Harrier T.4/T.8 BigEd Set (BIG49192 for Kinetic) 1:48
Harrier T.4/T.8 BigEd Set (BIG49192)
1:48 Eduard BigEd
In case you're unaware, Eduard's Big ED sets are a great way to purchase all the sets you want for your model whilst availing yourself of a bulk purchase discount that can be quite tempting.  The set arrives in a large cardboard envelope with the Big ED branding and a sticker in the top left that details what's inside.  Within the envelope the sets are all still individually packaged to protect the frets from shuffling past each other and getting damaged until you're ready to use them.
This set contains four previously release sets, which you can buy at a discounted value in this format.
Exterior (48945)
This larger bare brass set contains some important upgrades, such as new heat-shields for the aft nozzles, with scrap diagrams showing how they should be fluted with a biro and arranged; an interior surface skin for the air-brake bay; an upgrade to the detail in the bicycle landing gear and the wingtip out-rigger wheels, along with some bay enhancements and replacement bay doors, while others are detailed rather than replaced.  New in-scale vortex generators are supplied for the upper wing surface, along with a set of templates that ensure accurate placement, but keep that glue on the frugal side, or you'll have a permanent jig!  Lastly, there are pylon mating surface skins for if you're not arming your Harrier.
Interior (49882)
Two frets are included, one nickel plated and pre-painted, the other in bare brass.  A complete set of new layered instrument panels and side consoles are the primary parts on the painted set, with new rudder pedals; ejection seat details; sidewall details; coaming instrumentation and some canopy internal structure are also supplied.
Masks Tface (EX576)
Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with everything above, but also give you another set of canopy masks tailored to fit the interior of the glazing so that you can paint the interior and give your model that extra bit of realism.  There are two centre panes to the windscreen on both sides of the pane, due to there being a choice of parts between variants in the kit.  I guess Tface stands for Two Face or something similar?
Seatbelts STEEL (FE883)
In case you don't already know, these belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting.  Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE.  As well as the two sets of crew belts, you also get a set of the pull-handles over the pilot and co-pilot's heads that gets them out of there in case of an emergency.
Review sample courtesy of
