Thom216 Posted September 2, 2018 Author Share Posted September 2, 2018 Thanks. I would like a polished, shiny look, but it's not going as smoothly this first time, Look so simple on youtube!! It's also grainy to the touch, which is weird as some parts are quite smooth, like the flaps. The only thing I can think of is that I put too many coats on.(?) The flaps only got a few passes but I may have done too many on the fuse and wings. Tomorrow I'll use a fine sanding pad and go over it and see how it looks. May hit it with Alclad Chrome and see how that goes. I think I'll also test some MM metalizers. Just for shats and gaggles I sprayed a Tamiya Silver Leaf straight from the can onto bare plastic, then rubbed it down with a coffee filter and got this. Definitely not as shiny, but certainly smoother and less grainy looking. 4 Link to comment Share on other sites More sharing options...
Thom216 Posted September 3, 2018 Author Share Posted September 3, 2018 (edited) I looked at another youtube tutorial and I think I see where I erred. I forgot and used it like a normal paint. Supposed to be light coat, let dry and brush off any 'dust' before doing it again. Also forgot that this stuff dries fast too... I just sprayed and sprayed and covered that paint dust with following coats, giving the grainy effect. Edited September 3, 2018 by Thom216 Link to comment Share on other sites More sharing options...
amblypygid Posted September 3, 2018 Share Posted September 3, 2018 It might very well be the way that the photos have come out, but the prop looks less grainy than the large flatter areas (which only look slightly grainy). I think some buffing would help, for sure, though I'm also not an Alclad user and I find it hard to judge from photos. 1 Link to comment Share on other sites More sharing options...
Thom216 Posted September 5, 2018 Author Share Posted September 5, 2018 As a test, I used an older fuselage, putting a gloss black base down and then the Alclad. It came out looking pretty sweet. A little distorted here and there but very shiny and I can even see my fingers in the finish. If I can get the actual build looking as good as this, I'll be happy! 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 6, 2018 Share Posted September 6, 2018 Shiny, shiny. Top job thom, you really have to be perfect with the prep for a passable metal looking finish, looks like a good un to me Glynn 1 Link to comment Share on other sites More sharing options...
Thom216 Posted September 13, 2018 Author Share Posted September 13, 2018 On 9/6/2018 at 10:52 AM, Hewy said: Shiny, shiny. Top job thom, you really have to be perfect with the prep for a passable metal looking finish, looks like a good un to me Glynn Agreed, which I don't have here... So, slight change in plans as I am going back to the kit decals for this one. The Dottie Mae decals will be kept for another build with a better paint result. I know I could strip the paint all off the thing, but at this point I don't feel like doing that, nor do I want to deal with the resulting mess. Right now, Model Master Aluminum Plate is drying on the frame, probably all dry already, and I think I'm almost to decals and final assembly. Will post update pics soon! 1 Link to comment Share on other sites More sharing options...
Thom216 Posted September 13, 2018 Author Share Posted September 13, 2018 As said, some pics of the build, with paint applied. This is MM Aluminum Plate. Coverage is okay, though in spots I can see the waviness from too many coats of paint. Everything else is decals, from the checkers for the cowl to the D-Day stripes, so bound to have fun with that! 4 Link to comment Share on other sites More sharing options...
Valkyrie Posted September 13, 2018 Share Posted September 13, 2018 Like a metal finish. Even the tamiya silver leaf looks good 1 Link to comment Share on other sites More sharing options...
Thom216 Posted September 27, 2018 Author Share Posted September 27, 2018 Been a little while huh? And right at the end too. Not sure if I'll finish this by the 30th, but paint is pretty much done and the decals are going on. She's not like I initially intended and there are more than a few oopsies that I'm not going to point out. For paint and decals, I decided not to use the kit invasion stripes. At first I didn't think they were going to go alright, but using Micro Set I was able to lay the belly stripes down pretty well, except for a break that occurred by the turbine exhaust housing. It wasn't so bad, then I thought about trying to get the decals to conform to the under wing detail and I just decided to paint them. Their spacings are a little off, but doing this right has since gone by the wayside, so here she is so far. I need more Micro Sol to settle the decals against the fuselage. Somethings I'm not worrying about are varying silver panels or weathering. When decals are done, shes done. 😜 7 Link to comment Share on other sites More sharing options...
Hewy Posted September 27, 2018 Share Posted September 27, 2018 Very nice indeed thom, the silver looks good to me 1 Link to comment Share on other sites More sharing options...
Tbolt Posted September 27, 2018 Share Posted September 27, 2018 Very nice. The invasion stripes look good, I wouldn't worry accurate spacing, I'm sure the guys applying them on the real aircraft didn't worry that much about it. 2 Link to comment Share on other sites More sharing options...
PlaStix Posted September 29, 2018 Share Posted September 29, 2018 That is progressing nicely. Hope you manage to it over the line in time. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Thom216 Posted September 29, 2018 Author Share Posted September 29, 2018 (edited) Thank you, but the line is now too close. Work yesterday, work today, family tomorrow... Three strikes now. Let there be hope for the B-17 GB!! As of now, I'm putting the decals on the cowl and that's going about as I expected. Wrinkles and tears... Or is that tears..? 🤣 Not as bad as it first looked when first applying, as the Mico Sol works really good. But still, tiny wrinkles and a few tears. Considered putting it on hold, but I think I'll plug away at it off and on until finished and then park it in the Inspection Thread with some real tiny pictures!😁 The last panel is on and 'smoothing' now. After this, I'll be putting this more to the back of the table and pulling the Fr.47s back out as they are still in the Optimisic stage.😉 Edited September 29, 2018 by Thom216 3 Link to comment Share on other sites More sharing options...
