fatalbert Posted May 9, 2018 Share Posted May 9, 2018 Hi guys,does anyone know if any of the available 1/72 corsair kits has a deployed flap option,or is it an aftermarket only option.Cheers........Neil 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted May 9, 2018 Share Posted May 9, 2018 I checked out all 3 Tamiya versions only the newer release has anything close to it. The have the starboard inboard flap as seperate but nothing else. The Hobyboss & Academy seem to be complete solid wing. My guess is A/M is your best bet ? Id recommend the Aires set unless you have something else in mind. Dennis Link to comment Share on other sites More sharing options...
fatalbert Posted May 9, 2018 Author Share Posted May 9, 2018 7 minutes ago, Corsairfoxfouruncle said: I checked out all 3 Tamiya versions only the newer release has anything close to it. The have the starboard inboard flap as seperate but nothing else. The Hobyboss & Academy seem to be complete solid wing. My guess is A/M is your best bet ? Id recommend the Aires set unless you have something else in mind. Dennis Thanks Dennis,have ordered an aires set,cheap as chips off a well known auction site. Neil 1 Link to comment Share on other sites More sharing options...
Seawinder Posted May 9, 2018 Share Posted May 9, 2018 You probably already know this, but F4U-1 flaps were generally up when the plane was parked. Link to comment Share on other sites More sharing options...
fatalbert Posted May 9, 2018 Author Share Posted May 9, 2018 28 minutes ago, Seawinder said: You probably already know this, but F4U-1 flaps were generally up when the plane was parked. Yeah ,I know,but I just like the look of the corsair with everything hanging out,thanks for the heads up though ☺ Link to comment Share on other sites More sharing options...
