Sign in to follow this
Shar2
HMS Belfast. 1:350
HMS Belfast
Eduard 1:350
The Trumpeter 1:350 HMS Belfast has been out some time now, in fact it was released in 2013, although rather late to the party, Eduard have now decided to release two sets of etched brass to detail the model. The two sets arrived in zip lock bags with the yellow card inserts. They are well up to the usual standard and provide a tremendous amount of extra, as well as replacement detail parts.
Detail set- (53-210) comes on two sheets of relief etched brass and also includes a small sheet of acetate for the bridge windscreen.  The sheets contains a myriad of parts such as watertight doors which can be posed open or closed, cable reels, for which the modeller will need to provide plastic rod for the reels themselves, flag lockers, replacement single and twin 20mm Oelikons, 20mm splinter shields, complete new mountings for the 2pdr Pom Poms along with replacement ammunition racks and even the ammunition belts.  There are also replacement aerials for the Type 282 Yagi radar arrays and new mounts for fitting to the AA director mountings.  The bridge receives a new shields, wind deflectors, ADF aerial and platform, while the searchlights are fitted with new mountings.  The catapult is completely replaced with PE, as are the Type 279 radar arrays on the mast tops and the Type 284 aerials and their mountings.
The detail continues with the 4” mounts being provided with new shields while the Type 271 radar in its distinctive lantern is completely replaced, as is the whole tower structure it sits on. The main directors are fitted with new Type 274 radar arrays, as well as new doors, hatches, and access ladders. The ships prominent platforms and supports on each side are replaced. The large, cranes for the aircraft and boats are also completely replaced with PE, including the, jibs, cables, hooks, all the mechanics and workings, in fact there is too much to mention, but each crane is made up from 30 parts. All the cradles for the ships boats will need to be removed, before being replaced with PE parts. The boats themselves are given new thwarts, gratings, gunwhales and oars where required. The motor boats also have new cabin tops, windscreens, rudders and propellers.
Railings (53-211). With the title of this fret being so very descriptive, it’s not difficult to see that this provides ships railings which cover all sections of the ship from the main deck upwards, including the turret tops. There is a selection of three bar and two bar rails the majority of which are shaped to fit their specific positions.  Also included in the set is a pair of accommodation ladders and platforms, deck extension beams for the ships boats, all the splinter shields around the 4” gun deck. The Carley floats get new inserts which represent the wooden tread boards. The funnels are provided with internal structures, unfortunately the funnels aren’t the correct size so they may not fit any replacements. The flat, plates you can see in the accompanying photograph are the main turret tops. The turrets also receive new ladders, surrounds for each main gun, and access doors.  Each mast is fitted with new yardarms, although they are a little flat for the purpose, ladders, platforms, gaffs, and support frames. The Walrus also gets the Eduard attention and is fitted with a complete set of replacement struts, propeller, catapult cradle, transport cradle which is fitted with a turntable.
Conclusion
It’s about time Eduard did something for the poor old Belfast, they aren’t usually this slow out of the block. The Trumpeter kit of the Belfast is very nice out of the box, but with these two sets you could dramatically improve the finished model.  There are so many parts that you will need quite a bit of patience and care to fit them all, as with any etch set, but the results will be worth it.
