Finally got started on my contribution, the venerable Bristol Bulldog, for some reason I have 3 although a few parts are missing so in reality there's enough to do 2. This one will be largely OOB as I am in respite after my Contrail Botha!
The kits...
Decided to open the blister pack but use the decals from the later boxed version as they are the only ones in usable condition.
Here's what you get..
Noticed the poor pilot is missing a leg and some engine cowl bits have broken off and gone missing so will raid one of the other kits for replacements.
Added a better seat, instrument panel, framing, control column etc to the cockpit, very little of which is seen once closed up.
Closed up and spayed.
The circular block on the lower wing looks at first like a casting mark but does exist on the real thing, there is a corresponding hole in the bottom of the fuselage to take it.
The decals are thick and despite all my best endeavours refuse to sit well. I will replace the roundels with Xtradecal ones and possibly the lettering too. The tail ones are terrible and will be replaced by masking and spraying. I wanted to apply them at the gloss stage so that they don't silver, the fabric areas will be dulled down with matt varnish spray.
All in all I'd say this is a well engineered kit and should go together well...more soon.
I've replaced the upper wing decals with xtradecal which are not as thick as the Airfix ones and work much better. All the fabric areas have ben 'matted' with Humbrol matt varnish, the contrast with the metal areas looks quite good IMHO!
I have taken the plunge with the tail decals of removing them and will paint them on hence the white tail as a first step.
Nice! 👍
This is looking superb and you’ve nailed that lovely chrome /  fabric finish quite nicely. Well done.
Cheers.. Dave
A little more progress.
The engine supplied is nicely detailed and with a black was has lots of detail.
The way the three parts of the engine fit together is excellent and a tribute to Airfix's craftsmanship. The collector ring was painted metallic silver, then washed with a coat of brown/copper and finally a black oil wash.
All for now!
Spotted the finished Bulldog in the Gallery and it looks terrific - rigged and everything! I've missed sharing the completion of the build - are you able to put any more in this build thread? Cheers. Mike
Oh I like that. I think I'll go & dig mine out & count the pieces, just in case, maybe have a small fondle too. :D
St
a job well done! 👍
Ditto the above - smashing job.  I have 4 x 1/48 Gipsy Moths in the stash - don't ask...
...I've still never built a bi-plane - but this is a good inspiration - I must get them out.
Buy a set of micro drills, some fishing line and give it a bash, it’s not so hard! Look forward to seeing your WIP!
ooh I've got all the gear - and no idea - as they say...
I have a couple of projects on the go - but I certainly feel inspired to 'give it a go' soon.  :goodjob:
:wow: If I hadn't known better, I would have said this was 1/48th.  What an excellent result.
Great work Well done
Martin H
