Nocoolname Posted July 24, 2018 Share Posted July 24, 2018 Hi Phantom Pholks! I'm hoping someone might be able to enlighten me on whether there are any key differences between the F-4C/D and the Long Nosed Phantoms other than the obvious - nose and cockpit? Given that a) there's no sign of ZM's Long Nosed Phantoms anytime soon and b) my lack of patience I was thinking of splicing the nose from my Hasegawa F-4G to a ZM F-4D to make a better Wild Weasel. I'd be interested in your thoughts. Cheers Link to comment Share on other sites More sharing options...
Reparty Posted July 24, 2018 Share Posted July 24, 2018 The very first long nose F-4E's were converted earlier F-4s (F-4C 63-7445, F-4D 65-0713) so a long nose spliced to a ZM Phantom would work, along with J79-GE-17 long petal nozzles. The hydraulic wing folds were removed along with the Ram Air Turbine on the port upper intake. Otherwise the airframes model wise are identical. The slatted wing used on all F-4Gs would also need to be factored in to your project. They were all FY69 aircraft, which means they all had the belly re-inforcing strap. 1 Link to comment Share on other sites More sharing options...
Ben Brown Posted July 27, 2018 Share Posted July 27, 2018 The aft fuselage was different on the F-4s with the J79-GE-17 engines. The natural metal area where the fuselage met the afterburner nozzles was shorter. Only Z-M addresses this difference in 1/48. They supply different parts to use with the different afterburner nozzles. You'll need to cut down Parts J1 and J2 or source the same parts from the F-4J/S kits. If I may offer my opinion (feel free to tell me to shut up and go away! ), the Hasegawa F-4s are actually very good, shape-wise. They got the aft fuselage shape right, while Z-M missed the mark, there. If you add the aftermarket cockpit of your choice, intakes (several vendors offer them), and possibly afterburner nozzles, you'll have a model that's just as detailed as a Z-M Phantom. Cheers! Ben 1 Link to comment Share on other sites More sharing options...
Sonoran Posted July 28, 2018 Share Posted July 28, 2018 But Hasegawa totally missed the shape of the front end on their long nosed F-4s. 1 Link to comment Share on other sites More sharing options...
Duncan B Posted September 13, 2018 Share Posted September 13, 2018 Wait for the ZM F-4E, it isn't all that far away and if it doesn't make an appearance at Telford this year I'll eat my hat. Duncan B 1 Link to comment Share on other sites More sharing options...
Sonoran Posted September 13, 2018 Share Posted September 13, 2018 They told us in Phoenix that they're working on them. 1 Link to comment Share on other sites More sharing options...
whiskey Posted September 13, 2018 Share Posted September 13, 2018 (edited) Swearing removed Edited September 18, 2018 by Greg B 1 Link to comment Share on other sites More sharing options...
Sleepwalker Posted September 14, 2018 Share Posted September 14, 2018 Maybe not a dozen but one for me, but then I'm eagerly waiting for wildest weasel for me - F-4G. Link to comment Share on other sites More sharing options...
whiskey Posted September 14, 2018 Share Posted September 14, 2018 4 hours ago, Sleepwalker said: Maybe not a dozen but one for me, but then I'm eagerly waiting for wildest weasel for me - F-4G. I've got enough markings for a dozen Weasels too! Link to comment Share on other sites More sharing options...
jpk Posted September 18, 2018 Share Posted September 18, 2018 Also, Jeffrey at Hypersonic is working on correction parts for the rear of the ZM fuselage. The test photos look promising, if that is an issue with you. Link to comment Share on other sites More sharing options...
Sonoran Posted September 21, 2018 Share Posted September 21, 2018 On 9/18/2018 at 5:55 AM, jpk said: Also, Jeffrey at Hypersonic is working on correction parts for the rear of the ZM fuselage. The test photos look promising, if that is an issue with you. That’s going to have to be some massive pieces of resin Link to comment Share on other sites More sharing options...
tony.t Posted September 21, 2018 Share Posted September 21, 2018 The Hasegawa spine is too narrow. I'd wait for the Z-M F-4G Adv.WW to be released. Tony Link to comment Share on other sites More sharing options...
jpk Posted September 30, 2018 Share Posted September 30, 2018 On 9/21/2018 at 12:08 PM, Sonoran said: That’s going to have to be some massive pieces of resin They are actually quite thin like the plastic. Link to comment Share on other sites More sharing options...
