US MD3 Generator. 1:32
US MD3 Generator
Videoaviation 1:32
The latest 1:32 release from Videoaviation is of a MD3 Generator set.  The set comes in a sturdy cardboard box with a picture of the unit on top.  Inside there is quite a lot of cream coloured resin contained in either bubblewrap or ziplock bags. The mouldings are very nicely produced with very little flash and minimal webbing/attachments connecting the parts to the moulding blocks. There are twenty one parts all told, not including all the pipework which is included as uncut lengths.  Construction begins with the fitting of the leaf spring suspension units to the rear of the generator body, followed by the two, two piece rear wheels. The front axle mount and fuel tank are then added, after which the front pair of two piece wheels are fitted to the axle and the whole assembly fitted into the mount hole. The towing arm can be posed in either folded or extended position. The different length cables are each fitted with plugs, before being coiled up and placed on the roof.  Of course, you can also use the cables in a diorama setting attached to your particular aircraft. Decals are included for all the stencils and warning signs/markings for the unit, including the white edge markings. The modeller can paint this unit in two different colours depending on where they’re used, Yellow, or Green overall.
Conclusion
This is another great little kit from Videoaviation. Not too difficult to build, but could be fun to weather it a bit, not too much mind, and will make a super addition to any diorama next to and possibly attached to a suitable aircraft.
Review sample courtesy of
