Paul A H Posted May 19, 2018 Share Posted May 19, 2018 Russian MiG-31M Foxhound 1:72 Trumpeter The Mikoyan MiG-31, known by the NATO reporting name 'Foxhound' is an all-weather interceptor and replacement for the more famous but far less capable MiG-25 Foxbat. Although the MiG-31 bears a close resemblance to its predecessor, it is only the basic elements of the design that are shared. The MiG-31 is a much more modern aircraft and benefits from a very capable suite of avionics which provides full look down/shoot down capability against targets are small as cruise missiles. One thing it does have in common with the venerable Foxbat is its speed. The Foxhound is one of the fastest combat aircraft around and can show a clean pair of heels to most comparable jets. The weapon of choice for the Foxbat is the long-range R-33 missile, but it is also capable of using the now obsolete R-40, as well as the short-range R-73. Some variants can deploy the KH-31 and KH-58 anti-radiation missiles in the SEAD role. The MiG-31M was an intended upgrade featuring a one piece rounded windscreen, enlarged dorsal spine, digital flight controls and multi-mode phased array radar. It was also fitted with upgraded engines. The type was prevented from entering full production by the dissolution of the Soviet Union. Trumpeter have pleased a lot of modellers with a penchant for Russian hardware of late. This kit follows their MiG-29, Su-24 and Su-27/33/34 families, as well as their MiG-31 and MiG-31B/BM kits. In classic Trumpeter style, the kit arrives in a large sturdy box with the parts packed so well that it is almost impossible to get them back in the box once unpacked. The box contains an over 330 parts, although this is relatively modest compared to their Su-34. The parts are well protected and the quality of moulding is up to the usual Trumpeter standard, with fine, consistent panel lines and plenty of detail. The overall breakdown of parts is virtually identical to previous iterations of this kit, but with revised parts to ring the changes between the original MiG-31 and the M. The cockpit is nicely replicated, with detailed instrument panels and sidewalls, as well as neat two-part K36 seats. The nose gear bay has to be built around the landing gear leg, which means painting the whole thing before it goes into the kit, but does at least replicate the detail of this part accurately. The nose and forward fuselage is a seperate part to the rest of the airframe, so I guess it could be assembled and put to one side while the rest of the beast is gradually assembled from its component parts. Construction moves on to a number of major sub-assemblies, most of which have to be completed at this stage in order to progress the build. The massive engine air intakes are full length, and contain eight parts each, not including the engine compressor blades. The main landing gear legs and bays also have to be assembled at this stage, although they look both well detailed and reasonably sturdy. Once complete, the nose gear bay, main gear bays and engine intakes can all be cemented into the large, slide moulded lower-rear fuselage, while the nose section can also be slotted into place. In order the bring the whole thing together, the single span upper wing can have the lower wing surfaces added and be joined to the rest of the airframe. With the collosal fuselage complete, most of the rest of the build is spent adding a few more large parts and a whole host of finishing details. Unlike the Hobbyboss kit, the vertical tails are moulded as solid parts and have plenty of rivet detail moulded in place. This is so fine, however, that I am reasonably confident that it will disappear completely under a coat of primer, particularly given that the whole kit has quite a rough, textured finish. The jet exhausts are each made up from three parts and are suitably imposing, although not quite the dustbin-like cans of the MiG-25. The canopy is moulded so it can be finished in the open position, and of course the one-piece windscreen is present and correct. The air brakes are also molded separately and are designed to be finished in the extended position. Trumpeter aren't usually shy when it comes to ordnance, so you get fair deal with this kit. Included in the asking price are: 6 x R-37 air-to-air missiles; 2 x R-40T infrared homing air-to-air missiles; 2 x R-40R radar homing air-to-air missiles; 2 x R-73E air-to-air missiles; 2 x R-77 air-to-air missiles; and 2 x drop tanks. The painting and marking guide shows the prototype, 037 Blue, but sufficient bort numbers are included to allow other aircraft to be built, if you fancy a very mild 'what if'. Stencils are included for the airframe and ordnance, which is also nice to see. The decals themselves look nicely printed and should perform well. Conclusion This is very nice kit which comfortably moves straight to the top of the tree when it comes to MiG-31s available in this scale. It's big but not too complex, well detailed and includes a fair selection of ordnance. On the other hand, it's far from cheap, especially when compared to the main competition. My main criticism of the kit is that the panel lines and rivit detail are incredibly fine and will surely disappear under a layer of primer. Not good for an aicraft that really needs a panel line wash to match the grubby appearance of the real thing. Nevertheless, if you do choose to build one, you will be rewarded with an impressive kit. Review sample courtesy of UK Distributors for 6 Link to comment Share on other sites More sharing options...
mdauben Posted July 12, 2019 Share Posted July 12, 2019 Over 330 parts for a 1/72 scale airplane! Things sure have changed since the kits I put together as a teen. Great review. Link to comment Share on other sites More sharing options...
Timbo88 Posted July 13, 2019 Share Posted July 13, 2019 Agree with you there, that's an awful lot of parts. Things certainly have moved on in recent years regards kit content. Link to comment Share on other sites More sharing options...
