fjaweijfopi4j48 Posted May 4, 2018 Share Posted May 4, 2018 Yes, that's right, besides the ongoing Argentinian DH89a based on a modified Heller kit, I just had to start this one too, whilst all the tricks remain fresh on my mind. The modifications for this MacRobertson entry can be considered minimal, compared to the extensive ones on the other build. They comprise: on the interior a long range-configured cabin with special fuel tanks and radio and navigation stations. On the exterior some blanked windows, an emergency exit on the fuselage top, and a few gizmos here and there. I will cut the door open here too, to allow a glimpse of the interior. There is a wealth of images on this plane on the Net, accessible just by using a search engine with the proper terms. Flight magazine has a rather basic sketch of the cabin that only shows the tanks, so I am appealing here to this esteemed membership for any photos or sketches of the cabin interior, stressing that I do not need any photos of the exterior or cockpit, contemporary to the race or modern, or walk-arounds, or anything else OTHER than photos or drawings of Tainui's cabin. Work begins by raiding the spares bin and getting potential seats and equipment, plus making the basic structure of the fuel tanks, that hung from the upper wing spars: The cabin floor is covered with a thin veneer, the tank structure is wrapped: Main parts are glued (nacelles, upper wing three components, some of the cockpit parts, made-up cylinders behind the engine front, etc.). All other parts are separated from the sprues and cleaned-up: The fuel tank is given some braces: 13 Link to comment Share on other sites More sharing options...
StephenCJ Posted May 4, 2018 Share Posted May 4, 2018 I will follow along with this build as I do with all your builds. I now have an interest in civilian aircraft especially the pioneers and their rickety machines that they flew over great expanses of ocean. Very brave people. I am doing the bum at the computer as you suggested doing some research into Smithy's 'Southern Cross' very interesting and confusing. I am going to do NC 1985. Stephen 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 4, 2018 Author Share Posted May 4, 2018 43 minutes ago, StephenCJ said: as you suggested doing some research into Smithy's 'Southern Cross' very interesting and confusing. I am going to do NC 1985. Stephen Hi Stephen Nice choice for the F.VII. When I did the research form my model I had to wade through a lot of confusion, miss-captioning and mislabelling regarding the versions. I may have some info for you -that I will have to retrieve. Could you please drop a line to me using the forum mechanism so we are in touch directly? Cheers Link to comment Share on other sites More sharing options...
corsaircorp Posted May 4, 2018 Share Posted May 4, 2018 Hello Moa, I'll tag along, another great kit in the making ! Sincerely. CC 1 Link to comment Share on other sites More sharing options...
Courageous Posted May 4, 2018 Share Posted May 4, 2018 And away we go again. Love your work. Stuart 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 4, 2018 Author Share Posted May 4, 2018 15 hours ago, StephenCJ said: I am doing the bum at the computer as you suggested doing some research into Smithy's 'Southern Cross' very interesting and confusing. I am going to do NC 1985. Stephen Hi again Stephen Not sure how are you tackling the Valom kit, but perhaps the following will be useful, a quote from my own build (I did a somewhat arcane incarnation of the Southern Cross). Here some notes about the kit and the versions (summarizing that whatever version of Southern Cross you chose, you MUST modify the kit to match it, since the Valom SC is just the airliner version with other decals, which is not accurate. And to avoid more digressions of the thread, we shall contact off-forum to continue this chat if you wish. Hope this gives a general sense: This "Southern Cross" version VALOM released is supposed to cater for the US registration 1985 (the plane for the well-known flight) and the plane re-registered in Australia as VH-USU. Thing is, as the fuselage is presented, it needs adjustments to represent them (because mainly of the doors). Besides, VH-USU had a number or incarnations that involved very visible changes. Strangely enough, you could build an authentic VH-USU plane, as it was in 1933 (or 1935 according to Getty Images) (The memorable ocean-crossing flight was in 1928) in the Australia to New Zealand flight, with both doors as the kit is, but using the three-blade propeller on the center engine, and different exhausts than the ones depicted in the instructions (the ones that go over the wing for the external engines and two long ones for the center one), plus shields on the engine fronts; all these details visible in period photos. Not sure the decals will perfectly fit, since the lettering suffered modifications during the plane's life, but you can potentially build a Southern Cross WITHOUT MODIFYING ANYTHING, BY JUGGLING THE EXTRA PARTS OF THE KIT AROUND, just not the plane depicted on the box. For that you need some work. Once again, if you want an accurate model that faithfully represents the plane intended, you will have to gather references and check the kit against them. In this case, I recommend it. VALOM as you will see provides a number of alternate parts to cover many versions, therefore you get some spares bin fodder. This concept of a flexible building with alternate parts also helps modelers that want to build other versions not in the market, or planes that were modified during their lives. On the other hand, to make several versions from one mold and added parts, they have made some compromises. The instructions are in general reasonable, better than many, but still in parts confusing; to quote just two: the way the rudder bar and pedals attach to the console is unclear, and US-registered 1985 had no passenger interior but a huge long-distance fuel tank and some custom interior arrangement with radio and navigator station, a very obvious and known fact. VH-USU had seats only in one of its incarnation (the version highlighted above). Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 4, 2018 Author Share Posted May 4, 2018 On the other model I am "deploying" the flaps, but Tainui was a DH89 (not a DH89a) and had no flaps, so they have to be deleted: The door here is also coming out, very sharp new blade, very careful, restrained, controlled, easy-peasy passes: Door is out, cleanly: Take note that many of those windows will have to be blanked-off, and a drift sight created immediately after the door, as per photos of the original plane. 6 Link to comment Share on other sites More sharing options...
StephenCJ Posted May 4, 2018 Share Posted May 4, 2018 Thanks Moa for your interest in my build. I will start a WIP sometime today. Link to comment Share on other sites More sharing options...
Azgaron Posted May 5, 2018 Share Posted May 5, 2018 Nice start! Looking good! Håkan 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 5, 2018 Author Share Posted May 5, 2018 21 hours ago, StephenCJ said: Thanks Moa for your interest in my build. I will start a WIP sometime today. 😉 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 6, 2018 Author Share Posted May 6, 2018 (edited) Flaps deleted, rib tape re-traced lightly, nacelles glued on: Drift sight cutout: Wind-driven generators for both DH89 models: Edited May 12, 2018 by Moa to correct typo 9 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 7, 2018 Author Share Posted May 7, 2018 I made new radio and nav. station seats, more accordingly to what can barely be guessed in the Flight mag. skecth. I also rescued from the spares bin and tidied-up a bit a generator that goes on the belly of the fuselage, in the center of a white circle that surrounds the race number 60. Details, details, details: 7 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 7, 2018 Author Share Posted May 7, 2018 Oh! I just noticed that my profile now says "obsessed member". Should I be worried? Should I see a doctor? Is there a cure? I see around many on the same condition...or even worse! Are we going to be sent to some kind of asylum? can you build models there? 2 Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted May 7, 2018 Share Posted May 7, 2018 You can change it in your profile settings.....I've been killing time for a while. 1 Link to comment Share on other sites More sharing options...
StephenCJ Posted May 7, 2018 Share Posted May 7, 2018 Very nice chairs Moa. Very nice everything. Stephen 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted May 7, 2018 Share Posted May 7, 2018 Blimey anther one on the go. This is great stuff. Lovely kit. Great work and an interesting subject. All the best Chris 1 Link to comment Share on other sites More sharing options...
stevehnz Posted May 7, 2018 Share Posted May 7, 2018 (edited) 6 hours ago, Moa said: Oh! I just noticed that my profile now says "obsessed member". Should I be worried? Should I see a doctor? Is there a cure? I see around many on the same condition...or even worse! Are we going to be sent to some kind of asylum? can you build models there? No No No Maybe & hopefully. Steve. Edited May 7, 2018 by stevehnz 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 7, 2018 Author Share Posted May 7, 2018 8 hours ago, stevehnz said: No No No Maybe & hopefully. Steve. Dear Steve I see that your condition is much worse than mine, by far (Completely Obsessed Member? wow!) Anyways, I feel now that I should honor the characterization bestowed upon me. The clear parts are glued, same as in the other Rapide, but here the masks are applied on the inside only on the panes that will remain clear, so the paint will go over the ones that are blanked on the original: Thinking about these, but my suspicion is that this issue was taken care of in a much more, how should I put it, prosaic and practical way, may be with a bucket: Still no diagram or photo of the compete cabin interior. I saw online that this book may contain such information. It's out of print and extremely expensive, even used, so if one of you has it and could have a look at that piece of the puzzle, I'd be very grateful: 5 Link to comment Share on other sites More sharing options...
Roger Holden Posted May 7, 2018 Share Posted May 7, 2018 3 hours ago, Moa said: Still no diagram or photo of the compete cabin interior. I saw online that this book may contain such information. It's out of print and extremely expensive, even used, so if one of you has it and could have a look at that piece of the puzzle, I'd be very grateful: I have the book and all it shows is a Flight sketch of the cabin fuel tank (in the DH 88/MacRobertson section) which you have seen already. (The book is a much better ref on the Moth types than the Rapide.) Best Rapide books are the 2 Air-Britain volumes, which likewise have little on that particular aircraft, apart from a couple of photos. Best MacRobertson ref is an Australian Historical Society booklet which details all the participants, but I can't put my hands on it quickly. I think there was a Tasman NZ release of the Heller kit containing those decals and there has been at least one aftermarket decal set also. 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 7, 2018 Author Share Posted May 7, 2018 1 hour ago, Roger Holden said: I have the book and all it shows is a Flight sketch of the cabin fuel tank (in the DH 88/MacRobertson section) which you have seen already. (The book is a much better ref on the Moth types than the Rapide.) Best Rapide books are the 2 Air-Britain volumes, which likewise have little on that particular aircraft, apart from a couple of photos. Best MacRobertson ref is an Australian Historical Society booklet which details all the participants, but I can't put my hands on it quickly. I think there was a Tasman NZ release of the Heller kit containing those decals and there has been at least one aftermarket decal set also. Hi Roger Thanks very much for that information! And will have a look at those decals. Cheers Interior base coat in a neutral grey, and fuel tank in a metal tone: 6 Link to comment Share on other sites More sharing options...
stevehnz Posted May 8, 2018 Share Posted May 8, 2018 10 hours ago, Roger Holden said: I have the book and all it shows is a Flight sketch of the cabin fuel tank (in the DH 88/MacRobertson section) which you have seen already. (The book is a much better ref on the Moth types than the Rapide.) Best Rapide books are the 2 Air-Britain volumes, which likewise have little on that particular aircraft, apart from a couple of photos. Best MacRobertson ref is an Australian Historical Society booklet which details all the participants, but I can't put my hands on it quickly. I think there was a Tasman NZ release of the Heller kit containing those decals and there has been at least one aftermarket decal set also. I'm wondering if the Tasman kit has any info on the tanks in Tainui, either way, there's a couple of them coming my way before long, one for Tainui of course & one for a RN one, I already have one for an RNZAF version. Steve. Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 8, 2018 Author Share Posted May 8, 2018 I realized that the chairs were of "comfortable airliner seat"* size, so I made a few more at a smaller size: (*For you, fledgling, a "comfortable airliner seat" is a thing that used to exist, even when you flew main cabin. Not anymore) Just for heck of it I prepared the kit's inst. panel, which looks decent enough if you don't want to use the P.E. one (I will), given its scarcely visible position. Also seen are very respectable radio and navigation consoles found in the spares bin. On British planes the complex radio instrumentation was used exclusively to listen to the BBC. The "navigation" console was actually a disguised cuppa brewing machine: 7 Link to comment Share on other sites More sharing options...
VH-USB Posted May 9, 2018 Share Posted May 9, 2018 On 5/7/2018 at 4:15 PM, Roger Holden said: I have the book and all it shows is a Flight sketch of the cabin fuel tank (in the DH 88/MacRobertson section) which you have seen already. (The book is a much better ref on the Moth types than the Rapide.) Best Rapide books are the 2 Air-Britain volumes, which likewise have little on that particular aircraft, apart from a couple of photos. Best MacRobertson ref is an Australian Historical Society booklet which details all the participants, but I can't put my hands on it quickly. I think there was a Tasman NZ release of the Heller kit containing those decals and there has been at least one aftermarket decal set also. As Roger mentions, the Aviation Historical Society of Australia published an expanded issue of their journal which was devoted to the MacRobertson Race. It's long OOP but copies do turn up very rarely on www.bookfinder.com. But for the purpose of modeling the DH89 *Tainui* it won't be of much use as the issue contains little on this plane. The Tasman NZ release of the old Heller DH89 kit does contain decals for *Tainui* but there are some errors and omission on the decals. The co-pilot of *Tainui*, Cyril E. Kay, published his flying biography in 1964 entitled *The Restless Sky. The Autobiography Of An Airman*. This book is long OOP but copies are cheap and easy to find. One of the chapters in the book is devoted to the MacRobertson Race and Kay does describe the cabin fuel tanks. He says they were oval and hung from the plane's ceiling and in order to get to the cockpit from the cabin he had to crawl on his belly under the tanks in the very small space available. I recommend this book as it's a good read. The book *Magnificent Enterprise* does contain a period color photo of a DH90 Dragonfly with a tangerine color fuselage. This is most likely the shade used on the fuselage of *Tainui* and also most likely a Titanine paint color. Cheers, Tim 2 Link to comment Share on other sites More sharing options...
Azgaron Posted May 9, 2018 Share Posted May 9, 2018 Looking good! Håkan 1 Link to comment Share on other sites More sharing options...
Roger Holden Posted May 9, 2018 Share Posted May 9, 2018 1 hour ago, VH-USB said: As Roger mentions, the Aviation Historical Society of Australia published an expanded issue of their journal which was devoted to the MacRobertson Race. It's long OOP but copies do turn up very rarely on www.bookfinder.com. But for the purpose of modeling the DH89 *Tainui* it won't be of much use as the issue contains little on this plane. I dug my copy out and although it doesn't contain photos of use, it does contain some pertinent info. It says that although the third crew member has been described as a radio operator, according to Cyril Kay,he was actually a professional photographer taken along to film the race. It is not thought any radio was fitted. There were 3 fuel tanks suspended from the top of the fuselage. The article also refers to another one in Vol 18 no 2 of the same mag, specifically on the plane, which may contain more info. 1 1 Link to comment Share on other sites More sharing options...
