Special Hobby 1/72nd Baltimore,..... FINISHED
Hiya Folks,
                 I have been building Baltimore models over the years and have decided to add another to the collection,...... but I have two choices, both from the Mediterranean Twins decal sheets which I researched for Xtradecal;
1-Baltimore Mk.V FW332/R `Redwing' 13 Sqn Italy 1944
42255078804_f3fe8141dd.jpg4978169-v470a3c531e9-15 by Tony OToole, on Flickr
42255033184_13d9678696_z.jpgX72107_1 by Tony OToole, on Flickr
or,...
2- Baltimore Mk.IIIA FA353/X  69 Sqn or 203 Sqn, Luqa, Malta 1943;
28105134317_082a7d6f87_b.jpgROYAL AIR FORCE OPERATIONS IN MALTA, GIBRALTAR AND THE MEDITERRANEAN, 1939-1945. by Tony OToole, on Flickr
42072113585_f9b39b9f1f.jpgdownload by Tony OToole, on Flickr
Here is the Special Hobby kit;
29100881308_51100df9c0_k.jpgDSCF4283_NEW by Tony OToole, on Flickr
28104590467_86d89cf2cf_k.jpgDSCF4284_NEW by Tony OToole, on Flickr
29100880668_2a6f86e2a8_k.jpgDSCF4285_NEW by Tony OToole, on Flickr
Cheers for now,
                       Tony
Edited by tonyot
Hiya Folks,
              In case anybody is interested,..... here are my Baltimore models;
1/72nd;
Mk.II, 232 Wing;
29101297348_904ea43a0d_k.jpgBaltimore model 4_NEW by Tony OToole, on Flickr
Mk.III, 459 Sqn RAAF;
41163556050_e55f15ff70_k.jpgBaltimore model 5_NEW by Tony OToole, on Flickr
Mk.IIIa,13 Sqn Hellenic Air Force;
29101298038_da08e9f134_k.jpgBaltimore  model 6_NEW by Tony OToole, on Flickr
Mk.V 13 Sqn Royal Hellenic AF, Italy 1943, prior to departing for Greece (this version had a new fin/rudder with a rudder balance at the top, as seen on this model ,....however many units replaced the fin/rudder of their Mk.V`s with the salvaged items from the earlier variants which did not have the balanced tip as the earlier style was more responsive, especially for formation flying);
41163590430_bb5325bbf1_k.jpgDSCF7290 by Tony OToole, on Flickr
Mk.V, GB/-17 `Picardie', Free French AF, Riyak, Syria 1944 (as above re fin/rudder)
29101296498_2bd649e879_k.jpgBaltimore model 8_NEW by Tony OToole, on Flickr
Mk.V, Italian Co- Belligerent AF,Italy 1944 (as above re fin/rudder);
41163556780_9c37cf8169_k.jpgBaltimore  model 7_NEW by Tony OToole, on Flickr
1/48th;
Mk.V, B Flt, 55 Sqn, Italy 1944 (Many units replaced the fin/rudder of their Mk.V`s with the earlier type without the balanced tip as it was more responsive);
41163555610_474f8567cb_k.jpgBaltimore model 1 by Tony OToole, on Flickr
29101296738_b5dba7b35a_k.jpgBaltimore LM58b by Tony OToole, on Flickr
Mk.IV, 728 Naval Air Sqn, Hal Far, Malta, late 1940`s;
29101608178_cf2ca373d1_k.jpgbaltimore rn-2 by Tony OToole, on Flickr
42255374914_3fe3d5dcbd_k.jpgbaltimore rn-3 by Tony OToole, on Flickr
And,.... for 13 Sqn RAF,.... after giving up their Baltimore`s they re equipped with Boston`s in 1944;
28105008997_b312ff17d7_k.jpgDSCF0605 by Tony OToole, on Flickr
          Tony
Edited by tonyot
  • Like 15
Your Baltimore collection is really splendid Tony and, having picked one of these up (relatively) cheap when MPM were having a clearance of the Azur stuff (along with a Sea Otter and a Turbinelight Havoc), I'm interested to see how it goes together.
Edited by Beard
to correct spelling.
Cheers Fella`s and yes Chris,..... they are all Special Hobby/ Azure kits,...... all various boxings of the same basic kit.
Well I`ve started to stick the bits together,.... I`m not really going to town on the interior as very little can be seen,.....here is the cockpit interior;
29117299588_98c0c29098_k.jpgDSCF4335 by Tony OToole, on Flickr
29117299008_324622fd9c_k.jpgDSCF4336 by Tony OToole, on Flickr
And then the wings, tail and engine nacelles;
42271049644_17dbadfdda_k.jpgDSCF4337 by Tony OToole, on Flickr
One thing which has noggled me about the SH kit is the fact that the Martin mid upper turret, which was used on all versions from the Mk.IIIa onwards,... is far too small on this kit. To this end I have decided to use the fuselage section intended for the Mk.III version, with the 4 gun BP turret,.... which actually looks just right for the Martin turret and has the correct bulged sides,..... and then fit the left over Martin turret from a recent Airfix Mitchell model.
Here, you can see the SH kit Martin turret and fuselage section on the right,..... compared to the Airfix Mitchell Martin turret and the fuselage section for the SH kits Mk.III version on the left..... the latter has the correct bulged sides for the Martin turret and has had the inside ledge filed away so that the Airfix Mitchell turret can fit inside;
28121367187_9db4c4d814_k.jpgDSCF4338 by Tony OToole, on Flickr
The Airfix Martin turret from a Mitchell and the SH Baltimore Mk.III fuselage section, all ready to fit;
42088056755_ab7a877516_k.jpgDSCF4339 by Tony OToole, on Flickr
And the turret in place on the completed fuselage,... compare this to the later Baltimore models posted earlier with their incorrect small Martin turrets and photos of the real aircraft;
42271049384_c1b5157729_k.jpgDSCF4340 by Tony OToole, on Flickr
29117297478_78d71adb70_k.jpgDSCF4341 by Tony OToole, on Flickr
I made a wing spar from a section of sprue and then fitted the wings on my tea tray workplace;
28121366257_0f9dce5201_k.jpgDSCF4343 by Tony OToole, on Flickr
28121365737_597f3ea38b_k.jpgDSCF4346 by Tony OToole, on Flickr
So a nice day in front of the telly watching the football and avoiding the sweltering heat outside!!!
          Tony
Edited by tonyot
Glad you like the Baltimore collection folks,... hopefully the latest addition will fit in OK!
Well last night I fitted the engines, intakes etc and got most of the sanding done,...... almost ready for painting now!;
DSCF4357_NEW
I think that I shall be going for R-Redwing in the day bomber scheme,........ and do the Malta based Coastal aircraft some other time.
          Tony
Fill yer boots Paul,...... glad you like it so far mate!
Well after some sanding the canopy and nose glazing was added, the turret test fitted again and ready for some paint;
DSCF4385
          Tony
3 hours ago, Beard said:
That looks like it goes together very well. I'm finding myself rather attracted to the Baltimore rather tempted to dig my Frog one from the stash and give it a go.
Cheers Beard,..... yes it goes together quite well but all of the mating surfaces were sanded flat first before assembly,.... a bit like a vacform kit. The SH kit isn`t a great rendition of the Baltimore, the fuselage is not deep enough nor is the cross section of the forward fuselage correct as it should really nip in towards the top in a triangular shape,..... the Frog kit seems to get some areas correct but is wrong in others, especially the engines and cockpit canopy while the turret seems to replicate the 4 gin BP turret used by the Mk.III, but with 2 x .50 guns,..... I wonder what a mix of parts would produce?
          Tony
Well that sounds like a challenge mate!!!
Back with the model,..... I`ve got the first colour on,.... Dark Earth;
DSCF4421
         Tony
Great collection Tony,good progress too,Iwas toying with the idea of building the re-boxed Frog Maryland but I don't think I'll have the time.
Cheers Steve,.... go on,..you`ll have plenty of time for a Frog Maryland,.... it is a decent kit too!
Right,....I`ve got the first coat of Dark Green camo onto the Baltimore;
DSCF4670
           Tony
Hiya Folks,
                   Still plodding on with this one,....... the upper surface camouflage is done and the undersides are masked off;
DSCF4682_NEW
The Azure Blue is being applied;
DSCF4681
I`ve since finished the undersides and gloss varnished the model this evening, ready for the decals soon
         Tony
I thought you'd found a photograph to support a Baltimore with undersides that are partly Dark Earth, then I realised it was an 'in progress' shot.
Your work here isn't helping with my desire to do one for this GB but, luckily, I'm not in a position to do any modelling for the next week or so.
I`m sure you`ll find time,..... no I was just part way through painting the undersides.
Here is the model after being varnished, with the decals in place;
DSCF4690
            Tony
No chance, my wife is taking me to Wales for 10 days... I'm several hundred miles from my stash.
On the upside, I'll be visiting the Welsh Spitfire.
PS. The Baltimore is looking lovely.
Edited by Beard
Have a nice time and cheers,..... hope the weather behaves itself!
6 hours ago, Franz75 said:
Wow, I'm looking for Baltimore but it is hard to come by. 😪  And ridiculously over priced.  Very nice job Tony.
Thanks Franz,..... it is one of my favourite aircraft types,..... so I bought a few in and always snap them up if I find them cheap at a model show.....I got this one for £3!!!
           Tony
