canberra kid
Big ideas about a big wing
12 hours ago, perdu said:
This is going to be a brillant monster machine
I think you have the concept just right here John
(and the finished result is always better when you have made your ideas work out)
Thanks, it seams to be happening to plan, but I still have some tricky things to overcome. Time will tell :)
John
12 hours ago, MarcNewitt said:
Wow, that is all I can say! Just..... WOW.
For the love of Canberras this is going to be epic. Very best of luck with this although going by what I have seen from the D you built this shouldn't cause you too much trouble!
Regards
Marc
Thanks Marc, fingers crossed! :)
John
That's all the wing components made, when I've modified both Airfis wing sections to take the new spar and fit the kit fuselage I can stick some parts together.
John
On ‎9‎/‎13‎/‎2018 at 10:45 PM, MarcB said:
everything could help !
Holy Cow.. How big ? Or have you bought a half scale 12" Rule ?  You , the kid and cedB with his B-36 are using all the available plastic stocks .
It's big! 31 inch span, that is BIG :) plastic stock is safe, but bathrooms aren't
John
1 hour ago, Corsairfoxfouruncle said:
You definitely do anything easy do you ? Incredible work on this so far.
Dennis
I know Dennis, I must be a wee bit mad, but I'm having such fun! :)
John
I'm not worried Avocado Bath tubs.. They are so cheap !
15 hours ago, canberra kid said:
This is fabulous stuff.
I’m still trying to work out, though, why you titled the thread “Big wing”?
Graham 😁
Graham 😁
LOL! not sure ether Graham, now it's together, sort of, it should be gigantic! :)
John
Somewhere up above, Leigh-Mallory is smiling! (I can just hear John's wife. "Honey, have you seen the light fixtures that used to be in the 'loo?")
Mike
Mike
Mike Leigh-Mallory's big wing was definitely a thing to behold! as for the light, it's always best to keep her in the dark when ever possible :)
John
John
I hear you! BTW, you probably have these photos already, but I have attached a link below that has some good detail photos of the WB-57F- scroll down a bit to see them. Hope they are helpful for your project!
Mike
https://www.warbirdradio.com/image-galleries/archived-galleries/
Mike
Thanks Mike, I'll take a look when I get home this evening.
John
Coming along nicely there!
And thats more of a big fecking jock-off wing! haha!!
Very apt description Mikey :)
John
Mike
I've had a look at the photos Mike, I'd not seen them before which is a plus :) One thing it did remind me of is the up and coming fun of those vortex generators on the tail plains, such fun!
John
It's not too easy to see on the photo but I've re-profild the leading edge of the wings and thind the trailing edge.
John
Edited by canberra kid
I kept coming across in this in the WIP forum but have just got around to looking at it.
Holy cow, that's big!! I won't do all the ' likes ' in case I Overload your equipment but there should be about 20. I once had a 1/72 resin conversion for the big wing, made by Dave Buttress ( DB models ), but when I got around to wanting to use it the resin had gone soft and sticky so I threw it away.
Watching closely now.
John
John
Thanks John
The DB set is/was good, I've still got one I never plucked up the courage to give it a go, strange rally given what I'm doing now! :) good to have you along for the ride.
John
More plumbing, this time in aide of the engine nacelle, The nacelles for the TF.33's were beefed up considerably as you can see from the photo below.
This will as on the actual aircraft help strengthen the wing to nacelle joint, so, back the the plumbing, I needed something with the right amount of curvature to match that of the nacelle and a good thickness to match the real thing. So back to the plumbing supplies, I found some pipe the was slightly larger than the diameter of the cowling but after cutting down I knew it would be ok. It's going to be quite a long job but it needs doing.
John
