Gimme Shelter Posted May 8, 2018 Share Posted May 8, 2018 Just for fun, the Pegasus Hobbies 1/18 Great White Shark & Diver/dive cage diorama set built up a completed 6 Link to comment Share on other sites More sharing options...
whitestar12chris Posted May 8, 2018 Share Posted May 8, 2018 Cracking job, very nicely executed. All the best Chris Link to comment Share on other sites More sharing options...
Jim Wasley Posted May 8, 2018 Share Posted May 8, 2018 (edited) Scary stuff,great bit of model building,cheers. Edited May 8, 2018 by Jim Wasley Link to comment Share on other sites More sharing options...
Will Vale Posted May 14, 2018 Share Posted May 14, 2018 That's cool! Did you use silicone mastic for the water? I really like the slight opacity to the foam and splashes. Cheers, Will Link to comment Share on other sites More sharing options...
Gimme Shelter Posted May 15, 2018 Author Share Posted May 15, 2018 10 hours ago, Will Vale said: That's cool! Did you use silicone mastic for the water? I really like the slight opacity to the foam and splashes. Cheers, Will all clear bathroom mastic - nasty sticky smelly stuff but ideal for what was intended - plus a dusting of white for the spray using an airbrush Link to comment Share on other sites More sharing options...
rockpopandchips Posted May 15, 2018 Share Posted May 15, 2018 Gruesome! I like it, great work on the water as well. Link to comment Share on other sites More sharing options...
Gimme Shelter Posted May 18, 2018 Author Share Posted May 18, 2018 On 5/15/2018 at 10:52 AM, Gimme Shelter said: all clear bathroom mastic - nasty sticky smelly stuff but ideal for what was intended - plus a dusting of white for the spray using an airbrush Hi - yep a whole tube of Wickes clear bathroom sealant - nasty sticky smelly stuff but very workable after being left for 10 mins or so to dry - added a dusting of white using an airbrush later on for the foam and spray effects Link to comment Share on other sites More sharing options...
HansReggelsen Posted June 1, 2018 Share Posted June 1, 2018 Well, I haven't had a swim in the ocean since first I saw 'Jaws' in the cinema when I was a kid in the '70'es. Your diorama has reaffirmed me in the wisdom of that decision! Well done diorama! Cheers Hans J Link to comment Share on other sites More sharing options...
