Paul A H Posted August 12, 2018 Share Posted August 12, 2018 Resin Detail Sets for Eduard MiG-21 MF Interceptor/Fighter-Bomber 1:72 Eduard Eduard's all-new MiG-21MF was one of the most hotly anticipated kits in 1:72 scale for some time. Now it is finally here, we can see that the kit doesn't disappoint. It is both accurate and well detailed and has made a lot of modellers of Warsaw Pact subjects very happy. That's not to say it can't be improved, however, thanks to the possibilities offered by resin replacements for some key components and sub-assemblies. MiG-21MF Interceptor Cockpit (672180) This set provides a complete replacement cockpit for the interceptor variant of the kit. The set comprises a complete cockpit tub (which replaces a multi-part version supplied with the kit), an instrument panel, coaming, control column, HUD unit and ejector seat. A small fret of photo etched parts is provided and this contains smaller details including harnesses for the seat, details for the instrument panel (which is otherwise devoid of cast detail). A small sheet of plastic film is provided for the HUD screen itself. While the plastic cockpit provided with the kit is no slouch when it comes to detail, there is only so much that can be achieved with injection moulded polystyrene. This resin version is a considerable upgrade over the plastic version and is well worth consideration. MiG-21MF Fighter-Bomber Cockpit (672179) This set provides a replacement resin cockpit for the fighter bomber version of the kit. It is identical to the set reviewed above for the interceptor, but includes a different tub and coaming complete with equipment used for bomb aiming and delivery. MiG-21MF Exhaust Nozzle (672181) This set manages to achieve the feat of improving on the parts provided with the kit while simplifying construction. The replacement resin jet pipe comprises just three resin parts and a small fret of photo etched components which represent a more detailed version of the afterburner flame holder. The replacement assembly simply slots into the kit fuselage with no cutting or surgery required. MiG-21MF Wheels (672182) This set is intended as a like-for-like swap for the kit wheels. A choice of two different main wheels are provided, although the instructions note that one type was rarely used on the MF, along with two identical nose wheels. This means you actually get enough wheels for two complete kits. As is the norm for a set of this type from Eduard, pre-cut masks are also provided to aid painting. These wheels, with their realistic tyre treads, offer a significant upgrade over the kit parts. MiG-21MF Airbrakes (672193) This set provides both fore and aft airbrakes. The former will require the equivalent kit parts to be cut away, while the latter parts are a straight swap for the kit versions. This is an all-resin set, with no photo etch parts required. MiG-21MF Big Sin Set (SIN 67215) This set brings together a number of resin sets in one money saving package. inside the box, you get the following resin replacements: cockpit exhaust nozzle undercarriage wheels fuselage / wing pylons The overall package is around 25% cheaper than buying al of the sets on their own. MiG-21MF Masks (CX511) In a departure from the normal pre-cut masks offered by Eduard, this set omits masks for the wheels (as they have separately moulded hubs) and instead provides masks for the various dielectric panels dotted around the jet. The canopy is, of course, also covered. Conclusion Eduard can hardly be accused of shyness when it comes to providing aftermarket for one of their marquee releases of the past 12 months. It's great that Eduard's approach caters for both the casual hobbyist (through the weekend range of kits) and the committed enthusiast through this extensive range of detail upgrades. The quality of the items on offer is excellent, with each offering considerable enhancement over the plastic equivalents. Recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
