Shar2 Posted May 21, 2018 Share Posted May 21, 2018 Soviet T-34/85 ICM 1:35 History The T-34 was and remains a legend. It is not only the most produced tank of the WWII-era, with 84,000 built (compared to the 48,966 Shermans of all versions) but also one of the longest-serving tanks ever built. Many are still stored in depots in Asia and Africa, and some served actively during the 90’s (such as during the 1991-99 Yugoslavian war). They formed the backbone of countless armoured forces around the globe from the fifties to the eighties. The basic design was drawn for the first time in 1938 with the A-32, in turn partially derived from the BT-7M, a late evolution of the US-born Christie tank. The T-34/85 came about after it was recognised that there was a need to increase the firepower of the T-34/76 following the Battle of Kursk in 1943. While the hull stayed the same, a new turret was designed and was to be originally fitted with a derivative of the M1939 air defence gun. This gun wasn’t chosen to be produced en masse, that honour went to the ZIS-S-53 which armed the 11,800 tanks produced between 1944 and 1945. The Model The model arrives in a strong box with a separate top sleeve with a nice artist’s representation of the tank and riders on the front. Inside, within a large poly bag, are five sprues and two hull parts of green styrene and, four lengths of tracks, a small sprue of clear styrene, and a smallish decal sheet. On initial inspection the parts are really well moulded, clean, with no sign of flash. There are a number of moulding pips, some of which are on quite fragile looking parts, so care should be taken when removing. The sprue gates attaching some items like are also quite heavy and I can see these parts breaking if not careful. The build begins with the fitting of the engine cover onto the rear decking, and the bow machine gun, armoured tear drop, mantle and ball. The two intake covers are then assembled and also fitted to the rear deck. The two piece bow mounted machine gun is then assembled and slide into the ball of the mounting, being glued such that it is still moveable, whilst there are four plates that are fitted to the underside of the rear decking. The drivers hatch is made up form four parts before being glued into position. Back aft, the rear bulkhead is attached, followed by the radiator cover. Inside the lower hull section the eight suspension boxes are fitted, four per side as are the two driver’s control sticks, whilst the rear mudguards are fitted to the rear. On the outside the driver gearbox covers are fitted, as are the five axles on their torsion beam suspension arms and the idler axles. The drivers are machine gunners seats, each made from six parts are glued in their appropriate positions and the two hull halves joined together. Each of the idler wheels, drive sprockets and road wheels are made from two parts before being fitted to their respective axles. The four towing hooks are then attached, two at the front and two aft. The upper hull is then fitted out with grab handles, stowage beams and a couple of smaller hooks. Each of the two halves of rubber track lengths are joined together and slide of the wheels. While there isn’t really any interior, ICM have allowed for the fact that some modellers like to have the hatches open, to that effect there is some semblance of interior parts. The main gun breech is made up form thirteen parts, and although relatively simple, does look quite effective. On the outside of the turret the mantlet and fixed section of the mantlet cover are fitted, the breech assembly is then glued to the mantlet from the inside and the lower turret, including the turret ring is glued into place. The moving section of the mantlet cover is then attached, along with the machine gun muzzle. The three piece mantlet extension and three piece main gun is then fitted, along with the four piece cupola, gunners hatch, grab handles, ventilator dome, viewing block and top armour plate for the mantlet. There are more stowage bars, periscope sights, lifting eyes and viewing blocks fitted to the turret before the whole assembly si fitted to the upper hull. Final assembly includes the four, four piece fuel drums, each with two cradles, spare track links, stowage boxes and aerial base. There is a four piece folded tarpaulin, (in place of one of the fuel drums), another stowage box, two more track links headlight, horn, two towing cables and a large saw attached before the model can be declares complete. Decals The decal sheet provides four options for tanks that each served in 1945. All of the tanks are in all over green, each with tank ID numbers and unit markings. The choices are:- A T-34/85, 7th Guards Tank Corps, Germany, Spring 1945 A T-34/85, 7th Guards Mechanised Corps, Germany, Spring 1945 A T-34/85, 4th Guard Tank Army, Germany, Spring 1945 A T-34/85, of an undesignated unit, from the Spring 1945 Conclusion This is another fine kit from ICM. Although not the most complicated of tank kits, it does look the part and would make a nice, relaxing weekend build. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
