Sign in to follow this
Shar2
Turned Barrels for Dunkerque and Richelieu Classes 1:350
FN Dunkerque/Strasburg Barrels
1:350 Master Models
Master models continue to build up their range of 1:350 scale armament sets, but they are now increasing the items produced to add other accessories. As usual they are well up to the standard we’ve come to expect from Master Models.
[350-101] - This set is for the Hobbyboss FN Dunkerque and Strasburg kits it includes both main, (330mm), secondary, (130”).  These are all direct replacements for the kit parts, unlike the normal sets in which you just cut off the kit barrels, drill a hole and glue the metal barrels onto the remaining plastic parts, this set also includes resin mounts.  You still need to drill out the resin parts to 1.9mm and 0.9mm respectively, and then you just add to the mounts within the turrets using the kit trunnion.
[350-102] - This set is for the Hobbyboss FN Dunkerque and Strasburg kits, but can also be used on the Richelieu it includes four French training gun 90mm Model 1935.  These are all direct replacements for the kit parts as they include a resin gun mount.  You still need to drill out the resin parts to 0.3mm, and then you just add the barrel to the mounts and fit the recuperator to the top of the gun.
[350-103] - This set is for the Hobbyboss FN Dunkerque and Strasburg kits, but can also be used on the Richelieu it includes four Twin Mount 37mm/50. Once again these are all direct replacements for the kit parts as they include a resin gun mount and etched details, for the seats and sights.  You still need to drill out the resin parts to 0.3mm, and then you add the barrels to the mounts, carefully fold the etched part to shape and glue into place.
[350-104] - This set is for the Hobbyboss FN Dunkerque and Strasburg kits, but can also be used on the Richelieu it includes four French Quad Mount Hotchkiss 13,2mm/76.  As with the other sets these are all direct replacements for the kit parts as they include a resin gun mount and etched details, for the gun controls, mounting and sights.  You still need to drill out the resin parts to 0.3mm, and then you add the barrels to the mounts, carefully fold the etched parts to shape and glue into place.
Conclusion
This is a nice easy way to give your big French battleships that little bit of finesse that makes a nice model look great. The metal barrels are much more to scale than plastic can ever be moulded and the smaller weaponry will look so much better with the added etched parts..
