Shar2 Posted May 20, 2018 Share Posted May 20, 2018 Tiran 4 Late Type MiniArt 1:35 The meaning of Tiran [pronounced as Tiy-RAE-N] in Hebrew is beginner. Israel's chronic lack of AFV's on one hand and it's phenomenal victory in the 1967 Six Days War on the other, brought the IDF to adopt captured enemy vehicles for its use. The Arab armies lost hundreds of fighting vehicles - mostly Egyptian T-54 and T-55 MBT's which were abandoned by their crews. In order to allow for greater standardization in its armour corps, the IDF initiated a conversion program. The captured tanks were re-engined and re-gunned (with the standard 105mm gun used in the Centurion and Patton MBT's). Chief was the several hundred captured T-54/T-55 tanks that were taken and modified into the Tiran 4 (T-54) and Tiran 5 (T-55). The main difference between the two versions is the main gun armament. The Tiran 4 was armed with the original 100 mm main gun and the Tiran 5 was fitted with a 105 mm main gun, although the 105mm was also fitted to late Tiran 4’s. The Model Since this is an upgrade of the earlier T-54 kits there are a lot of similarities but quite a few new parts as well. As with MiniArt kits with interiors there are a lot of sprues, eighty five in this case, of grey styrene, plus three of clear, one sheet of etched brass and a smallish decal sheet. The box, deeper than a standard tank kit box has a nice painting of the tank on the front. On opening you are greeted by a mass of sprues, many of them quite small because of the tooling's modular nature, with quite a few parts going unused for this boxing. The mass of sprues fill up just about all the space in the box, leaving only room for air between the sprues, anyone wishing to just take a look at the sprues and getting them out of their bags will realise that getting all this back in the box is one of life’s little challenges! Construction is almost identical to the earlier releases, complete with the full engine, which is a beautiful model in its own right, and consisting of forty two parts if you include the engine mounting cradle. The lower hull is then fitted out with a multitude of parts that include the torsion beam suspension, multi part axles, gearbox covers, and interior escape hatch plus PE beam covers. The interior is then built up from the fighting compartment floor and includes all the pipe work, seats fire bottles, steering mechanism and internal bulkheads. The interior and exterior of the sidewalls are also covered with detail, including the large racks of shells for the main gun, with additional shells stored around the fighting compartment. The detailed sidewalls are then glued into place, as is the engine assembly, engine compartment firewall and other ancillary equipment. The upper glacis plate is then fitted as are the three piece road wheels, drive sprocket and idlers. The turret ring assembly is the attached, followed by the rear bulkhead, each fitted with more detail parts. The engine deck is then built up and the separate hatches are able to be posed open or closed as per the modellers’ wishes. The deck is topped off with PE grilles in their frames and the large hinge for the main hatch. Another slight difference with the T-54 is the large grille on the rear bulkhead and the additional stowage bin that across the whole width of the hull. The tracks are of individual link type, with ninety links per side, and it will be a case of assembling it like a link and length style, gluing each link together before draping them over the road wheels. The fenders are fitted with stowage boxes, fuel tanks and spare track links plus front and rear mudguards before being glued into position. The two fuel drums mounted to the rear of the tank are assembled and glued into their mounting frames plus the pipework for the fender fuel tanks. The turret is another new moulding, which has even more equipment in it than the earlier versions, due to the improved technology. The turret appears to be where the main changes were made. As with the other kits the turret interior includes the full main gun breech, this time for a 105mm gun, rather than the old 100mm, radios, training motors, seats, hand cranks, and other equipment, but with additional sighting equipment for the main gun, and more spare ammunition boxes for the co-axial Browning 30 cal machine gun. Ready use shells are added to the inside of the upper turret along with a multitude of brackets and clamps. The turret roof comes complete with all the periscopes and hatch details for the commander and gunner positions, two highly detailed Browning 30 cal machine guns, consisting of fifteen parts, one for the commander and one for the gunner. There is also a twenty three piece Browning 50 cal heavy machine gun that is mounted onto the mantlet. Two five piece aerials are affixed to the rear of the turret, along with a large stowage bin; while on the sides are a pair of Jerry cans and their respective cradles. On the right hand side there is another large stowage bin, made up from ten parts. The single piece main barrel is glued into the breech, and fitted with a choice of two mantlet covers. There a many more grab handles fitted to the outside of the turret on this version, not to mention brackets and clamps. The turret assembly is then fitted to the hull, completing the build. Decals The decal sheet gives the modeller four options. The decals are beautifully printed, are clear and in good register with a slightly matt finish. The options are:- Tiran 4 of the Israeli Defence Force for eh 1970’s Tiran 4 of the Israeli Defence Force Training Unit for the Lebanese Army, Negev Desert early 1980’s Tiran 4 of the South Lebanese Army, Used on Operation @Peace For Galilee”, June to September 1982 Tiran 4 of the South Lebanese Army from the 1980’s Conclusion Ok, it’s essentially another T-54, with additional equipment and a different gun, but you can never have enough T-54/55’s. These kits are really coming thick and fast MiniArt’s moulding machines must be going full chat day and night. There is so much detail that it could overwhelm a modeller unless their mojo was really cranked up. But if you break the build into bite sized pieces as sub-assemblies, painting as you go, there shouldn’t be a problem. Not one for beginners or maybe even intermediate modellers, but there are versions being released, without interior, which would perhaps be more suited to their level to gain experience before tackling a full interior build. As bang for your buck goes, these have to be some of the best value kits around these days. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
Rodders154 Posted May 21, 2018 Share Posted May 21, 2018 A lifetimes work Seriously it will take a much better moddeler than me to build this but boy would I love to be able to Rodders Link to comment Share on other sites More sharing options...
Bullbasket Posted May 21, 2018 Share Posted May 21, 2018 I'm setting myself up here to be shot down again, but although this is a Tiran 4, it doesn't have the 105mm gun. I believe that it's the Russian 100mm with the fume extractor at the end of the barrel. Over the weekend at the Saumur show, I picked up Miniart's Tiran 4SH Early Version, which is the version with the M68 105mm gun. The decal sheet contains markings for four IDF tanks and the kit comes with a full interior. To illustrate just how much plastic is contained in the box, I have Takom's Tiran 4 kit which tips the scales at 713 grams, and admittedly there is no interior with it. The Miniart kit however weighs in at just over 1350 grams, almost twice as heavy. This certainly not a weekend build. John. Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted June 22, 2018 Share Posted June 22, 2018 On 5/20/2018 at 5:36 PM, Shar2 said: The Tiran 4 was armed with the original 100 mm main gun and the Tiran 5 was fitted with a 105 mm main gun, although the 105mm was also fitted to late Tiran 4’s, the subject of this kit. My understanding is similar, I thought the Tiran 4 was T-54 based, known as a Tiran 4SH if upgraded. The Tiran 5 was T-55 based, known as Tiran 5SH if upgraded. Finally there was the T-62 based Tiran-6, don't believe these were upgraded, but I stand to be corrected on this. Link to comment Share on other sites More sharing options...
Bullbasket Posted June 22, 2018 Share Posted June 22, 2018 41 minutes ago, Sgt.Squarehead said: On 20/05/2018 at 17:36, Shar2 said: The Tiran 4 was armed with the original 100 mm main gun and the Tiran 5 was fitted with a 105 mm main gun, although the 105mm was also fitted to late Tiran 4’s, the subject of this kit. My understanding is similar, I thought the Tiran 4 was T-54 based, known as a Tiran 4SH if upgraded. The Tiran 5 was T-55 based, known as Tiran 5SH if upgraded. Finally there was the T-62 based Tiran-6, don't believe these were upgraded, but I stand to be corrected on this. Morning Sgt. I got my info from a couple of sites and my understanding of the designations is this. T-54's and T-55's, unmodified were designated as Tiran 1&2. Modifications were made to both tanks such as additional stowage boxes and jerry cans, front fenders replaced with rubber ones and the loaders hatch replaced. These were Tiran 4&5. Later mods included engine replacement and 100mm gun replaced with the 105mm (whether it was M68 or L7, not sure). These were the Tiran 4SH and Tiran 5SH. The Russian 100mm had the fume extractor at the end of the barrel, whereas the 105mm had it midway. That's what led me to say that the kit is armed with the 100mm and that's how it's depicted on the box art. Looking at the sprues, I can't see a 105mm gun in there (I could be wrong). John. Link to comment Share on other sites More sharing options...
Shar2 Posted June 22, 2018 Author Share Posted June 22, 2018 So, you guys are picking me up on a bit of the history I found on several sites.i haven't said at any point that this gun was in the kit. 😋 Link to comment Share on other sites More sharing options...
Bullbasket Posted June 22, 2018 Share Posted June 22, 2018 On 20/05/2018 at 17:36, Shar2 said: although the 105mm was also fitted to late Tiran 4’s, the subject of this kit. Sorry if I misunderstood you, but I thought that's what you were saying. John. Link to comment Share on other sites More sharing options...
Shar2 Posted June 22, 2018 Author Share Posted June 22, 2018 I can see how it can be misread. But I meant the subject of this kid of a late model. I'll edit it so It's not so easily confused. Link to comment Share on other sites More sharing options...
Bullbasket Posted June 23, 2018 Share Posted June 23, 2018 No problem Dave. It's a good review by the way. I would have bought the kit, but I already had the Takom version. I picked up the 4SH which also has a full interior. It's a helluva lot of kit. John. Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted June 23, 2018 Share Posted June 23, 2018 To be fair it's something I'm still trying to get my head around.....The issue came up in a thread about the T-54/55 and I'm still not 100% sure of the designations.....However I may know someone who is. Link to comment Share on other sites More sharing options...
Shar2 Posted July 15, 2018 Author Share Posted July 15, 2018 If you fancied the kit above, but were afraid of all the interior parts, you can now get most of the lovely plastic shown above, with the interior parts removed. Review sample courtesy of Link to comment Share on other sites More sharing options...
Shar2 Posted January 1, 2019 Author Share Posted January 1, 2019 MiniArt have now released the second version of the Tiran 4, the Sharir. It is this version that has the M68 105mm gun fitted. Apart from the new gun sprue, which also includes a some APDS rounds, and a new set of decals,, the kit is essentially the same. and the as is the build above. Review sample courtesy of 1 1 Link to comment Share on other sites More sharing options...
