AV-8S Harrier "Matador" 1/48 - finished!
Hi everybody y bien venidos!
I will move on here with my Spanish series....
this time with an early Harrier of the 8th Squadrille, Spanish Navy, or Armada Española, Octava Esquadrilla
Monogram molds, as Kinetic did not manage yet to release a very early Harrier single seater... fingers crossed they will soon! (GR.1, Gr.3 and AV-8A and AV-8S)
Decals by Series Españolas, looking great, as usual!
I will add a Quickboost Stencel seat I guess...
20180722_135122_11
20180722_135140_11
that is what I have for now, fit looks good! :) :)
Weapons? gun pods I assume, as well as N/ P Sidewinders, or alternatively Lau -10 Zunis....
external tanks? which size and where to take from? are the 100 Gallon tanks from Hunters the same one?
looking forward top your comments!
Thanks, Werner
Edited by exdraken
I built one of these a few years ago Werner as a USMC aircraft and I really enjoyed it, I re-scribed the panel lines.
I built the Kinetic T4 this year and didn't enjoy it so if I can find Monogram ones cheap I will pick them up instead.
Nice to see you building a Matador, will look nice next to your Spanish F-104, which of the schemes will you be building?
Craig.
Looking forward to this - there can't be too many Harriers built! :D
I built this kit myself as part of the 1970's NATO GB last year:
Unfortunally the pics disapeared in 'The Photpbucket' incident but perhaps there's some information to be gleamed from all the help I got.
I built mine as an RAF GR.1.
902ddedc-b71e-4d3b-b402-90a77dfdae71.JPE
One last observation is that the kit actually is an AV-8 with Stencel seat. :hmmm:
Cheers :bye:
Hans J
Craig.
Hi Craig,
thanks, it will be a very quick build, only a better detailed seat (hopefully) and a Master pitot.
Not too many schemes to chose from actually! pre-1980 with MARINA markings, or later 1980-1996 ARMADA markings....basically Gull Gray over White...the latte ones are a bit more colorful, as there is a Squadron marking on the nose ;) ! I could also add 25000 flight hours on the tail....
that's it more or less!
yeah, hopefully it will look nice! next to the EdA Starfighter, F-4, C-101 and F/A-18M!  (but also next to the GR.3 and GR.7s ;) )
Cheers :bye:
Hans J
thanks Hans,
pity about the pictures! nice one though! will go through your thread for sure! :thumbsup:
thanks for the seat info, I still hope the Quickboost seat is more detailed ;)  the kit one would be fine though if necessary!
cheers!,
Werner
Hi, Werner......You'll have to stick to the grey/white scheme......The AV8-A matador never sported the later, overall grey scheme seen on the AV8-B Bravo.....
I've got that kit in my stash, and find it an excellent option, despite its raised panel lines. Even the cockpit is nice, OOB...
I remember seeing them onboard "Dédalo" carrier, and what really caught my attention, as a 12 years old kid, was the terribly dirty looking of their undersides.....contrasting with the almost polished upper surfaces......
Saludotes...!!!!!
Edited by Artie
Looks interesting! Always nice with a Harrier! :)
Håkan
some update....
take share relatively fast ! :) :)
20180727_223813_1
20180727_223756_1
intakes, somehow I am missing the dropping aux doors... but I assume hey simply do not exist here......
20180727_224327_1
readly for closure !
Nice one, Werner! Me's tagging along.
Say, where did you get that Monogram kit from? They've seemed very difficult to come by as of late. I secured one some time ago, and mine is supposed to become a GR.3 with the aid of an Airfix LRMTS nose and a SHar tail.
Awesome kits, shapewise. The intake suck-in doors don't exist, IIRC, something which is easily fixed by such a talented modeller with your skills. Sure the kit needs rescribing and, if you've got the Kinetic SHar, you could always scratchbuild both the nose and main gear wheel wells by using those in the Kinetic kit as reference.
Cheers Werner, my mate!
Unc2
Edited by Uncle Uncool
Unc2
thanks, but undeserved ;)
got mine locally through the net,  just a month ago and so immediately started! was searching for ~ 2 years..... was cheap as well :):)
no rescribing with this one, panel line look good, I'd have a hard time producing something as decent!
the blow in doors will be done.. maybe I jsut cut up some PE frames!
fuselage closed, sorry, only a quick comparison pic with my other just started project , a Su-9 in the cold war Group build!
kit is rather smallish! and elegant :)
20180729_224324_1
hmmm if anyone is in doubt, he upper one is the Harrier :P
Hi Artie, thanks!
22 hours ago, Artie said:
Love that Matador..........!!!!!! By the way, be careful with the antenna layout.....
yeah, those seem to be different from the kit ones! any differences from Marina to Armada era?
do you have more info on the little window (camera?) in the nose port side?
will have to scratch something here....
quite dirty on the back end those beasts!!
by the way, please remove the hotlink to the 1st photo...... airliners. ........ .net obviously is not very keen to have hotlinks around.... ;)
Edited by exdraken
What exactly did you do with the intakes? I've got the kit as well, thinking about starting it soon and was just curious as to what exactly you did on yours.
hmmm not fully sure yet,
but the top 4 blow-in intake doors that are placed around the intake  are missing from the kit. If you look at the photos above, you can see that they open, depending on engine power (air flow necessities) when the engine is running, or when switched of  on the ground the top 4 ones drop caused by gravity. I am going to cut some PE to replicate them. That is all.
Apart, I just painted the inner intake wall in white. The border needs to be painted light grey though yet.
hope this helps a bit!
searching for intake photos:
hard to see into the intake, but cool loadout!  credits to the owner of course!
Edited by exdraken
On 7/31/2018 at 12:16 PM, Mr B said:
Nice subject.
Hope to see it done soon. So far it looks great.
rgds
me and soon.....
but thanks!
stuff arrived:
20180802_172421_1
20180801_191714_1
Stencel seat....
20180802_221847_1
of course not a drop in replacement....
but when made to fit (the tub again :banghead: )
it fits!
20180802_221809_120180802_221754_1
always goofy to modify after painting and glueing ...... ;)
Edited by exdraken
Awesome work so far, Werner!
You might remove the PE suck-in doors in order to give 'em a rounded shape by using the profile of the airframe aft of 'em. It's such an easy fix, my mate. Also, the four upper doors are opened almost vertically due to gravity. Fifth door from top to bottom (the one right in front of the NACA intake), is partially opened, like the way you placed the other ones.
Open up that NACA intake as well.
Cheers, my Helvetic mate!
Unc2
Unc2
Hi there!
Were to begin...
The easiest;)
Not Helvetic at all! - Iberic, not really, but would fit at least!
Alpine? If you like....
Austrian? Yes!
Styrian ? Yes!
Ok, next one from below...
Naca intakes??? The spatula shaped thing behind the 5th door you mean? Ok....
The 5th door.. why Monogram, why??? ;)
Droping the doors vertically hmmm there is inner structure that prohibits that now.... the doors would be way too short then ... sorry!
And second to last... I have no idea were I should "round" what.... ??
And last one,  thanks a lot for your input my Argentine??? Friend! :)
:thumbsup:
:blink2: Wow, what was I thinking when I pulled that one off...? my mistake.
Yeh, the spatula-shaped thingy behind "they're" 5th door. A spatula; wouldn't have ever thought of that.
Went to fetch my Monogram Harrier kit and found there was a spider the size of Texas dwelling in the stash! :lol: "Sheila, go get the shaving foam!" Inner structure there? Hmph... :hmmm:
The PE suck-in doors you've got to bend 'em over the shape of the fuselage which is right behind the suck-in door holes they cover. That way the PE suck-in doors will have a curved shape like the fuselage area they're fixed to, get it? "Sheila, come explain brother Werner what I'm going on about!"
As Argentine as the tenderloin steak, which I'm gonna feed you the day you come visit me in Buenos Aires, yeh? :nodding:
Cheers Werner!
Unc2
  • Haha 2
oh!
that you meant!
could not understand , because I DID that already :P
, sorry if not fully visible on the photos :)
all of them should already have a slight bend to them !!
inner structure: behind those spiderwebs, I assume there is an inner part of the intake (a separate part , white below) that blocks the suck-in doors, as you prefer to call them, being fully vertical! (see left intake on photo below!)
29808827058_c3438bc856_b.jpg&key=77d9671
Spatula... or NACA...... the same, no? :D :D :D
are  they open permanently (kind of an air intake to a certain sensor/ aux air???) or are they also suck/ blow  or as I prefer air pressure dependent?
ternderloin sounds great by the way!!!!
phuu quite a distance to cover..... current likelihood to have it down and over there.. close to 0 I fear!!!
you in GOOD old Europe every now and then? quizas???
cheers! Werner
Ah, me sees! No dice to cut or shave 'em either.
Spatulas are opened permanently; they're like those in the Buff, Buccaneer, late-style Tomcat cannon vent, Intruder, etc. They suck air in by pressure dynamics. Anywhere on an aircraft that you see a spatula, that's a NACA intake.
Yeh, meat's so tender you can cut it just by staring at it. Oh, and the taste is glorious if made on a grill.
Not me, but my mum. She's to visit Prague, Vienna and Budapest in October; I asked her, "Mum, can I come?" And she said, "No!":lol:
Cheers, my mate!
Unc2
  • Haha 2
Hi Werner,
There's quite a bit about auxiliary intake doors and the shape of the ducts on Vitaliy's GR7 build. It's all quite logical when you think about it; when hovering or when forward speed is low, the engine can't get enough air so sucks the intake doors open, creating another route for air to get to the fan. As a designer, you'd generally want a nice smooth path for this additional air to travel along, so the doors rotate about their hinges out of the way into recesses. No power, no springs (apart from a pair of little leaf springs along the wall of the fixed part of the auxiliary intake to help the doors remain in the closed position without wobbling about), just clever shaping. If you followed the primary intake in towards the fan (best done with the fuel valves off and a broom handle stuck down the intake to stop the slicer turning), you'd find that there's an edge along the line the moving edge of the auxiliary doors in their open position, interspersed with supporting webs. This edge meets the inner wall of the intake further aft than when it meets the "middle" AI door. Vitaly has modelled this very realistically on his model, so it's worth a site search. Hope this helps.
Kirk
5 hours ago, Kirk said:
Hi Werner,
Kirk
thanks Kirk!
 how could I miss 14!!!pages of Harrier p...???
intake section starts here for reference:
  • 2 months later...
so everybody!
the Brits Abroad GB has just finished and my SyAAF Meteor taking all the modelling time lately...
with great entries into the gallery, this one would have fit as well ;)
but no no time spared to move on with the Matador!
20181023_124831_1
the 5th blow in door was opened (thanks Monogram :( )
the NACA (or Spatula)  intake just behind as well, needs some more cleanup though!
thanks @Uncle Uncool
the nose camera was opened, and some structure build around
the fin mounted radar warning receiver (a later Matador upgrade) was scratched (not finished yet)
20181023_124848_1
20181023_124902_1
and that is a bottom view ;)
more soon!
Werner
Edited by exdraken
