Lawzer 2,739 Posted September 14, 2018 Share Posted September 14, 2018 22 hours ago, MarkSH said: Ha Ha! God no, have you seen the size of the box? let alone the model...if I came home with that my life wouldn't be worth living. The 1/24th Hurricane I've got is bad enough and even I don't know where I'm going to put that when its finished!! I mean you coul easily mistake that for a 1/24 - lovely work! 1 1 Link to post Share on other sites
MarkSH 5,924 Posted September 14, 2018 Author Share Posted September 14, 2018 Evening all, Completed some of the touch ups on the Mossie plus a couple of coats of Klear. I've now got her on her pins as a I need to make a start on the crew access ladder and need a working height to make it fit correctly. Somehow the geometry isn't quite right and I have a slight list to port with a wing tip height of the deck difference of about 5 mm not much I can do about it now. As @Lawzer suggested the undercarriage was jus a drop fit and was glued in situ so at least that bit was easy. The access hatch test fitted, but I forgot to spray it so some further painting required. Looking at her sitting with the cowling on the floor (cutting mat) I think I need some step ladders to go by the port nacelle. Plenty of time..... Cheers, Mark. 7 Link to post Share on other sites
MarkSH 5,924 Posted September 15, 2018 Author Share Posted September 15, 2018 Hi all, Made a start on the crew access ladder, very fiddly but we enjoy a challenge don't we? As I now have a specific height to work with, I cut some 0.4 mm brass tube at the full length (46 mm x2) and cut lengths of 0.6, 0.8 and 1.0 mm tubing each minus a 1/4, 1/2 and 3/4 of the total length respectively to form the telescopic assembly. each of the tubes was glued to the next except the thinnest which was left free to allow for some minor height adjustment as obviously the Mossie sits at quite an angle. Unfortunately one of the telescopic lengths shifted whilst the cyano was drying and is now locked solid so its slightly off. the individual lengths are slightly over scale but are close enough I think. I made the ladder base from plastic which also helped to set the width of the ladder. On the first rung..... and a test fit, the top rung and securing hook/s need to be added. Not perfect but once its painted up should add a further bit of interest More later, cheers, Mark. 7 Link to post Share on other sites
TonyW 10,060 Posted September 15, 2018 Share Posted September 15, 2018 That's a very nice detail. The whole model is coming together beautifully. 1 1 Link to post Share on other sites
Blitz23 1,066 Posted September 15, 2018 Share Posted September 15, 2018 Looks great Mark 1 1 Link to post Share on other sites
Rabbit Leader 12,331 Posted September 15, 2018 Share Posted September 15, 2018 This is really turning out wonderfully well Mark. All the extra details are superb and as for those painted rings around the nose and spinners - well that’s just surgeons work! This will be one of the best builds I’ve seen of this kit - well since Lawzer’s one I suppose. Cheers.. Dave 2 1 Link to post Share on other sites
Lawzer 2,739 Posted September 18, 2018 Share Posted September 18, 2018 On 15/09/2018 at 23:08, Rabbit Leader said: This is really turning out wonderfully well Mark. All the extra details are superb and as for those painted rings around the nose and spinners - well that’s just surgeons work! This will be one of the best builds I’ve seen of this kits - well since Lawzer’s one I suppose. Cheers.. Dave Naaaaa - mines is now hiding at the back of the hanger! 1 Link to post Share on other sites
MarkSH 5,924 Posted September 19, 2018 Author Share Posted September 19, 2018 Evening everyone, Not a lot of bench time over the last couple of days but I have managed to get a couple of coats of Klear on the Mossie and the MRCA. I am in the process of applying the decals to the Mosquito with the upper markings nearly complete. Just a quick shot of progress with the Trolley Accumulator for scale and also the start of a set of Step ladders. I have also drilled out the gun camera port which I hadn't noticed wasn't there. and also added the windscreen wiper. My home print decals are OK but they will require a little bit of touching up around the edges to disguise them a bit better. More later, Cheers, Mark. 8 Link to post Share on other sites
Lawzer 2,739 Posted September 20, 2018 Share Posted September 20, 2018 wowsers!! Link to post Share on other sites
TonyW 10,060 Posted September 21, 2018 Share Posted September 21, 2018 Very nice. The spinners make it for me, there's a touch of Reno air racer creeping in there. Tony. 2 Link to post Share on other sites
MarkSH 5,924 Posted September 23, 2018 Author Share Posted September 23, 2018 Evening all, As well as the MRCA display base I've started to make a suitable base which will work for a few 1/48th models. I've also completed the set of maintenance step ladders for the display. Cheers, mark. 10 Link to post Share on other sites
Mancunian airman 2,798 Posted September 23, 2018 Share Posted September 23, 2018 Those ladders look a bit nice, what paint/varnish did you use ??? 1 Link to post Share on other sites
MarkSH 5,924 Posted September 24, 2018 Author Share Posted September 24, 2018 7 hours ago, Mancunian airman said: Those ladders look a bit nice, what paint/varnish did you use ??? Thanks, the ladders are undercoated with Tamiya wooden deck tan and then painted with burnt umber and sienna oil paints and then dragged with a coarse brush to get the wood grain.....it takes an age to dry! 2 Link to post Share on other sites
Rabbit Leader 12,331 Posted September 24, 2018 Share Posted September 24, 2018 This and your Tonka thread both look amazing each time you update them. So much to like here and this Mossie looks so good. That’s the best ladder I’ve ever seen - great painting! Cheers. Dave 2 1 Link to post Share on other sites
Ventora3300 3,706 Posted September 24, 2018 Share Posted September 24, 2018 8 hours ago, MarkSH said: Thanks, the ladders are undercoated with Tamiya wooden deck tan and then painted with burnt umber and sienna oil paints and then dragged with a coarse brush to get the wood grain.....it takes an age to dry! ....and where did the tools come from? Did you scratch-build them or pinch them from somewhere? 1 Link to post Share on other sites
MarkSH 5,924 Posted September 24, 2018 Author Share Posted September 24, 2018 The tools were scratched from scraps. 2 Link to post Share on other sites
nimrod54 12,530 Posted September 24, 2018 Share Posted September 24, 2018 Fantastic work on the ladders and tools Mark. I really like this Airfix nostalgia GB, people are going that extra mile to improve/display their models. 2 2 Link to post Share on other sites
MarkSH 5,924 Posted September 30, 2018 Author Share Posted September 30, 2018 Evening all, With the deadline met for the P-47 STGB I was able to crack on with the Mossie decals and apply a couple of coats of Klear ready for some weathering later this week: Not much on the underside.... In general the decals worked alright, one or two minor colour bleeds and as I mentioned before, some did require touching up at the edges where I had used a sympathetic outline colour to match the underlying paintwork. Overall though when some weathering is applied it should, fingers crossed, all blend in. Cheers, Mark. 6 Link to post Share on other sites
Lawzer 2,739 Posted October 1, 2018 Share Posted October 1, 2018 looking very smart indeed!!!! 1 Link to post Share on other sites
MarkSH 5,924 Posted October 1, 2018 Author Share Posted October 1, 2018 Hello everyone, Back again and the Mossie is starting to gain some character and looking a lot more subdued and weather beaten then yesterday. It was always my intention to have her looking like a well worn, hard working aircraft so it was on with an oil dot filter and an immediate application of Tamiya weathering powder into the still wet oil paint a bit like a wet in wet technique. Here I have applied dots of Yellow Ochre, Titanium White and Ultramarine which is blended in using a soft flat brush. For the ventral staining I used Payne's Grey. I have a good image of an FB variant with a particularly heavily stained belly so I might apply a bit more. You can see that I have put the oil colour on some card which helps to leach out the oil medium so the pigment dries a little quicker, however the real advantage of this is that it is slow drying and can be adjusted or removed. The top side has been treated the same way as the underside, but here I have applied the Tamiya weathering powder to joins, access panels and areas of wear and handling. Cheers, Mark. 6 Link to post Share on other sites
Rabbit Leader 12,331 Posted October 1, 2018 Share Posted October 1, 2018 Some great weathering tips there Mark, I appreciate the photos and explanatory text. Certainly one area I feel I’m way behind the eight ball. This Mossie keeps impressing me with each and every update. She’ll be a keeper when finished that’s for sure. Cheers.. Dave 3 Link to post Share on other sites
MarkSH 5,924 Posted October 11, 2018 Author Share Posted October 11, 2018 Evening all, The Mosquito is finally finished I took a quick photo this evening but I done run out of daylight! so I'll get some better piccies for the gallery at the weekend. Really enjoyed making this kit, it very much is a blank canvas on which to add your own take on the aircraft, great GB, superbly organized by @Rabbit Leader very well done and thanks. I've really got to get some suitable figures for these vignettes, I was trying to think of an appropriate title for it and the usual sort of stuff came to mind 'Mossie Maintenance' etc but I then thought how about having some 'erk disappearing into the crew hatch and another on the step ladder and call it (to be said in the best possible West country accent) 'ere Blanco where's me free ates'. As I said more pictures at the weekend. Cheers, Mark. 6 1 Link to post Share on other sites
Lawzer 2,739 Posted October 11, 2018 Share Posted October 11, 2018 That really is a top notch result mark! Superb work fella! 1 1 Link to post Share on other sites
Rabbit Leader 12,331 Posted October 11, 2018 Share Posted October 11, 2018 As expected Mark, this has resulted in another supreme build, well done. Now you don’t often see Type C1 upperwing roundels on Mossie kits, so full marks for going that way. Can’t wait to see the glamour shots in the Gallery. Now I must correct you on the GB ‘organisation’ part. Although I’ve been updating this whole show as it’s progressed, the ‘real’ organisers have been the two tiresome official hosts - Ian @Lawzer and Mike @Ventora3300. Without these two chaps none of this fun would have happened, I just tagged along for the long ride. Thanks all the same and to be truthful all members who have contributed here really need a great big pat on the back (a free Airfix Vintage Classic kit wouldn’t go astray either??). Cheers and very well modelled.. Dave 3 Link to post Share on other sites
MarkSH 5,924 Posted October 11, 2018 Author Share Posted October 11, 2018 @Rabbit Leader, @Lawzer and @Ventora3300 I stand suitably corrected and apologise for the oversight and once again reiterate my admiration for all of those who take on GB organisation period! I must address the situation and volunteer myself for co-host duties if a subject about which I have enough knowledge to merit my involvement appears. Cheers, Mark. 3 Link to post Share on other sites
