trickyrich Posted August 14, 2018 Author Share Posted August 14, 2018 1 hour ago, Col. said: Oooh! Do we need a second Hawker GB? we probably could, the last one was very popular! Though there is the chance of the D Day GB? My only wish was it had been the "Car Door" type, the RAAF tested 3 of them in the desert, they were in desert colour scheme as well (well they sort of had to be). 1 Link to comment Share on other sites More sharing options...
Arniec Posted August 15, 2018 Share Posted August 15, 2018 8 hours ago, trickyrich said: we probably could, the last one was very popular! Though there is the chance of the D Day GB? My only wish was it had been the "Car Door" type, the RAAF tested 3 of them in the desert, they were in desert colour scheme as well (well they sort of had to be). You can always try to get the old Revell car door type and get the extra resin parts from MDC for it. 😉 Cheers, 1 Link to comment Share on other sites More sharing options...
franky boy Posted August 15, 2018 Share Posted August 15, 2018 Looks like you’re going to have your hands full with this one Rich! That Typhoon truly is a thing of beauty. James Link to comment Share on other sites More sharing options...
trickyrich Posted August 15, 2018 Author Share Posted August 15, 2018 1 hour ago, Arniec said: You can always try to get the old Revell car door type and get the extra resin parts from MDC for it. 😉 Cheers, I've said it before Arnold, you're an evil person putting all these ideas in my head!! But not this time......unless I can find another one on evilBay cheap. I got this one for less than it would have cost me to get it direct from MDC! 1 hour ago, franky boy said: Looks like you’re going to have your hands full with this one Rich! That Typhoon truly is a thing of beauty. James As you may have noticed I'm a bit of a resin fiend, love and hate the stuff! The MDC gear along with Fisher Model & Pattern probably turn out the best resin models you can buy. The quality of them rival the best plastic stuff from Japan. Unfortunately so does the price! 3 1 Link to comment Share on other sites More sharing options...
Col. Posted August 15, 2018 Share Posted August 15, 2018 1 hour ago, Arniec said: You can always try to get the old Revell car door type and get the extra resin parts from MDC for it. 😉 Cheers, Sounds nowhere near complicated enough for Rich going down such a straight-forward route Arnold 1 2 Link to comment Share on other sites More sharing options...
Arniec Posted August 15, 2018 Share Posted August 15, 2018 (edited) 7 hours ago, trickyrich said: I've said it before Arnold, you're an evil person putting all these ideas in my head!! But not this time......unless I can find another one on evilBay cheap. Me evil?! Noooooo. Those are all positive ideas. By the look of your answer I have already did it. Cheers, Edited August 15, 2018 by Arniec 1 2 Link to comment Share on other sites More sharing options...
trickyrich Posted August 17, 2018 Author Share Posted August 17, 2018 Just a quick update as it’s pretty late here and I’m quite tired....long day/week! This is basically what I’ve been doing for the past couple of days. As mentioned earlier I have a new/correct resin seat for her so now I could start building or more re-build the ejector seat so it’ll look something like this. I ending up using a couple of bits from the original frame, the rest is plastic rod. It’s not quite there but it looks 100% better. I’ve had to make the ejector seat rails short as with most on these resin models the cockpit tub walls are not square! A few minor details and some paint and it’ll look perfect. The U/c was the other item replaced. As can be seen there is a bit of difference between the two sets, especially with the nose gear! The original gear seemed to be too long, the aircraft actually sat quite squat on the ground. A can be seen the originals bit are all too long, the nose gear and wheel wouldn’t fit and it’s in its fully compressed state! I have since shortened the forward section of the new wheel well as well, as it was a bit too long. The main gear has the same issues, in its compressed state the original gear wouldn’t have fitted. I have to make new mounts for the new gear so I’ll set the correct heights then. The new nose wheel well is already to fit, I just need to make a mount for the gear and actuator to fit onto. Once it’s in place I can finish tiding up the actual wheel openings. Hopefully I can get the cockpit painted and fitted this weekend, then I can close up the fuselage, as the next major tasks are getting the nose to fit correctly and sort out the cockpit opening, there’s something not quite right there. The seat can go in much later. I may even get the wing on this weekend as well. 6 Link to comment Share on other sites More sharing options...
Col. Posted August 18, 2018 Share Posted August 18, 2018 Tidy work Rich and a lot of it at that 1 Link to comment Share on other sites More sharing options...
stevehnz Posted August 18, 2018 Share Posted August 18, 2018 Great goodness Rich, you don't half like taking the long way home (cue Supertramp ) it makes my Airfix & SH D/Ks look quite beguiling in their straightforward simplicity. I'm sure your WIP & finished item will be way more interesting/ impressive than mine will be come the day. Steve. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted August 19, 2018 Author Share Posted August 19, 2018 On 8/18/2018 at 6:17 PM, stevehnz said: Great goodness Rich, you don't half like taking the long way home (cue Supertramp ) it makes my Airfix & SH D/Ks look quite beguiling in their straightforward simplicity. I'm sure your WIP & finished item will be way more interesting/ impressive than mine will be come the day. Steve. thanks Steve, and if I had any sense I'd build the Airfix...again. I built her years ago just after it was released. I remember it was a super nice one to build, though i stuffed up the paint job. I had been going really great with the seat until I dropped it just before the clear coat and broke of the seat handles, they've disappeared so will have to replace them. I'm going to cheat with the panels in the cockpit, I have lots of leftover Eduard PE IP's so I'll use them to help detail the tub. 2 Link to comment Share on other sites More sharing options...
exdraken Posted August 20, 2018 Share Posted August 20, 2018 Great update Rich! Looks like a quick build as well Interesting how different sizes csn be interpreted... how on earth happen those discrepancies!!! Link to comment Share on other sites More sharing options...
trickyrich Posted August 21, 2018 Author Share Posted August 21, 2018 Thanks, I'm now getting really close to closing up the fuselage. I'm always a bit surprised at how they can sometime get the sizes so wrong. Even if you don't have accurate drawings at hand just lining up the actual parts as I did quickly shows up size issues. Oh well it gives me something to do and keeps the families of the AM supplies fed. 1 Link to comment Share on other sites More sharing options...
Hewy Posted August 21, 2018 Share Posted August 21, 2018 Fine jobs done there rich, seat looks smart Glynn 1 Link to comment Share on other sites More sharing options...
trickyrich Posted August 22, 2018 Author Share Posted August 22, 2018 Time for another update, this is what has been done since last. I’ve started to fill in the gaps around the new nose wheel well, once the fuselage is closed I can finish this off, which will be a nice quick job. I tidied up around the new side intake on the fuselage. I then had to figure out how the cockpit will sit. As can be seen there is no mount for it, just some cut outs in the fuselage for the side walls......which are wrong! So after lots of test fitting and comparing to photos I’ve come up with this. Not very pretty but it seems to do the trick. Height wise it’s just about spot on. The cockpit and seat are just about done, I just need to finish up some painting and give them a coat of flat clear. Excuse the dust. The seat actually came out well compared to the original and with the canopy closed it'll look just right. The instrument panel and cowling are the next things to be played with, the cowling and bits on top look sort of correct the IP wasn’t and the whole thing had a bit of a lean to it. So I’ve cut it all up and rebuild it using the PE panel from the Eduard interior set. If I get it right I may end up looking something like this....maybe. It should all look nice and busy looking when done. Getting the cockpit opening and front and rear sections of it right will be fun! But all does sort of fit and sit right which is a big help! 7 Link to comment Share on other sites More sharing options...
trickyrich Posted August 26, 2018 Author Share Posted August 26, 2018 I don’t really know if I’ve done a lot at all, I do know though it his taken quite a bit of time to do what I’ve done! Well the fuselage is closed and the wings are on, that is an achievement but boy it was some work. The fuselage went together reasonably easy and I didn’t need to use any alignment posts. The wings.....hmmm not so easy and once they were on I found they are ever so slightly warped and more to the point twisted! They’re not really bad or noticeable, so I’m still tossing up whether to just leave them of try giving them a quick bath in hot water. There’s no way I could ever remove them now. I’ve decided to fit intake/exhaust covers so I chopped off part of the intake duct and fitted the nose. Again not quite the simple task as the profile was different when the two parts were lined up. After a frustrating hour or so of checking drawings an measurements I think fuselage was too short.....may be, I gave up in the end as I got way too confused. The simplest thing was to just add a plastic shim to fill in the gap. No reshaping of the resin on the fuselage or nose was required, I just needed to shape the new plastic....looks like it was made to be there. Big relief as there are some complex curves in that area! I could now fix up the cockpit opening and area around it as well. One nice thing I am quite happy with is everything seems to fit under the canopy nicely, the canopy actually fits and it all sits nicely......almost unbelievable! The next big task is to clean up all the joins, they’re not as nice as I had hoped, plus I need to finish off the cockpit. Still a bit to go but am sort of happy with where I’m at for the moment. 8 Link to comment Share on other sites More sharing options...
trickyrich Posted September 7, 2018 Author Share Posted September 7, 2018 all I can say is that I haven't been distracted by lovely resin things.... Ok I haven’t done much to this build at all, she’s waiting for me to clean up all the joins and fill in some nasty holes around some of those wing joins! Good news is I’ve finally got the colours I need for her. It’s a bit of a strange mix of lacquer and water based paints so I’d better get the painting order right! I’ve used neither of these paints before but have heard good things about them. With luck I’ll get a bit done this weekend. 3 Link to comment Share on other sites More sharing options...
Col. Posted September 7, 2018 Share Posted September 7, 2018 Good luck with that mix Rich. Getting it wrong might give you some interesting 'effects'! 1 Link to comment Share on other sites More sharing options...
Hewy Posted September 7, 2018 Share Posted September 7, 2018 Nice choice of paints, are you using the mission models paint for the undersides, "silbergrau", i must get me some of those mrp ones to try, looking good so far 1 Link to comment Share on other sites More sharing options...
trickyrich Posted September 7, 2018 Author Share Posted September 7, 2018 5 hours ago, Hewy said: Nice choice of paints, are you using the mission models paint for the undersides, "silbergrau", i must get me some of those mrp ones to try, looking good so far yeah the Mission is fr the undersides. I had so much trouble trying to find the right colours and no one here had all the colours I needed from the one manufacturer. I've heard good things about both of these paints so am looking forward to trying them out. I may look as if I have more than I need but I intend to build a few more Luftwaffe aircraft of this era. Link to comment Share on other sites More sharing options...
franky boy Posted September 7, 2018 Share Posted September 7, 2018 Nice work Rich, that cockpit looks top notch. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted September 20, 2018 Author Share Posted September 20, 2018 I haven't forgotten about her..... I'll have an update for her this weekend, she's getting close to the painting stage, I just need to finish the cockpit. Most of the filling and tiding up is complete, the radome is on and it didn't fit very well. I'm currently working on the elevators, the shape of them is wrong and I've just finished making the mounts for them from brass and aluminium. 1 Link to comment Share on other sites More sharing options...
Col. Posted September 20, 2018 Share Posted September 20, 2018 We'll wait Rich. Not patiently but we'll wait 1 Link to comment Share on other sites More sharing options...
trickyrich Posted September 25, 2018 Author Share Posted September 25, 2018 all good things....... Wow, it’s been a while since I’ve updated this one!!! Progress has been a bit slow with other projects and this one fighting me a bit! Right what have I done....well mainly trying to close up that cockpit which seems to be taking forever and cleaning up the fuselage. I’ve just about finished up the cockpit, all the bits are in, I just need to finish up the last bits of painting. As usual, not too much will be seen, which is nice as the Collect-Aire bits were pretty horrible. I still think there’s something not quite right with the cockpit opening but at this stage it’s too late to correct! At least the canopy fits really well. I have spent quite a bit of time on the fuselage, cleaning it up, again there have been small fit issues everywhere. The radome is fitted but as can be seen it’s now super thin, it didn’t fit! It was way too big for the fuselage, initially I added a strip of plastic around the fuselage to bulk it up a bit to match the radome, but it didn’t look right. In the end I had to sand back the profile to match the fuselage, now the radome is super thin! Because of issues with the nose wheel well and intake, I had to cut the intake off short, to hide this I’m fitting intake and exhaust covers. These I’ve made up. So they fit nicely I’ve fitted stops in the intake and exhaust to stop them falling inside. The mounts for the elevators were completely wrong so I removed them and replaced with brass tube, the mounting locations in the fuselage were made with aluminium tube. Plus the profile of the tips of the elevators was wrong, so they needed to be reshaped. I’m not sure at the moment how I’m going to replace or fix the tiny airflow vanes on this section yet. All the small bits have been started on, the wheels are done, the air brakes were full of bubbles! The proper drop tanks were badly moulded so I’ve had to modify the other set, but they both have a couple of MONSTER bubbles in them, they haven’t broken/cracked yet! Fingers crossed. The underside is pretty much completed, I’m really just now waiting on the cockpit to be closed up. At least now she looks like a Sabre-Dog. Unfortunately progress will halt for a wee bit, off to Darwin this weekend, away with work next week, but the following weekend I’m on holidays for two weeks so hopefully I can finish her then....maybe! 5 Link to comment Share on other sites More sharing options...
Col. Posted September 26, 2018 Share Posted September 26, 2018 Your update reads as if this kit is more dog than Sabre so well done on keeping at it Rich. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted September 26, 2018 Author Share Posted September 26, 2018 one thing I will say about these Collect-Aire models is that they make you work for it!!! They may appear to be quick basic and simple (yeah I know it's resin) but there's always surprises waiting for you at every step!! There'll be a short recess on the build while I go up to Darwin for a few days. The following weekend I start 2 weeks holidays!!! I'll be taking the wife away to Carins but will sneak in a visit to this place! http://ausarmour.com/museum/ 2 Link to comment Share on other sites More sharing options...
