Hi to everyone. I am Patrik from the Czech Republic and I want to show you my first build here. It is my 4th model after almost 5 year pause from modelling.
Some time ago, I've decided to build Mirage F1-AZ. I am using this:
Mirage F.1CR made by Special Hobby (Czech producer)
Mirage F1-AZ conversion for Hasegawa made by Scaleworx
Wheels set made by CMK (Czech producer)
Pitot tube made by Master
die-cut masks made by Eduard (Czech producer)
MAV decals (custom set)
I've decided to not use any PE parts since it will be even more time consuming build.
Kit itself is nice but require some work (filling gaps in parts joins etc.)
https://postimg.cc/image/4f1ixx6lz/
https://postimg.cc/image/kda8o45zr/
https://postimg.cc/image/bjjc6y65j/
Hello Patrick,
Welcome, and a nice subject...
Looking good so far, when you just copy/paste the direct link from the postimg page (https://s31.postimg.cc/mj4jijwkr/image .jpg, without the space) it's a bit more easy for us to look at the model and progress.
Silenoz, many thanks for your help, that's what I have been missing with uploading pics.
Work continue. Kit is suplied with 3 different variants of dashboard, I choose one, that looked similar to AZ type. Painting it wasn't easy and maybe PE part would be great here. I painted it black and made white wash to highlight any details. Cockpit was painted and glued inside fuselage. Fuselage halves was easy to glue together but I had to use putty to seal the gaps. I used Tamiya polyester for this purpose because I was afraid that regular putty could show gaps after few weeks again. I had to rescribe few lines on fuselage too.
I glued together plastic nose from kit and than made measurements to cut it. Attaching resin nose was easy job, but required some putty. Once it was done, I connected nose part to fuselage and fill the gap with Tamiya epoxy putty again.
Wings needs to be modified. I had to thin lower part so it can join upper part properly (othervise almost 1mm step will occure). I also dry fitted vertical stabilizer.
I  worked on vertical stabilizer and connected resin antennas to it. It is great that there is 3 variants of stabilizer in kit. I also made doppler antenna since there's none in kit.
Very nice work, I will keep an eye on this as the F1.AZ is the best looking F1! What camo are you going to go for, the older tan and green or the dark green and dark earth low vis?
I am going to make it in late dark earth/dark green scheme.
continued again. I had to rescribe lines on resin ventral fins and adjust them to fit properly to fuselage. I wasn't satisfied with retracable probe so I made new one using IV needle and aluminium foil. Wings and vertical stabilizer are glued and gaps filled with surfacer 500. French corails are modfied to looks like flare pods used on AZ. I also modfied rails under wings so they can accept Mk. 82 bombs. I am finishing scratched centerline pilon for bombs. I am using Matra rockets from box as Kukri V3B missiles since they look very similar. Wing drop tanks are from box. Mk. 82 bombs from AMK KFIR. All rails and armanent is connected using tac-it rubber.
Indeed, there is no CLB 30 in the SH boxes ! 😑
I though V3 were in the box, for sure in the first CE or CG boxes, but apparently, not in the CR box... Edit: I think part 88 on sprue D are V3... 🤔
And where did you find your CLB 4 ?
Armanent sprues are same in every mirage F1 kit so I used correct missiles thinking they are Matra 😁
CLB 4 is scratchbuild, because I can't find any in this scale and the one from shapeways seems to be little overpriced for me...
Oh, this looks promising! Nicely done so far.
Nice work, then !😍
Many thanks for your support 👍
After some discussion on Czech model forum, I decided to cut nose away and will fix it again. Hopefully I will get better fit and mirage will looks better. I also sanded putty around nose and made only minor repairs. I will sand it again before fixing nose.
I have to finish this kit before special hobby release their own AZ version😂
looking good, about that last part... trick of the trade... you can wait forever, and finally decide on an aftermarket set. Shortly after a plastic kit will appear, not sooner...
Some update. I drilled holes and glued copper vires in connection of nose and fuselage. I than glued nose in its place and fill gaps with CA glue. For final smoothing I used Tamiya polyester putty. Seam was smoothed and now waiting for surfacer (hopefully tomorrow). I will than rescribe panel line and its should be finished.
I am not sure if I will go only with preshading or also with dots and blobs with light cote of base color.
Picture is not in great quality but hopefully shows that I captured nose shape better than previously.
I rescribed panel lines, smoothed most of it. It required some minor putty work but it should be in final layer of surfacer soon.
I also painted excellent resin Scaleworx seat.
I am still busy with all of those stuffs in connection with new job and moving to the new city. I managed to find some time during this week. I glued ejection seat and canopy in place. Canopy needed some surfacer 500. I also painted lower surfaces in base gray-blue yesterday. Today I am planning to make some post shading on lower surfaces. Hopefully there'll be enough time.
Exhaust nozzle is painted with Gunze C8 and C104 and some variation added with Tamiya clear blue, clear red and smoke.
Another progress made yesterday. I am still not happy with my airbrush work, but I hope it will get better and better.
Nice start, but preshade with black isn't necessary IMHO, when you really want to preshade and you have a pale camo, then use less stark colors then black... With regards to preshade, not really a fan of it (in my opinion it isn't realistic), the marbling looks good
I chose dark gray for preshading, but maybe it's still too dark. I already used this technique on my 1/48 spitfire and liked it. Don't worry, I will make preshading only a little pronounced. At all it was relatively new aircraft kept in good condition so only little variation in shades of colors is planned.
I hope I will make some progress today.
On 10/11/2018 at 4:08 PM, Courageous said:
Preshading...love it or hate it, it's down to the individual.
Stuart
Personally... i never pre-shade! i only POST-shade :)
Here's pic of my spitfire I mentioned before. It was taken by guys from eastmodel at local model show.
49727_big
Another progress on Vlamgat made yesterday. Photos was taken under lamp and it makes preshading much more pronounced than in normal light.
 Another progress made. Graz-blue seemed to be too blue-ish so I applied few light coats of gray. Unfortunatelly no photo of it.
Next step was masking and firt coat of dark earth. Unfortunatelly this color was too dark and I had to wait to next day. After some evaluations, I used Tamiya buff straight out of bottle and was really happy with the result.
Today, I plan to prepare masks. On sunday, there will be plenty of time to apply dark green and maybe even Gunze Super clear GX-100.
Still lot of work in front of me.
