Shar2 Posted July 15, 2018 Share Posted July 15, 2018 Dornier Do335 and other Gun Barrels 1:32 Master Models The latest batch of items from Master Models included these three sets for 1:32 Do335’s, but can also be used on other aircraft in the same scale. As usual, they are beautifully turned and finished and are so much more realistic than the kit parts. [AM-32-106] – This set is for any German aircraft that used the Mk103 30mm cannon, such as the Do335 and Hs-129. The set includes turned brass barrels with 3D printed muzzle brakes turned brass mounting rings. The set contains two versions of cannon muzzle brakes. [AM-32-107 – This detail set has been designed for the HK Models 1:32 Dornier Do335 and contains turned brass MG-151 gun barrels, FuG 25a antenna and a pitot tube. [AM-32-108 – This detail set has been designed for the HK Models 1:32 Dornier Do335B-2 and contains turned brass MG-151and MK-103 gun barrels with muzzle brakes, FuG 25a antenna and a pitot tube. Conclusion Here we have another group of really useful and well produced items. All the sets are well up to standard we have come to expect from Master Models. All you have to do is a bit of research on what the particular aircraft you are modelling was fitted with and choose the correct set. Review sample courtesy of Piotr at Link to comment Share on other sites More sharing options...
