Moa
The Flight of the Phoenix, scratchbuilt, 1/72nd.
The two parts of the vertical stabilizer, the lower with the wheel, and the beams for the landing gear:
The horizontal stabilizer is made:
On 8/19/2018 at 10:01 AM, Moa said:
The engine nacelles are excised:
Now I remember why my P-1 is in a box somewhere: as I removed the wings from a previously-built C-45 it was very tricky to fill the gaps left by my nowhere-near-as-tidy nacelle removal!
I'm glad to read your progress over the weekend, Moa. It's looking great!
Excellent work Moa. Amazed that your 'cone' fitted so well to the cockpit tub.
Carry on good sir.
Stuart
Hi Zac
May be a combination of some styrene and Milliput to fill the gaps, if the gaps are bigger?
Carry on good sir.
Stuart
Hi Stuart
Provided the diameters of the tub end and the cone base are the same, and that the cone is reasonably straight, there will be no problems.
If there was some miss-alignment, a disk of styerene could be glued on, as an interface to be sanded as required. Small shims and epoxy (and later Milliput in the gap) could also help to correct some angular proclivities.
There is a solution for almost every problem in modeling, the unsolvable one being us.
Nice work on the beams for the undercarriage, not the easiest of things to make, especially in this scale.
Martian 👽
Martian 👽
Tell me about it.
It pays to have three pairs of eyes, four brains, and four arms!
1 hour ago, Moa said:
Tell me about it.
In other words to be me then!
Martian 👽
The nice fuselage now tidied-up and with two air intakes as per photos. The parts to make the cowl flaps are seen in the foreground:
I hollowed the exhaust and made its seat comfortable:
The model as today. As you may notice, the "skids" and the cabanne struts have to yet to be made:
Edited by Moa
The skids are tackled now. They are actually a box made of four sizes, the top is also hollowed. Four oversized planks are glued only at the front and back with a small dot of cement, and the holes' location is marked:
 Holes drilled, first with a small bit, then to full size:
The planks are shaped and separated:
Almost ready:
A third air intake to the left side was spotted on photos, so it was shaped and added:
Wings primed to spot blemishes:
This build is absolutely bonkers but you are demonstrating a high level of skill.  Very entertaining.
AW
AW
You are very kind, but why bonkers?
I mean it is what you might say “out of left field” a very unusual subject.  No offence intended.
AW
AW
I know, I was just curious about why this would be strange. Yes, it's a sort of an oddball, but well known and with an appearance, that if ungainly, is not unusual since it pretty much follows the basic, simple, archetypical shape of a plane.
Odd indeed is what I will start to post (hopefully soon) as RFIs (if of models built a few years ago).
Stay tuned 🙂
On 8/20/2018 at 9:15 PM, Moa said:
Hi Adrian
I suggest you read the post from the beginning.
You are not the first one to get confused about the planes used in the movie (I have explained this quite a number of times by now...)
There was one "crashed" plane (the Packet, actually three of them apparently for different sequences), then the STATIC prop "made from the packet" ( a non-flying prop, made from parts of the Packet), then a flying prop, the Timm-Tallmantz Phoenix P-1 made with parts from an AT-6 Texan and a C-45 Expeditor -plus designer-made parts-, then, when it crashed, a North American O-47 was modified to (barely) resemble the other movie props.
Quote
Sorry, I was rather hoping you were going to make a diorama with the C-82 Packet sat in the desert,  morphing into the Phoenix P-1. That would tell the whole story?
Edited by AMB
But that's the whole point, that the Packet does not morph into the Timm-Tallmantz P-1 -that was made from parts of other planes as a flying prop for the movie- but into the movie static prop, which is not the model I am making. They were two different planes that had only a passing resemblance.
Some great scratch building there, loving watching it progress. Well done.
For your next mission, "if you choose to except it" I would love to see you do a Fairchild XC-120 Pack Plane, (very slightly related to this project) Never seen one done before.
Hi Andy
You are very kind.
Regarding your comment:
1) There is already a resin kit of this plane in the market
2) I don't do military
But I do like odd looking planes 😉
The slots for the landing gear legs are carved:
The position for the stab is carved:
The outer ends of the horizontal stabilizer (after the elevators were slightly deflected) are capped with small planks later to be contoured:
Edited by Moa
The wings are now marked and trimmed back to the right span:
Their roots will have to be adapted to the angle and curvature of the fuselage:
