Bonhoff Posted July 30, 2018 Share Posted July 30, 2018 Hi All, This'll be my main project for this GB. KR's IanJ 7 Link to comment Share on other sites More sharing options...
PlaStix Posted July 30, 2018 Share Posted July 30, 2018 Great to see one of these is going to be built. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted July 30, 2018 Share Posted July 30, 2018 Great choice a Monster of a tank 1 Link to comment Share on other sites More sharing options...
CliffB Posted July 31, 2018 Share Posted July 31, 2018 It's nice to see yet another nation's take on how to do WWI armour. 1 1 Link to comment Share on other sites More sharing options...
Bonhoff Posted July 31, 2018 Author Share Posted July 31, 2018 (edited) Made a start - Unlike the single piece track links in the FT-17 that I built previously, these are two piece tracks that require but a quick swipe with a file once they've been detached from the sprue - this length took about a quarter of an hour to do, only another 88 to go. Along with these track links, the was the small matter of the 30 wheels, comprising 2 pieces each - Once again, very little fettling needed and before I knew it, one bogie had been completed. Think I'm going to enjoy this, although I must admit a certain bias as I've really enjoyed building all the Meng kits that have passed through my hands so far... IanJ Edited July 31, 2018 by Bonhoff 8 Link to comment Share on other sites More sharing options...
Graeme H Posted July 31, 2018 Share Posted July 31, 2018 As my maternal grandfather was involved in the recovery of the one here in Queensland called Mephisto, I'm in 1 Link to comment Share on other sites More sharing options...
sithman Posted July 31, 2018 Share Posted July 31, 2018 and as my Great Grandfather fought alongside these beasts, I'm in too! 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted August 1, 2018 Share Posted August 1, 2018 Nice start ther Ian I find this photo is very informative - thank you, now I understand the thinking behind these early suspension systems. 1 1 Link to comment Share on other sites More sharing options...
Andwil Posted August 1, 2018 Share Posted August 1, 2018 I admire your patience Ian. AW 1 Link to comment Share on other sites More sharing options...
PlaStix Posted August 4, 2018 Share Posted August 4, 2018 Great to see you've got this project underway and that you are making good progress. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Bonhoff Posted August 6, 2018 Author Share Posted August 6, 2018 Bogies went together without much trouble - If you are really careful with your glue it might be possible to have all the wheels rotating. Bogies are loosely placed on the baseplate here - Next will be all the supporting framework for the return rollers. KR's IanJ 6 Link to comment Share on other sites More sharing options...
Bonhoff Posted August 8, 2018 Author Share Posted August 8, 2018 Really should consider painting some of this before it becomes inaccessible... KR's IanJ 6 Link to comment Share on other sites More sharing options...
Robert Stuart Posted August 8, 2018 Share Posted August 8, 2018 That is looking good Ian, very 'industrial' 1 Link to comment Share on other sites More sharing options...
Andwil Posted August 10, 2018 Share Posted August 10, 2018 On 8/9/2018 at 5:23 AM, Robert Stuart said: That is looking good Ian, very 'industrial' Exactly what I was going to say! AW 1 1 Link to comment Share on other sites More sharing options...
Peter Lloyd Posted August 15, 2018 Share Posted August 15, 2018 Amazing progress. You'll be in Amiens in no time. 1 Link to comment Share on other sites More sharing options...
Bonhoff Posted August 16, 2018 Author Share Posted August 16, 2018 (edited) And now onto the tracks - On Meng's FT17 that I built previously, the tracks were a single piece that simply required clean up and clipping together. On this the track is in two pieces, the track plate and the wheelguide / hinge thingy and you require a total of 96 to do both sides. Fortunately - Once the parts are removed from the sprues, they need minimal clean up and if you do them in batches, can be done approximately one a minute. Only a couple of hours work there - Took me longer to do the link and length tracks on my 1/72nd Sherman Firefly.... Next - I taped together the basic superstructure to check for fit and to see if it'll be necessary to do something about the missing engines that are only provided in the limited edition version of the kit. I was hoping to leave the top of the hull loose so you could see all the interior detail, but it isn't quite a perfect fit - I may see what I can do about that, if anything. This is the view of the engine bay if you leave the "Cab" off - Visible engine bay outlined in red. IMHO engine detail only necessary if you have the whole roof or the side off - Think I can get away with painting the hole black . Now into brush priming hell IanJ Edited August 16, 2018 by Bonhoff Missing word 8 Link to comment Share on other sites More sharing options...
Bonhoff Posted September 12, 2018 Author Share Posted September 12, 2018 Hi All, Still beavering away, brush priming / painting as I go - Suspension is now all together and one of the tracks completed and installed. Observations as follows... 1: Make sure that you have all the track links moving after painting or the two ends won't meet. 2: Paint the inside faces of the flanged wheels, at least the ones on the ends of the bogies, as they will still be visible once everything is assembled. 3: I removed the locating pins from the tie bars between the bogies - Your life will also be made easier if you leave the exhaust silencers off until after you've installed the tie bars. 4: The tie bars are different lengths depending on location. Hopefully I'll get the other track painted and installed this week - Then we can start on the superstructure. Till the next thrilling installment. IanJ 7 Link to comment Share on other sites More sharing options...
Bonhoff Posted September 21, 2018 Author Share Posted September 21, 2018 Update Running gear now complete - In case you're wondering the tracks were primed with Humbrol Primer then painted with Citadel "Leadbelcher." They were then washed with a couple of coats of very thinned Humbrol Rust and finally a coat of Citadel's "Agrax Earthshade" brown wash to tone them down. Can now finally get on with the superstructure. IanJ 5 Link to comment Share on other sites More sharing options...
Bonhoff Posted October 10, 2018 Author Share Posted October 10, 2018 It's been painful so far priming all the bits by hand - Time to break out the spray cans and find a quiet bit of car park at work... IanJ 4 Link to comment Share on other sites More sharing options...
Bonhoff Posted October 23, 2018 Author Share Posted October 23, 2018 Moving onwards... 57mm cannon, driver/commander's station, machine gunners seats and radiators constructed and loosely test fitted. Really like the two leather seats - They seem, from a design point of view, very much of their era but wouldn't look too out of place in an executive furniture catalogue today. The leather is painted with Vallejo "Hull Red" with a Citadel "Agrax Earthshade" wash to highlight the upholstery. Radiators have a P/E mesh overlay on the outer face - Pity a lot of this detail may not be visible after completion. I have a little bit of work to do to the supports for the driver station as the two rads are causing a bit of distortion. Thanks for looking. IanJ 4 Link to comment Share on other sites More sharing options...
the South African Posted October 24, 2018 Share Posted October 24, 2018 Ian this project is coming along spectacularly!Stellar job so far mate. Regards: Shaun 1 Link to comment Share on other sites More sharing options...
Bonhoff Posted November 4, 2018 Author Share Posted November 4, 2018 Bit more done... The interior walls have had a couple of coats of Vallejo Off White followed by a wash of Citadel Nuln Oil, floor washed in Citadell Agrax Earthshade. The "Conning Tower" has been constructed - The vision hatches can be constructed in fully open, half and fully closed positions and include nifty little P/E rails that are just about doable without an etch folder. The walls have been lodged in place to see how much of the interior will be visible once it's done. The answer would appear to be "Not Much" Still - It's kept me out of mischief for a while..... KRs IanJ 2 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted November 4, 2018 Share Posted November 4, 2018 Ive seen a number of tanks with interiors over my years. Once built they had the top of the hull/turret removable for display ? Is that a possibiity here ? 1 Link to comment Share on other sites More sharing options...
Bonhoff Posted November 4, 2018 Author Share Posted November 4, 2018 Not sure - the top panel seems a teeny bit warped but until I get all the sides on I won't know for certain. IanJ 1 Link to comment Share on other sites More sharing options...
PlaStix Posted November 4, 2018 Share Posted November 4, 2018 Very impressive work on the interior. Looking good. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
