Mike Posted August 15, 2018 Share Posted August 15, 2018 Bf.109G Update Sets (for Eduard/Tamiya) 1:48 Eduard & Eduard Brassin This is a catch-up of some sets for the excellent new Eduard kits of various marques that haven't been incorporated in other reviews for whatever reason. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. The resin sets arrive in the familiar Brassin clamshell or card box, with the resin parts safely cocooned on dark grey foam inserts, and the instructions sandwiched between the two halves, doubling as the header card in the clear boxes. Bf.109G Tropical Filter (648410 for Tamiya) This is a simple replacement with additional detail, which requires only two small bases to be removed from the side of the fuselage in front of the intake. There are two resin filters (enough for two kits) with extreme detail, and two sets of brackets that brace the filter against the fuselage, replacing the lumps removed earlier. The original styrene intake from the kit is retained, while the resin part just plugs into the aperture. Bf.109G-4/U4 cockpit (648411 for Tamiya) A complete resin cockpit to replace the kit parts with more highly detailed resin and PE parts, with eighteen parts in grey resin, four in clear resin, two sheets of PE, one pre-painted and nickel-plated, the other bare brass, a small sheet of acetate, and the instructions. The new cockpit replaces the old, and necessitates the removal of all the interior detail before it can be installed, with a choice of resin instrument panel with decals, or a resin and PE sandwich that has realistic detail on the individual dials. Crew seatbelts are included, as are delicate rudder pedals and details far beyond what styrene alone can achieve, such as the combined resin/PE and acetate Revi 16b gunsight, or the alternative Revi 12c. The inside of the canopy is detailed with head armour, padded headrest and grab-handles on the inside corners of the windscreen, while the sloping rear of the cockpit can be depicted as early or late designs, with a different stowage panel inserted after making space for it by removing the early version that is moulded into part B25 of the kit. In both cases the two sill sections are removed beforehand, as these are included in the resin parts of the cockpit. Bf.109G Seatbelts STEEL (FE910) In case you don't already know, these belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting. Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE. A complete set of shoulder and lap belts are included, with the buckle-padding parts additional items that are glued under the buckles for the pilot's comfort (in the real version). Bf.109G-14 Update Set (48942 for Eduard) This single sheet of PE adds more detail to the already well-detailed kit, in the shape of the radio-compartment door and surround, with realistic locking mechanism; the linings for the main gear wells where the legs reside; a retaining strap for the drop-tank; scale-thin flaps on the rear of the radiator housings; the two-layer flap sections behind the radiator baths, which have additional diagrams showing the correct layout of parts; a set of in-scale gear legs in multiple layers, with oleo-scissors, tie-down lugs and brake hoses; rudder trim actuator, and a stiffening base to the underwing aerial. Review sample courtesy of Link to comment Share on other sites More sharing options...
