RidgeRunner Posted August 18, 2018 Share Posted August 18, 2018 Hi all, I may be way behind the curve but I've discovered that using correction fluid for small jobs works very well. Simply, you apply a little, let it setb( a few moments) and wipe clean with white spirit. Clean, quick and neat. Has anyone else done same? Any pitfalls, such a poor ageing qualities? Thanks, Martin 1 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted August 18, 2018 Share Posted August 18, 2018 I've been using it like that for years. I thought everyone else knew about it! One of the poundshops sells it in a blue plastic dispenser. It's not perfect but cuts down on sanding. 1 Link to comment Share on other sites More sharing options...
RidgeRunner Posted August 18, 2018 Author Share Posted August 18, 2018 Ah ha! I'm just behind the times, Pete. Martin er..... What owl? 1 Link to comment Share on other sites More sharing options...
Black Knight Posted August 18, 2018 Share Posted August 18, 2018 I use the pen version to put it into depressions made by mould release pins. As long as the divot isn't too deep it fills it nicely. In deep ones if you put too much fluid in it cracks as it dies 1 Link to comment Share on other sites More sharing options...
pigsty Posted August 18, 2018 Share Posted August 18, 2018 In deep ones if you put too much fluid in it cracks as it dies Plus, if you put a second layer of correcting fluid over a first, it tends to delaminate. But for a small and shallow job, it's very useful stuff. 2 1 Link to comment Share on other sites More sharing options...
