Mike Posted August 14, 2018 Share Posted August 14, 2018 Luggage Set 1930-40s (35582) 1:35 MiniArt via Creative Models Continuing their current theme of providing the modeller with a full range of ancillary items to bedeck and festoon dioramas, vehicles and vignettes, this set takes the theme of luggage. It arrives in a figure-sized box, and inside are five sprues all containing different types and styles of luggage, as well as some wheeled goodies in the shape of a pram and a cart. The instructions are printed on the rear of the box, and deal mostly with the creation of the cart and pram, with additional steps for the bags, sacks and suitcases that are also included in the set. A small decal sheet is also provided to dot around the suitcases as you see fit. Within the box you get one each of the following: 4-wheeled cart with framework 4-wheeled pram Large suitcase Medium suitcase Small suitcase Doctor's bag Hat box Folio case Sack with round vegetables showing through Sack with longer vegetables showing through Large sack Painting suggestions can be found on the front of the box, but the choice is yours, as are the placement of the decals. The pram is perhaps the most complex of the assemblies, with the cart following closely behind, which will require a little care in cleaning up, so that you don't break any of the delicate parts. Much of the pram is more robust, apart from the handle and leaf-springs under the chassis. This will be a perfect set for anything including refugees or travel situations, where personal effects have been abandoned due to circumstance, or stacked in the back of a truck/bus etc. Review sample courtesy of Link to comment Share on other sites More sharing options...
