Darby
Geoffrey Wellum's Tribute
A few photos of the Spitfire in the hanger prior to the memorial flypast today. Had an interesting chat with the maintainers and a point to note is that the prop on this aircraft is wooden. That's straight from the horse's mouth so to speak. Hope these images are of use to anybody and the flypast was quite a sight as well. A fitting tribute amongst the glowering clouds above Cornwall today.
Neat pics Darby
Many of the the WW2 blades were wood based, being a compressed wood composite, Rotol using "Jablo"
google found me this, which I'd not see before
http://www.enginehistory.org/Propellers/Rotol/rotol.shtml
There are other types,  this is Jablo
The brass sheathing on the leading edge this can be seen here as the paint has chipped
sid_bregman.49tdpblsmr40os00wc4cc84gw.ej
as seen here in colour on a Spit XIV if you  look closely, note the yellowy nature of the bare metal.
3690539310_6cf2a9e36e_o.jpg&key=3db5ab7b
Here's a useful image of some blades,showing both the wood construction and the brass leading edge sheaths.
mkxv.camberface.jpg&key=7bf076bc326beeb7
Hope of interest
Is it an urban myth that the Fleet Air Arm worked out that you could remove up to 4" (100mm) to repair a propellor blade after pecking at the deck without it loosing performance?  Balancing them after must have been really difficult I would imagine.
This a photo of the Rotol label. There was a leading edge protective strip on each blade which you can make out below.
I think that I may be correct in saying that the current Jablo blades used on airworthy Spits are made in Germany. Delicious irony!
This certainly happened on the early Griffon Seafires,
the thrust line on the XV and XVII was lower, so they were more prone to 'pecking'
There is mention of the this IIRC,  in Seafire - from the Cockpit, but maybe in another Seafire book.  Sorry, books not hand to checkn details.
@gingerbob may know more.
@Work In Progress has posted this
cheers
T
Imported Hoffman blades for the BoB flight many years ago. Came in as a commercial shipment on a RAFG truck, with a load of other RAF stores.
Guess I forgot to enter them separately for duty and VAT :whistle:
