PT-109 (53215) 1.72
Shar2
PT-109 (53215)
Eduard 1:72
The PT-109 from Revell is getting quite long in the tooth now, even so, it’s nice to see it re-released. It can now also be detailed up with this set from Eduard, the first of at least two according to their website.
PT109: The set comes in the standard poly sleeve and contains parts of the boat, a pre-printed flag and an acetate instrument panel, the weapons details will be in the next set. Included on the sheet are new hatches, which can be posed open, vent openings, which can also be posed open, torpedo tube rails and stops, cleats, machine gun mounting rings and bow hawse pipe. The exhaust silencers are fitted with new control rods, the liferings, new cleats and attachment surround. The skylights receive new grilles, while the deckhouses are fitted with new handrails.  The cockpit is provided with new instrument panels, covers, hand holds, throttle levers, and a new flag locker. The mast gets new supports, while the front cabin roof is given new siren support brackets, handrails and  the torpedo tubes fitted with new rear hatch ends complete with wing nuts. The kit can be finished off with a nicely painted ensign.
Conclusion
As mentioned above, the kit out of the box will make a nice model, but if you want something more, then this set will certainly go toward making a model with more finesse and improved detail.
Review sample courtesy of
