airfixpeter Posted June 4, 2018 Posted June 4, 2018 I found this one lurking in the bottom of the stash and judging by the state of the mould seems and the amount of flash I won't be a quick build. And there won't ejector seats, revolving number plates , machine guns etc etc. 5
airfixpeter Posted June 6, 2018 Author Posted June 6, 2018 Time for a start it's only the wheels for the moment I can't get the proper wire wheels look as it's beyond my skills so it will have to remain as they are. Starting with the untouched wheel with all the flash. And then the cleaned up and finally the painted and finished. Only another three to go 5
airfixpeter Posted June 7, 2018 Author Posted June 7, 2018 Some more work done this time it's the mould seems on the body it mainly on the front wings and just near the rear windows and a bit of body work straighting to do as well 4
Rabbit Leader Posted June 8, 2018 Posted June 8, 2018 Nice seeing this classic Aston as part of the GB mix. Those wheels look a treat and I sympathise with you having to repeat the process another three times. Best to look on the bright side though - it's not a multi- wheeled big rig now is it!! From what I can tell, those moulds look like they've seen better days, so I hope it all lines up well for you as you progress along. Cheers.. Dave 2
airfixpeter Posted June 8, 2018 Author Posted June 8, 2018 Finally got some colour on the body and I didn't want to go with the silver so I have gone with the nearest green to one of the original colours witch is a metallic green. the pics go from under coat,top coat and then gloss coat 3
BIG X Posted June 8, 2018 Posted June 8, 2018 Interesting colour choice - should make for a very striking build 1
airfixpeter Posted June 9, 2018 Author Posted June 9, 2018 Started on the chassis today and had some cleaning up of the suspension and transmission components to do and the started to install them. 1
CliffB Posted June 10, 2018 Posted June 10, 2018 What a great choice Peter and looking very striking in metallic green . Re. the wire wheels. Is the silver paint acrylic? If so, you could overpaint using matt black enamel. As soon as it's dry, then gently wipe over the surface using a cotton wool bud that has been dampened with enamel thinner. That will remove the black from the top surface of the wires. It's how I brought out the silver detail on these Alpine wheels. It's pretty foolproof (famous last words), as long as the buds aren't too wet and you change them regularly. Cheers Cliff 3
airfixpeter Posted June 10, 2018 Author Posted June 10, 2018 7 hours ago, CliffB said: What a great choice Peter and looking very striking in metallic green . Re. the wire wheels. Is the silver paint acrylic? If so, you could overpaint using matt black enamel. As soon as it's dry, then gently wipe over the surface using a cotton wool bud that has been dampened with enamel thinner. That will remove the black from the top surface of the wires. It's how I brought out the silver detail on these Alpine wheels. It's pretty foolproof (famous last words), as long as the buds aren't too wet and you change them regularly. Cheers Cliff Thanks for the tip I was going down that route but I felt that the detail was so shallow that I wouldn't have really worked.
airfixpeter Posted June 10, 2018 Author Posted June 10, 2018 And here's the final pics before the final put together so far it's not given me many problems 6
Rabbit Leader Posted June 10, 2018 Posted June 10, 2018 Great work Peter. You’ve done a fine job putting this one together. if I was ever fortunate enough to wake up one morning and be asked “What colour should we spray your restored DB Mr. Rabbit Leader?” I’d be hard pressed to look past a metallic green like your fantastic kit!! Cheers and nice gallery entry.. Dave 1
CliffB Posted June 11, 2018 Posted June 11, 2018 It's nice to see the first vehicle in the Gallery Peter 2
