Shar2 Posted July 29, 2018 Share Posted July 29, 2018 Soviet AA Type 1.5 ton Railroad Truck MiniArt 1:35 The GAZ AA 1.5 ton truck was a licenced manufactured version of the Ford AA truck for the Soviet Union, where more than 950,000 were built. There were many body styles, but the most recognisable version was the flat bed truck as depicted in this kit, although being slightly different, in that instead of standard wheels with rubber tyres, this on is fitted with rail wagon style wheels. The model is contained within a very attractive, bright and colourful box that MiniArt have started using recently. Inside, there are nineteen sprues in grey styrene, one of clear, and a single sheet of etch brass plus a full decal sheet. Unlike the original kit of this truck, you don’t get any cargo provided, but you do get a nice set of rails for the truck to be displayed on. The build starts with the nicely detailed engine with the block, head and sump being glued together followed by the addition of the starter motor, alternator, water pump, auxiliary drive belt, cooling fan, cooling pipes, oil filler pipe. The gearbox is then assembled from three parts and glued to the engine assembly, along with intake manifold. The two, chassis rails are fitted with an extra beam where the truck bed will sit. These are held on the rails by three “U” bolts and their associated clamps. The rear leaf springs are then attached via their support links. Four cross members are then used to join the rails together, as well as the rear chassis end piece, to which the towing eye spring is attached. There is a three piece box attached to the left hand rail, near the front. The rear axle and differential is made up from six parts, if you include the drive shaft. This assembly is then fitted to the rear leaf springs, while the front suspension is made up on a single leaf spring assembly mounted laterally and fitted with the front axle, steering rack and support arms. The rear differential is then fitted with a triangular support structure which also supports the brake rods. The front and rear brake drums are then attached to the axles, followed by two wheels per side on the rear axle and one per side on the front axle. The wheels are then assembled from the outer hub, to which the inner, flanged ring is attached and the central boss detail. The front wheels are then glued to direct to the brake drums, while the rears are fitted with a small spacer between the drum and the wheel. The front chassis end cap is attached as are the two bumper side arms, while to the rear there is a choice of towing hook styles, one, just a single piece unit, the other is made up from five parts. The engine assembly is then glued into position, followed by the two piece radiator, two piece front bumper and two support brackets on chassis rails. The five piece exhaust is the attached to the right hand side. The two front fenders are each single piece units to which a small hook is attached before being fitted to the chassis, as are two of the lateral truck bed beams. The cab floor is also attached and fitted with the bench seat, gear stick and panel support. The three piece wiper/wiper motor is fitted to the front screen surround, once the clear screen has been fitted. The screen is then fitted with two small arms, these can be glued in either the stowed position for a closed screen, or down, so that the screen can be posed open. The rear of the bonnet section is then glued to the front of the screen support, along with eh two side sections and engine bulkhead which has been detailed with several small parts. Inside the foot pedals are attached lower bulkhead, part of the floor panel fitted earlier, before the front cab assembly is glued into place, along with the steering column and wheel. The three piece rear panel and roof of the cab are then glued into place, as are the two bonnet supports, between the bulkhead and the radiator. Each door is made up from five parts, including clear section, door handles, latches and window winders. The doors are then put to one side. The bonnet halves, split longitudinally are each made from two sections, which can be posed in either the open or closed positions, allowing the modeller to show of the engine should they so choose. The doors are then attached; again, they can be posed open or closed as the modeller wishes. The three piece horn is attached to a rail, which in turn is attached to the front of the vehicle between the fenders. The two, three piece headlights are then fitted, as is the single, two piece wing mirror, on the drivers side. The truck bed is then assembled from five parts, depending on the colour scheme being built you can have either four plank sides, front and rear sections you can use six plank sections. The bed, sides, front and rear sections are glued into place, completing the truck section of the build. The rest of the build concentrates on the tracks. These consists of sleepers, two lengths of rail per side being joined by fishplates, and the individual rail ties. When assembled and painted there will look very realistic, when compared with the Trumpeter style of rail track. Since they are of Russian gauge, you won’t be able to use them with Axis vehicles, but MiniArt do additional sets of track if you wish to build a rail diorama with the Soviet armoured railcars that are on the market. Decals The decal sheet gives the modeller six options. The decals are beautifully printed, are clear and in good register with a slightly matt finish. The different companies Initials are included for two of the options, as well as the other vehicles respective registration plates and insignia. The options are:- An Unidentified Waffen SS unit, presumably the Reichskommissariat, Ostland 1943 – 1944, four plank bed. An Unidentified Soviet unit used between 1941 and 1945, with four plank bed. An Unidentified of the Wehrmacht, on the Eastern Front 1941 – 1943, with a four plank bed. Deutsche Reichsbahn, (Imperial Railway Administration), on the Eastern Front between 1942 and 1943 with a four plank bed. An Unidentified Soviet unit used between 1941 and 1945 with a six plank bed. Deutsche Reichsbahn, (Imperial Railway Administration), Ostland, used between 1943 and 1944 with a six plank bed. Conclusion I just love these trucks from MiniArt, they are so evocative of the period and can be used in so many situations, whether on their own, or an evocative diorama. The oddity that is having a truck on rails will make it stand out in your collection and certainly be a conversation piece. The staff at MiniArt should be commended for giving us modellers such great kits with pretty much everything you need, just let your imagination run wild. Review sample courtesy of Miniart - Distibuted in the UK By Creative Models 1 Link to comment Share on other sites More sharing options...
