SnapCrackle Posted August 22, 2018 Share Posted August 22, 2018 Hi all, I've got a 1/48 gladiator on the go, whose cowling I've cut and shut to accommodate a resin engine. Unfortunately I had to sand off one of the humps over the cylinder heads to get everything together. I'm looking for advice on how to replace this detail, the original plan was to create a mould from one of the remaining humps but attempt 1 didn't go as well as I'd hoped. Any tips? Link to comment Share on other sites More sharing options...
stevehnz Posted August 22, 2018 Share Posted August 22, 2018 Small piece of plastic card the approximate depth & shape of the engine bumps, glue to a short piece of sprue for a handle, sand to shape, cut off sprue & stick to cowl. Job done. Steve. 2 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted August 22, 2018 Share Posted August 22, 2018 Possibly mold it with Milliput ? 1 Link to comment Share on other sites More sharing options...
SnapCrackle Posted August 25, 2018 Author Share Posted August 25, 2018 Thanks both for your replies. I tried both methods and ended up preferring the plastic card option. A little bit more sanding to do now it's in situ, but I'm quite happy with the result 😊 Thanks again! 2 Link to comment Share on other sites More sharing options...
stevehnz Posted August 25, 2018 Share Posted August 25, 2018 That looks OK, maybe a little filler cleaned up straight after with thinners or water on a q-tip, depending on what thinner you use, to blend the base in & it'll be a good thing. Steve. Link to comment Share on other sites More sharing options...
