Ham Hands Posted May 9, 2018 Share Posted May 9, 2018 (edited) Hello and thank you for clicking. I am building in 1/48 scale for the first time in 20 years (6 builds at once). I want my bombs to resemble this: Mine currently look like this: I am unsure what to do. Any help appreciated. I will be away from my pc for several hours. I will check in later. Thank you. Edited May 10, 2018 by Ham Hands 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted May 9, 2018 Share Posted May 9, 2018 (edited) Hmmm possibly a wash with grey or white as the base to fade the colors out like the photo ? Edited May 9, 2018 by Corsairfoxfouruncle 2 Link to comment Share on other sites More sharing options...
Ham Hands Posted May 9, 2018 Author Share Posted May 9, 2018 5 minutes ago, Corsairfoxfouruncle said: Hmmm possibly a wash with grey or white as the base to fade yhe colors out like the photo ? Thank you very much. I will leave a quick wash on them now before I leave home. I will use Flory models 'Light". Many thanks. 1 Link to comment Share on other sites More sharing options...
Ham Hands Posted May 9, 2018 Author Share Posted May 9, 2018 (edited) Hello again. I have done a little on my bombs. It is dark here so this is a lit shot. (Lit poorly) There is a bit of lint on the prop, since removed. See what you think and feel free to offer suggestions. Here is a 500 pounder. Thanks for looking. Edited May 9, 2018 by Ham Hands Link to comment Share on other sites More sharing options...
thorfinn Posted May 9, 2018 Share Posted May 9, 2018 (edited) My suggestion would be an overall light dry-brushing of one or two shades of the lightened base-color. It's what I do to most surfaces anyway, as a matter-of-course, for what I call 'toning'---breaking up the monochrome paint color, to resemble the subtle variances that the eye sees through ordinary light and atmospheric effects in 'real scale'---but can be effectively 'ramped-up' (with a more determined application, and the use of slightly-differing color-tones) to simulate wear, chipping, and so on. The dry-brushing highlights the almost invisible differences in surface texture on the model part, and can convey a surprisingly realistic effect...even when the color variation is so subtle a viewer might not realize anything has been 'added.' Plus...it's dead-easy! Oils or enamels tend to be easier to control than acrylics...because of the extended drying time...and a stiff-bristled brush (of whatever size) tends to offer more subtle control, thanks to the 'spring' in the bristles. Practice it on a spare part if you've never tried it before. You'll likely be amazed. Used in concert with washes---and the above shot looks really good, after Dennis's advice---you can produce some really eye-catching effects. Cheers Edited May 9, 2018 by thorfinn 3 Link to comment Share on other sites More sharing options...
huvut76g7gbbui7 Posted May 9, 2018 Share Posted May 9, 2018 Only thing I can add to above is perhaps matt down a bit.There's no shine on the original photo. Otherwise looking good. 1 Link to comment Share on other sites More sharing options...
Ham Hands Posted May 9, 2018 Author Share Posted May 9, 2018 Thank you guys. Indeed I will do as advised in the daylight. I plan to rub the paint down a bit and will be sure to have all bombs fully matt when complete. Thanks very much. 1 Link to comment Share on other sites More sharing options...
Ham Hands Posted May 10, 2018 Author Share Posted May 10, 2018 I am getting close. I must remember these will be slung under an F9F panther wing and won't be obvious. I have dry brushed using a mix of silver, white, olive green, yellow ochre and raw umber. I will just show one. They all look similar. Any thoughts, criticism, advice will be appreciated. Many thanks. 5 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted May 10, 2018 Share Posted May 10, 2018 Well it looks pretty good to my old Mark 1 👀 1 Link to comment Share on other sites More sharing options...
thorfinn Posted May 10, 2018 Share Posted May 10, 2018 Think you've matched your top (reference) photo pretty well. Nice work! 1 Link to comment Share on other sites More sharing options...
Ham Hands Posted May 10, 2018 Author Share Posted May 10, 2018 Thank you very much. Special thanks for the advice given above. It inspired me further and is much appreciated. Link to comment Share on other sites More sharing options...
Finn Posted May 11, 2018 Share Posted May 11, 2018 Looking good, one thing to note, the bomb bodies were normally stored outdoors so were subject to weathering, even Navy bombs were stored at a depot outside before being sent to a ship. Tail sections were for the most part were better protected from the elements by being kept indoors or n containers so the paint on them looked more fresh. Jari 2 Link to comment Share on other sites More sharing options...
Ham Hands Posted May 11, 2018 Author Share Posted May 11, 2018 5 hours ago, Finn said: Looking good, one thing to note, the bomb bodies were normally stored outdoors so were subject to weathering, even Navy bombs were stored at a depot outside before being sent to a ship. Tail sections were for the most part were better protected from the elements by being kept indoors or n containers so the paint on them looked more fresh. Jari Hello Jari. Thank you for this information. I was actually wondering how I would be able to match the small section that is secured via blutac. This information removes that task. Far easier to paint the fins. I am glad I signed in to ask my 1st question. Thanks again. Link to comment Share on other sites More sharing options...
Selwyn Posted May 11, 2018 Share Posted May 11, 2018 One Quick question are the bombs to be fitted to the aircraft, or sat around the aircraft in a diorama? Its just if they are to be not fitted and sat on the ground the nose fuzes should be removed, as fuzes were normally fitted after the bomb was loaded. Selwyn 1 Link to comment Share on other sites More sharing options...
junglierating Posted May 11, 2018 Share Posted May 11, 2018 13 minutes ago, Selwyn said: One Quick question are the bombs to be fitted to the aircraft, or sat around the aircraft in a diorama? Its just if they are to be not fitted and sat on the ground the nose fuzes should be removed, as fuzes were normally fitted after the bomb was loaded. Selwyn Nicely put....its a cool pic cant help but think of the faff if he dropped it.....pick it up and throw it over the side I suppose 1 Link to comment Share on other sites More sharing options...
Selwyn Posted May 11, 2018 Share Posted May 11, 2018 5 hours ago, junglierating said: If he dropped it to the deck he would probably just pick it up and fit it. These things were designed so if you jettisoned one in an in flight emergency they would not go off if they hit the ground, so a few feet down would just scratch the paintwork. Lets face it, if the bomb was that sensitive to handling you would certainly not be fitting it to my aeroplane, or carrying it around on a flight deck! The only issue would be if it landed on the fins and bent them. then it would be a new tail to fit, and no doubt giving the Chief a good listening to! Selwyn 1 1 Link to comment Share on other sites More sharing options...
Finn Posted May 12, 2018 Share Posted May 12, 2018 Here is an example of how reasonably "clean" the tail section of a bomb looks compared to the bomb body: Jari 1 Link to comment Share on other sites More sharing options...
Julien Posted May 12, 2018 Share Posted May 12, 2018 15 hours ago, Selwyn said: One Quick question are the bombs to be fitted to the aircraft, or sat around the aircraft in a diorama? Its just if they are to be not fitted and sat on the ground the nose fuzes should be removed, as fuzes were normally fitted after the bomb was loaded. Selwyn He did say they would be under the wings of a panther, so fuses would be OK 1 Link to comment Share on other sites More sharing options...
Ham Hands Posted May 12, 2018 Author Share Posted May 12, 2018 (edited) Hello. Thanks for looking in. Yes, these will be underwing. I realized later the red mark is for lining up arming points, front and rear. (visible behind the man's head.) I could strip them and start again, but as they will be hard to see I may just leave them be. I will sit with it for a few days. Thanks again. Edited May 12, 2018 by Ham Hands Link to comment Share on other sites More sharing options...
Selwyn Posted May 12, 2018 Share Posted May 12, 2018 41 minutes ago, Ham Hands said: Hello. Thanks for looking in. Yes, these will be underwing. I realized later the red mark is for lining up arming points, front and rear. (visible behind the man's head.) I could strip them and start again, but as they will be hard to see I may just leave them be. I will sit with it for a few days. Thanks again. The red mark is not a red marking, its a purple marking and its not for aligning arming points! The bomb is a HE bomb with an incendiary component. yellow band =HE Purple band = Incendiary . Selwyn 1 Link to comment Share on other sites More sharing options...
Ham Hands Posted May 12, 2018 Author Share Posted May 12, 2018 1 hour ago, Selwyn said: The red mark is not a red marking, its a purple marking and its not for aligning arming points! The bomb is a HE bomb with an incendiary component. yellow band =HE Purple band = Incendiary . Selwyn Oh thank you very much! Link to comment Share on other sites More sharing options...
Ham Hands Posted May 14, 2018 Author Share Posted May 14, 2018 Now having sprayed the tail fin area. 1 Link to comment Share on other sites More sharing options...
