Julien Posted May 11, 2018 Share Posted May 11, 2018 Finnish Army K9FIN "Moukari" 1:35 Academy via Pocketbond The K9 Thunder is a modern 155mm artillery system developed by Samsung for the Republic Of Korea (South Korea) Armed Forces. The need to a new system was recognised in the late 1980's and the new gun system was produced and put into service 10 years later. This self propelled gun features steel armour capable of withstanding 14.mm Armour piercing rounds, and 152mm shell fragments. The 155mm 52 calibre gun has a range of 40km. The gun also features a hydro-pneumatic suspension system and a 1000hp engine. The Finnish Army realised their current Artillery systems would be outdated fairly soon and have struck a deal to buy 48 used K9's from the South Koreans. Now their neighbours Norway and Estonia are looking to procure the gun as well. The Kit This is a reboxing of Academy's 2009 boxing of the ROK 2009., with only new decals to differentiate it. You can always rely on Academy to give us kits of ROK equipment. The kit arrives as the main upper & lower hulls, five sprues of plastic and a set of runner tracks. Construction starts by adding the suspension components to the lower hull. The track return rollers are added along with the mounts for the lower suspension, once these are on the suspension arms are added. At the front the drive gear boxes are added. The two part road wheels (6 per side are added along with the drive sprockets. An idler wheel is added at the back. The rear bulkhead for the gun is made up and added to the lower hull. Construction then shifts to the upper hull. The drivers hatch, engine access hatches and grills are added along with a spare pair of track links. The drivers vision blocks are added along with headlights, and their protective covers. We now shift to the gun turret. The back is added to the turret and then it can be added to the base plate. Hatches are added along with external tools, and jerrycan stowage. A tow cable is added to the roof along with lifting eyes. A roof mounted sight is made up and added along with the commanders hatch and its heavy machine gun. Stowage baskets are then added to the rear of the turret. Next up the gun is put together. The front and rear parts of the barrel are in two halves and these are joined by a centre section, muzzle brake is then fitted to the end. The gun mount is then made up and the gun added, this sub assembly can then be added to the turret. The upper and lower hulls can then be assembled and the turret added. The flexible track is also added. A gun travelling mount is also then made up for the front hull. Markings From the box you can build one vehicle which was seen at the National Flag Day Parade in June 2017. Conclusion It is good to see models of these gun systems used by the less mainstream countires. Recommended. Review sample courtesy ofUK Distributors for 2 1 Link to comment Share on other sites More sharing options...
