LaurieS Posted July 24, 2018 Share Posted July 24, 2018 Present model a GR3 Harrier has raised panel lines which I am removing. Replacing is going OK plus adding blind rivet lines. There are numerous access panels. Trying to keep as many of these as possible. However I am going to have to replace some as they are rubbed out partially with seam repairs. Question and help. I have stainless steel templates that is not a problem. It is the technique for scribing the shape in the template is the difficulty. I have four different scribers (well you have to) plus two Flexifile needles. The Flexi File seems to be the only optional. Tried both the fine and medium needles (held in a whasis name vice). Get a recess but not a very nice clean one that I get using the Tamiya scriber. Any advice received with great thanks. Also any advice and technique for scribing the rivets in the access panel. Laurie Link to comment Share on other sites More sharing options...
PhoenixII Posted July 25, 2018 Share Posted July 25, 2018 14 hours ago, LaurieS said: It is the technique for scribing the shape in the template is the difficulty. I have four different scribers (well you have to) plus two Flexifile needles. The Flexi File seems to be the only optional. Tried both the fine and medium needles (held in a whasis name vice). Get a recess but not a very nice clean one that I get using the Tamiya scriber. Any advice received with great thanks. Also any advice and technique for scribing the rivets in the access panel. Laurie Hi Laurie, all I can suggest is:- 1. Make sure the template is secure on the fuselage then lightly run the scriber of choice around the template, multiple times, let the scriber do the work rather than pressure. 2. You'll need to lightly abrade the area around the panel OR use liquid adhesive sparingly over the top, or both, this will reduce the peaks and troughs. NB Beware of Tamiya extra thin, it's rather 'hot'! 3. New tool! Get one of Radu's riveting tools or a 'Rosie the riveter' or a good old fashioned ponce (pounce) wheel. HTH Paul Link to comment Share on other sites More sharing options...
LaurieS Posted July 25, 2018 Author Share Posted July 25, 2018 14 minutes ago, PhoenixII said: Hi Laurie, all I can suggest is:- 1. Make sure the template is secure on the fuselage then lightly run the scriber of choice around the template, multiple times, let the scriber do the work rather than pressure. 2. You'll need to lightly abrade the area around the panel OR use liquid adhesive sparingly over the top, or both, this will reduce the peaks and troughs. NB Beware of Tamiya extra thin, it's rather 'hot'! 3. New tool! Get one of Radu's riveting tools or a 'Rosie the riveter' or a good old fashioned ponce (pounce) wheel. HTH Paul Thanks very much for the info and your time Paul. On the Rosie this is interesting. I tried to obtain the original Rosie. The story I got was that the orignal character who produced Rosie had shut down and another had taken up production I think in the USA. However I also found that the new Rosie was using RB Productions wheel which looking at the picture I saw at the time was identical to the RB Productions effort. The original Rosie had rounded teeth. The RB productions is more like a dash. Not bad but the original Rosie was the real thing. Can you check to see if the disc is an original Rosie or the RB Productions Model. If the original I am all for getting one. Thanks Laurie Link to comment Share on other sites More sharing options...
PhoenixII Posted July 25, 2018 Share Posted July 25, 2018 Hi Laurie, mine's nowt so posh, 'cos i'm a tight fist, mine's Chinese! HM Hobbies are showing stock of the original 'Rosie the riveter'......as of five minutes ago! Production seems to have switched to the U.S. main stockist seem to be UMM-USA. For further information Google 'Rosie the riveter' there's even 'You Tube' videos, that should waste at least ten minutes of your day! Paul Link to comment Share on other sites More sharing options...
LaurieS Posted July 25, 2018 Author Share Posted July 25, 2018 3 minutes ago, PhoenixII said: Hi Laurie, mine's nowt so posh, 'cos i'm a tight fist, mine's Chinese! HM Hobbies are showing stock of the original 'Rosie the riveter'......as of five minutes ago! Production seems to have switched to the U.S. main stockist seem to be UMM-USA. For further information Google 'Rosie the riveter' there's even 'You Tube' videos, that should waste at least ten minutes of your day! Paul Had a look Paul. It actually says in the blurb that the wheels are stainless steel made by RB Productions. Regret they are just like RB Productions own product and not a real Rosie original which they are cheating by calling it so. But RB type are not bad. Their product. You can change the wheels as they are held in position by a nut and screw. They do a large size and a small size to get into awkward places. http://www.radubstore.com/index.php?main_page=index&cPath=77_110 Worth a look at their products they have seduced me to part with some of my beer money. Thanks Paul Link to comment Share on other sites More sharing options...
