Bandsaw Steve Posted September 19, 2018 Share Posted September 19, 2018 Ah yes... subtlety. I think I read something about that once. 🤔 1 Link to comment Share on other sites More sharing options...
Redshift Posted September 22, 2018 Author Share Posted September 22, 2018 (edited) Right, calling this one finished. See you in the RFI. Edited September 22, 2018 by Redshift 4 Link to comment Share on other sites More sharing options...
pheonix Posted September 22, 2018 Share Posted September 22, 2018 For a scratch build that was mighty quick... A first class model, I do like the fornt elevation - you have really caught the shape. P 2 Link to comment Share on other sites More sharing options...
Bandsaw Steve Posted September 22, 2018 Share Posted September 22, 2018 A great piece of work quickly executed - still, ‘Redshift’ does imply great speed. Any details on how you fixed the upper wing? Were there any particular problems or tricks involved? This is the part of the 504 build that I’m dreading. 😱 1 Link to comment Share on other sites More sharing options...
Redshift Posted September 23, 2018 Author Share Posted September 23, 2018 11 hours ago, Bandsaw Steve said: A great piece of work quickly executed - still, ‘Redshift’ does imply great speed. Any details on how you fixed the upper wing? Were there any particular problems or tricks involved? This is the part of the 504 build that I’m dreading. 😱 I put metal inserts into the ends of the struts using 0.5mm tinned copper wire, then carefully measured out the position of the struts on the lower wings and nose, drilled some holes and glued the sticky out strut wires into the holes. This leaves the struts held firmly, but with a little bit of flex. Make sure the upper wires are all bent to be vertical. Now mark out and drill the upper wing, then carefully lower the upper wing in place, manipulating the struts with tweezers. Took a couple of goes but it worked out ok. Once in place a quick dab of CA using a pin as applicator keeps everything in place ready for rigging. Wash hands, drink tea. Simple! 1 Link to comment Share on other sites More sharing options...
Bandsaw Steve Posted September 23, 2018 Share Posted September 23, 2018 OK - so hopefully nothing to be too scared of? 😧😟😐😁 1 Link to comment Share on other sites More sharing options...
Redshift Posted September 23, 2018 Author Share Posted September 23, 2018 If you can master woodworking, lathes and vacforming you can plonk a wing onto some sticks without any bother! 😋 1 Link to comment Share on other sites More sharing options...
