zegeye 947 Posted July 3, 2018 Share Posted July 3, 2018 This is my entry. I don't know if I manage to finish it. I must to finish my B-25 entry first.... But I will try to put here some progress photo from time to time. 5 Link to post Share on other sites
stevehnz 10,446 Posted July 3, 2018 Share Posted July 3, 2018 This kit builds up well, it should give you little trouble. I'll look forward to see your progress. Steve 1 Link to post Share on other sites
amblypygid 2,006 Posted July 3, 2018 Share Posted July 3, 2018 Definitely following (and nice to see I'm not the only Academy builder here!) 1 Link to post Share on other sites
zegeye 947 Posted July 3, 2018 Author Share Posted July 3, 2018 Yes indeed. Although I have four more T-bolt in the stash ( tamiya, hasegawa) I have chosen academy. But this isn't very good model. As you can see I have a lot aftermarkets to use with. I have a quickboost guns for it (which aren't on the picture ) and I need one more.... wheels. This is all you need to make the Academy looks like an allmost good T-bolt. But from the box it should looks like a T-bolt to. It is easier to make Tamiya one, but all this stuff I have bought years ego. So, I plan to use it better than throw it. 2 Link to post Share on other sites
zegeye 947 Posted July 7, 2018 Author Share Posted July 7, 2018 (edited) OK. I've decided what camo will have my T-bolt. If I succeed it will be this one: photo courtesy of saipanbolt (for disscussions only) Edited July 7, 2018 by zegeye 4 Link to post Share on other sites
amblypygid 2,006 Posted July 7, 2018 Share Posted July 7, 2018 Nice choice. Link to post Share on other sites
Tbolt 1,761 Posted July 7, 2018 Share Posted July 7, 2018 Nice to see someone joining me in a 19th FS build Link to post Share on other sites
zegeye 947 Posted July 8, 2018 Author Share Posted July 8, 2018 Painted some parts.... 6 Link to post Share on other sites
Sgt.Squarehead 7,616 Posted July 8, 2018 Share Posted July 8, 2018 We seem to have very similar taste in aircraft kits my friend.....This was the kit I was thinking of building too! 1 Link to post Share on other sites
Tbolt 1,761 Posted July 9, 2018 Share Posted July 9, 2018 If your decals sheet doesn't mention it, there's a chance this aircraft had blue wheel covers ( matching the rest of the blue used ), like quite a few of the 319th FS aircraft at the time. Though from the picture you posted it's hard to say for sure. I'm going with blue caps on "Big Squaw". Link to post Share on other sites
zegeye 947 Posted July 28, 2018 Author Share Posted July 28, 2018 I'm making the space for a resin wheel wells. 3 Link to post Share on other sites
zegeye 947 Posted September 4, 2018 Author Share Posted September 4, 2018 (edited) Nothing special but the resins are in place. Edited September 4, 2018 by zegeye language mistake 4 Link to post Share on other sites
zegeye 947 Posted September 6, 2018 Author Share Posted September 6, 2018 I have a question.... do enybody have a photo of protective fabric on tail weel well of the Thunderbolt? 1 Link to post Share on other sites
Corsairfoxfouruncle 23,430 Posted September 6, 2018 Share Posted September 6, 2018 Hello @zegeye ... This is a drawing out of the Squadron Thunderbolt walkaround book. This is a photo of a restored jug from Pinterest. Thats all i could find. Every other walkaround is missing the boot. Dennis 1 Link to post Share on other sites
zegeye 947 Posted September 7, 2018 Author Share Posted September 7, 2018 OK, thanks. But this is not a fabric cover.... it looks like a metal one. Maybe this is from N version??? I've read in D&S series that should be fabric.... So, maybe someone else have sommething? Link to post Share on other sites
Tbolt 1,761 Posted September 8, 2018 Share Posted September 8, 2018 (edited) I don't recall seeing good picture of the full installation but this drawing from the IPC roughly shows it - item 8 is "installation of pan and boot" The EMI when talking about removing the tail wheel assembly says "remove fabric and metal dust shields which house tail wheel mechanism. These dust shields are attached by means of screws." So it maybe the the fabric part just covers the rear and side vertical section of the tail wheel assembly, with not much being visible from outside. Edited September 8, 2018 by Tbolt 1 Link to post Share on other sites
zegeye 947 Posted September 14, 2018 Author Share Posted September 14, 2018 OK. A little progress here. I put the resin cockpit into the halve of a hull. And reworked the tail weel well. Find the suitable part of metal dust covering from my previus T-bolt N. 1 Link to post Share on other sites
zegeye 947 Posted September 19, 2018 Author Share Posted September 19, 2018 (edited) I've worked a little with the wings. I filled with putty the seam marks on the flaps and rescribed lines. Some putty was needed with resine gun mountings. I also put clear parts to simmulate the lights. I have to fill in an old, and make the new one oppening for pitot tube, cose this is on the wrong wing in the Academy model. I rescribed the position lights. The engine is under construction too. Edited September 19, 2018 by zegeye 3 Link to post Share on other sites
Thom216 3,012 Posted September 20, 2018 Share Posted September 20, 2018 Those wheel bays looks really good. Link to post Share on other sites
zegeye 947 Posted September 22, 2018 Author Share Posted September 22, 2018 (edited) OK, it turns into airplane very well. The engine get the cables. Edited September 22, 2018 by zegeye 3 Link to post Share on other sites
zegeye 947 Posted September 26, 2018 Author Share Posted September 26, 2018 There is some progress. But I doubt I can finish it on time. There is a lot of things to do with this JUG. 4 Link to post Share on other sites
Valkyrie 4,301 Posted September 26, 2018 Share Posted September 26, 2018 Cracking engine Link to post Share on other sites
zegeye 947 Posted September 28, 2018 Author Share Posted September 28, 2018 Today I worked with an engine cowling intake. I try to make it a little better and realistic. It looks for now clumsy but I will smooth it out with a putty and sandpaper... And the airplane neded a little putty to, but not to much. 5 Link to post Share on other sites
stevehnz 10,446 Posted September 29, 2018 Share Posted September 29, 2018 (edited) Good to see some work done on these intakes, the biggest let down in the Academy P-47 kits to my mind. Steve. Edited September 29, 2018 by stevehnz Link to post Share on other sites
Thom216 3,012 Posted September 29, 2018 Share Posted September 29, 2018 Great work on the intake. Looks good! Link to post Share on other sites
