kitman Posted August 9, 2018 Share Posted August 9, 2018 Hi can anyone advise me as to what is there favourite metallic paint is when using a brush. In particular the best colour metallic for undercarriage legs. Thanks Link to comment Share on other sites More sharing options...
degsye39 Posted August 10, 2018 Share Posted August 10, 2018 While this may be unhelpful as it isnt technically readily available.. Nothing beats pre hornby era tins of humbrol enamel 11 or 191 IMHO I'd suggest ebay as i have seen multiple auctions with 50ml tins of the stuff going for a pittance ! Cheers! Link to comment Share on other sites More sharing options...
Beard Posted August 10, 2018 Share Posted August 10, 2018 (edited) Hello kitman and, as this appears to be one of your first posts, welcome to the forum. I'm a brush painter and use Tamiya's acrylic Flat Aluminium and Chrome Silver or the Humbrol enamel Metalcote range and always use a base coat of Humbrol enamel before applying either. For undercarriage legs, I usually use Tamiya Flat Aluminium with Chrome Silver for the slidey bits (unless it's a Spitfire... when I paint the legs in the underside colour). Edited August 11, 2018 by Beard to correct spelling. Link to comment Share on other sites More sharing options...
bmwh548 Posted August 10, 2018 Share Posted August 10, 2018 The metallic paste stuff is really good (finish wise), but it never fully dries so you need to be careful with handling. A few drops of Leveling thinner makes it very "brushable". Link to comment Share on other sites More sharing options...
CedB Posted August 10, 2018 Share Posted August 10, 2018 43 minutes ago, bmwh548 said: The metallic paste stuff... AK True Metal paste. I love it! I've found it great for variable bare metal finishes, smooth finishes (when airbrushed) and you can scrub it around until you get the finish you're after and burnish it to a shine if required. True, if you apply it too thickly, it takes ages to dry BUT it's much better if you dip the brush in some white spirit first and make sure it's not too thick. I think the problem occurs if the waxy base doesn't get a chance to 'flash off'. This was done with a mix of Dark Aluminium and Aluminium: Seems a bit expensive but it lasts for ages - you only use a little at a time. HTH 1 Link to comment Share on other sites More sharing options...
pigsty Posted August 11, 2018 Share Posted August 11, 2018 My metallic of choice is Mr Metal Color by GSI Creos (which is essentially Gunze Sangyo). It's easy to brush on, even without priming, though two coats are generally advisable. And if you leave it five minutes you can buff it til it gleams, especially Stainless. There are several colours in the range but the ones I find most useful are Stainless (good for anything between bright steel and aluminium), Dark Iron (good for gunmetal and deep steel shades) and Alminume* (very good for polished surfaces like oleo struts). Having said that, if I need large-scale coverage it's out with the car paints, and using the Mr Metal to highlight individual panels. * Japlish - pretty sure they mean aluminium Link to comment Share on other sites More sharing options...
sapperastro Posted August 12, 2018 Share Posted August 12, 2018 I just use Revell metallic colours these days. They do the job. Sometimes I will use Model master, or tamiya. Link to comment Share on other sites More sharing options...
