Aircraft Build Jigs
Uncle Pete
I've had a look on the internet for jigs that hold planes steady during building and painting.  Do any of you experienced guys use them?  Are they worth getting or do they "catch more fishermen than fish"?  So far I've been muddling through with blu-tak, knees, teeth and bits of bent wire.
I recently built one and have been semi-using it. I think it's not totally devoid of value, and I'm grimly determined to get my money's worth from it, but it's kind of a hassle and in retrospect I would not have purchased a wooden one.
Hmmm, interesting experience PC - is that the bi-plane jig I've seen in recent photos? Like this one:
I was thinking of getting one of those but maybe not :(
I have two types of stand that I find really useful (for my 1/72 builds). The first is from Sphere Products and I've just ordered the bigger one for a 1/48 build (or two 1/72!)
You do need to drill out the prop mount so you won't get spinning props (you have to glue it on afterwards) but once the widget is in the front it grips really well on the back of the hole so it doesn't split the seams like pointy sticks do. You can either use the supplied stand or, as seen above, any other thing with a hole.
The other stand I have is from JH Models (I got mine from Modelling Tools) and I use it all the time when applying decals. You can adjust the supports so that the model is stable, or just use it to prop things at an angle:
HTH :)
I'd rather build than buy, so I made my own from bits of scrap and four pencils (with rubbers). To my surprise it works quite well. The cylindrical side bits swivel.
I have thought that an improvement would be to add small but strong magnets to the end of the pencils (with a bit of padding glued at the end so as not to damage paintwork) and then glue washers into the wings, but I haven't got around to doing it yet.
  • Like 13
When I’ve needed to jig something in the past, as bentwaters suggested, good old Lego did the trick.
Couple of quid for a bucket of it at a car boot sale plus cardboard shims stuck on for adjustments.
The pound shops probably have some of that knock off Lego if needed.
Mart
I bought some Wilko ersatz Lego recently to help align the wings on things like (old) Ju-88s which are difficult with the gondola underneath I find. Works quite well for lining things up, quite cheap and you'll probably find other uses too. I'll post some pictures when I get home
Yep, another vote for Lego too for those 'bespoke' stands. I find the 'roof tiles' particularly useful when trying to level things out:
36852222382_2147f71030_z.jpg&key=4aa1b5d
... and I also put some BluTak on the ends to allow precise adjustment and secure attachment of tailplanes.
My new Sphere Products Medium stand arrived this morning too. Post over here but here are the small and medium together:
  • 1 year later...
Genius.
