Tiger I “131” in Tunisia* - 1/35 Dragon - update 23/07/18 - ##FINISHED##
8 hours ago, NotDaMama said:
It's definitely an experience seeing 131 run, video doesn't do it justice! Seeing her disassembled you got a real feeling for just how solid a vehicle they created. Unfortunately it was before digital, so no photos :doh:
I had the chance to pick up this Dragon kit but funds led to me getting the Tamiya early instead, so I'm watching with interest how this goes together. I plan to build my Tiger for this GB only if I get the Panzer III H done first. Lovely Dragon kit, lots of detail, far fewer wheels!! I'll have the build thread up when my lad finally permits me to use my own PC...
Hi again NotDaMama. Yeah I definitely want to see 131 in action so I will need to watch out for the correct events when I decide to go to Bovington. You were lucky to see it when you did.
And I will definitely look out for both your builds - I like Panzer IIIs as much as Tigers!
Kind regards,
Stix
Ozzy and PlaStix thanks for the encouragement. Certainly needed to make people come out of their zone of comfort. That upcoming GB could be the place to have a bash with plenty of tips and help along the way. I can hear the tune again....
il see how Plastix goes here, master class in armour. A 1/48 Tiger would be quite a big model though?
Good man,
Not to hijack Stix's thread 1/48 is smaller than 1/35, 1/48 will fit on your hand comfortably and takes up less shelf space.
Hi Valkyrie. Thank you for your comments. A 1/48 Tiger 1 isn't too big - as Ozzy says above - it will sit comfortably on your hand. If you don't want a bigger model you could try one in 1/72. My first AFV builds were a 1/72 Panther and a Tiger 1 from Dragon. Be warned though, as I found out, tank building can be quite addictive!.
Kind regards,
Stix
Now that my Hurricane build is finished I can concentrate on this project.
Before I post what I have been up to over the weekend, on this Tiger, it did make me smile when I found some parts I needed to use for one of the early stages. I have often read that some AFV builders move up to 1/35 kits because they find the parts in 1/48 and 1/72 too small - well these were the parts I was looking for in 1/35!!:
And this is them in place:
I also came across these in the box as well - although I don't need them yet:
Anyway.........moving on....... I got my first bit of PE on:
...oh and yes it's quite small too!
The top bits for the exhausts are quite small too and quite fiddly to assemble:
The tops of the exausts are nicely detailed though:
Got some PE bent to shape:
The above fit over the fan units:
Most of my time, however, was taken with getting all the wheels ready for painting. It seemed to take forever removing the seam that ran around the centre of every tyre!:
I leave the bits of sprue on so I have something to hold the parts by when I brush paint them.
When 131 was captured it was found to have had the front two road wheels removed - so Dragon provide the caps to go on the wheels behind and there is a small PE part which fits on as well:
Then I got my first bit of paint on - thinned Revell's Anthracite acrylic - applied by flat brush. This is after a couple of coats:
More next weekend.
Kind regards,
Stix
Edited by PlaStix
  • Like 10
Nice start Stix, having built a few Dragon Tigers I feel your pain with the small parts. Have you got PE tool clamps to bend into position? As they do look nice but are a complete pain in the bum.
22 hours ago, Ted said:
You have a very organized build going on. Great detail on the kit too.
You are right - I do like to be organised when I'm building! :winkgrin: And yes it is a nicely detailed kit.
21 hours ago, Soeren said:
These tiny piesces 28 are for the starter plate?
Excellent knowledge of Tiger 1 equipment! 10/10!
Hi Ozzy and thank you. Yeah there does seem to be a lot of smaller parts for this one, but hopefully I won't lose any! No I do not have any PE clamps. For straight bends I tend to use a variety of different thickness metal rulers - for curves I find what ever seems to be a suitable object to bend them round! Yes it's all a bit makeshift in the PlaStix modelling area..........no airbrush, no PE bending tool.............oh well........
Kind regards,
Stix
I got one of those PE jigs, got it for a birthday present. I find it more of a faf than help, I end up using my fingers of steel ruler insted.
Yeah - sounds similar to me. So far I have been fortunate in that I have been able to fold and shape any PE how It needs to be without any specialist equipment.
Over the past couple of evenings I have been doing some painting/dry-brushing on the fans and exhausts.
Painting on the radiator/fan unit parts:
Mostly dry-brushed on.
Radiator/fan units assembled:
Exhausts dry-brushed with Humbrol Gunmetal:
Kind regards,
Stix
Edited by PlaStix
On 15/05/2018 at 23:38, delta7 said:
sneaks in the back door stealthily and has camera ready to steal all your secrets to use on my build 🕵️‍♂️
Looking really good so far !!!
Hi delta7. Thank you. Any progress with yours? I did a bit of weathering on the exhausts yesterday evening on mine.
Kind regards,
Stix
2 hours ago, delta7 said:
Endlessly brush painting the rubber surround on the wheels just now. Know how the guy who paints the forth rail bridge feels,
Good luck!! Yeah - I have still got that pleasurable experience ahead of me!!
Hope it's going well.
Kind regards,
Stix
On 18/05/2018 at 13:21, mick said:
great start
Cheers Mick. :thumbsup:
I have started painting the wheels but it was slow work - so, at times, while waiting for them to dry I started assembling some of the upper hull parts - I have only added the parts that I think will be easy to paint and do the initial weathering around.
The detail on these areas is really nice.
I also started adding some rusty weathering to the exhausts:
More wheel painting tomorrow!
Kind regards,
Stix
On 19/05/2018 at 19:56, Ozzy said:
Nice effect on the exhausts Stix, good luck with the road wheel painting.
Hi Ozzy. Road wheel painting is still ongoing - I must admit I allow myself to get distracted into doing other things on the kit - there are so many of the wheels on a Tiger 1 and I haven't even started painting the tyres yet!!
I have been doing some assembling of smaller bits and pieces - like the front machine gun - but I also took the plunge and decided to get the main lower hull painted plus started the weathering process. I tend to have a regular routine - 2 or 3 thinned layers of the base coat - in this case Humbrol 93 - Desert Yellow. Once dry I give everything a very, very watered down wash of Revell's Gunship Grey. Once this has thoroughly dried I use a very fine paint brush to apply very thinned Revell's Anthracite in and around any detail - a kind of targeted wash to create artificial shadow effects. Finally I dry-brushed all over with a lightened version of the Desert Yellow:
Not much of an update but it's getting there slowly.
Kind regards,
Stix
That is absolutely amazing! I had no idea effects like this could be achieved with just brush painting. I'm going to have to pinch that method for future use!
You should look up Stix’s youtube video. Its well worth the time to watch it.
  • Thanks 2
Excellent painting again Stix! I h8 painting the rubber rims of a German tank with an interleaved suspension - those German engineers didn´t think of us future modellers at all when designing them back then 😜. V-P
  • Haha 2
