, 2020 by Marklo 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 8, 2020 Author Share Posted December 8, 2020 3 hours ago, Marklo said: Haven’t tried it yet but apparently pink is the best undercoat for yellow. I think my special hobby Gloster Whityle will be my next yellow model when I get around to it. Ahh yes yellow, being a brush painter too i was dreading painting the yellow, however on Another thread on here , @mark.au mentioned that a medium brown was a good undercoat and so I tested this the other day and reduced my yellow coats to 4 so will give that a go. I may have to try a pink undercoat too . What kit of the Fury is that, is it the Airfix or Pyro/Inpact/Lindberg kit?, looks good. The 0/400 looks great too Chris 1 Link to comment Share on other sites More sharing options...
Marklo Posted December 8, 2020 Share Posted December 8, 2020 4 minutes ago, bigbadbadge said: What kit of the Fury is that, The Airfix 1/48 with the cockpit opening ( too far forward) and the instrument panel ( the kit one is for a Demon not a fury) corrected. 5 minutes ago, bigbadbadge said: The 0/400 looks great too It’s been a very long journey but it’s almost there 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 8, 2020 Author Share Posted December 8, 2020 12 minutes ago, Marklo said: The Airfix 1/48 with the cockpit opening ( too far forward) and the instrument panel ( the kit one is for a Demon not a fury) corrected. It’s been a very long journey but it’s almost there Excellent thanks Mark, got a couple of the Airfix Furys and a Lindberg one .I was going to use the Airfix kits for a Nimrod but was lucky enough to be able to get a Lukgraph kit which is cracking so will have to decide what schemes to do the Furys now. Chris Link to comment Share on other sites More sharing options...
