Sign in to follow this
Shar2
German Schnellboot S-38. 1:35
Eduard 1:35
It was great to see the release by Italeri of the 1:35 S-38 Schnellboot, adding to their impressive array of 1:35 scale MTB’s.  The kit itself is very nice, but there is always room for improvement, and Eduard have a lot of experience in giving us modellers the sort of detail sets that will help do this. The three sets reviewed here are perfect for the task in hand, although I’m sure there is a lot more that can be added to the model, and not just in etched brass.
53212 – Schnellboot: Comes in a zip lock bag with a large sheet of etched brass and a small pre-painted sheet of etched steel.  The brass sheet contains many new and replacement parts for the torpedo tubes both internally and externally, a new door and other fittings for the bow mounted 20mm cannon, plus a host of deck fittings such as gratings, hatch fittings and 48 stanchion plates. There are also new foot plates, brackets for the boot hook, skylight surrounds, ventilator grilles, plus foot pedals, sights and other fittings for the 40mm Bofors.
Within the wheelhouse there are new fittings for the ships wheel, compass rose and surrounds for the two binnacles, and grille for the aldis lamp. All the dials and instrumentation are replaced with the well printed items on the etched steel sheet.  For those modellers who wish to build a pre-war version with the 20mm cannon on the stern, then there are parts include for this weapon too.
53213 – Flag: This set is very simple in that it just contains are large pre-printed German flag.  The flag comes complete with eyes top and bottom for you to add your favourite rigging line. If you don’t like to build your models with the swastika then you might not like to use this on your model.
53214 – Hatches: Also comes in a zip lock bag with one sheet of etched brass and a pre-cut acetate sheet.  The sheet contains complete replacements for all the deck hatches.  Each hatch is made of the hatch surrounds, the hatch itself with an acetate backing representing the glass, hinges, handles, clasps, and outside cover.
Conclusion
As mentioned above, the kit out of the box will make a nice model, but if you want something more, then these sets will certainly go toward making a model with more finesse and improved detail.  Some modellers may want to go further, but for those with a limited budget you can’t go far wrong with these sets.
Rieview courtesy of
