Fouga CM.170 Magister "German, Finnish & Austrian" - 1:72 Special Hobby
Julien
Fouga CM.170 Magister "German, Finnish & Austrian" (72373)
1:72 Special Hobby
The Magister is probably Fouga's most well know design even though they had been producing aircraft since 1936. Post war the company was working on sailplanes and the heritage from this can be seen in the Magister design. In 1948 the French Air Force were looking for a jet powered aircraft to replace the then piston engine trainers. Fouga's original design the CM130 was under-powered with two Turbomeca Palas engines. Fouga then re-designed their aircraft to incorporate the more powerful Marbore engines, et voilà the CM170 Magister. The distinctive V tail, and slender wings bear testament to Fouga's sailplane designs. The prototype Magister flew in 1952 with an order for the first 10 being placed in 1953. The Magister was the worlds purpose designed/built jet powered trainer. It is also worthy to note the Magister made it into carrier aviation. With a few changes to the structure and undercarriage, the addition of an arrestor hook, and sliding canopies the CM175 Zephyr was born. Interestingly carrier trials took place on HMS Bulwark and HMS Eagle.
 The French aircraft industry in parallel with the UK went through many mergers with the aircraft being known as the Fouga Magister, Potez Magister, Sud Aviation Magister; and finally The Aerospatile Magister; though always actually being called The "Fouga" Magister. Development of the aircraft continued right up until the French selected its replacement, the Alpha Jet. Overseas sales proved popular were made to primarily to Germany, Belgium, Finland, and Israel; with Germany, Finland & Israel building them under licence. Of a total of 929 aircraft built, 286 were built under license.
 The basic jet was very affordable to operate for smaller Air Forces. Other users would include, Algeria, Austria, Bangladesh, Biafra, Brazil, Cambodia, Cameroon, El Salvador, Gabon, Katanga, Lebanon, Libya, Morocco, Nicaragua, Rwanda, Senegal, and Uganda. Many counties including Austria, Belgium, Brazil, France, Germany, Ireland, Finland; and Israel would use the aircraft for their National Aerobatic display teams. Even though primarily a trainer many of these smaller nations would use the aircraft for its light strike capacity as well. Israel would use them in combat during the 6 day war, El Salvador saw them used during its civil war, and aircraft used by The Katangese Air Force were used against the UN during the Congo crisis in 1961.
The Kit
The kit arrives on four sprues of grey plastic, and a clear sprue. The plastic parts are of excellent quality, the panel lines are engraved and deep enough to be seen after painting without being trenches. Care will be needed to take some of the smaller parts of the sprue, and it might have been the case that these would have been better in photo-etch? The clear parts are crisp, clear and thin.
Construction starts in the cockpit area. The front and rear instrument panels are fitted (instrument faces are provided as decals), along with the seat supports for the front cockpit. The seats are added along with the engine and flight controls. Once complete the cockpit can be set aside. Attention then moves to the engine pods on each side of the fuselage. Engine fan faces and exhaust need to be placed inside and then the inner side of the engine trunking can be added. At the rear of each side the final exhaust section is added. Once the engines are complete then cockpit can be placed inside the main fuselage, and this then closed up. The radio equipment area to the rear of the cockpit is also added at this time. Various antenna behind the cockpits then need to be added and/or removed depending upon the version being modelled.
Once the main fuselage is together work needs doing on both ends. At the rear the tail cone is added along with ventral strake. The 'V' tails are then added, care being taken with the small hinges for these. At the front the first part to me made up is the underside of the nose where the nose gear mounts. This attached inside the nose cone and the appropriate gun/no gun insert is attached to the top of the nose. The prominent nose mounted VOR antenna loops are added and the nose attached to the main fuselage.
Construction then moves to the wings. These are of conventional upper & lower construction. The wheel wells are mounted into the wings before they are closed up, along with the wing mounted air-brakes. These can be modelled in with the deployed or retracted positions. The wing end mounted fuel tanks are in two halves, with the bottom being moulded to the upper wing, and then a lower fuel tank part is added. The clear noses can then be added to the front of the fuel tanks.
The landing gear is then added to the model. The front single nose wheel is two parts and this is added to the main leg, this is then mounted to the nose of the aircraft. The single front gear door is added. The main wheels though larger than the nose wheel are single parts. These are fitted to the main legs, the legs along with their retraction struts are added into the main gear bays. The three part main gear doors are added. If needed armament can now be added to the model. Bombs and rocket pods are included to be used as wished by the modeller. To finish off the model the canopies can be added in the raised or lowered positions.
Markings
There are 3 marking options on a sheet printed by Cartograf which guarantees there will be no issues with it.
  • Finnish Air Force - Aircraft licence built in Finland 1968
  • German Navy 1968
  • Austrian Air Force Silver Birds Aerobatic Display Team 1966-1968
Conclusion
It is great to see more versions of this new tool from Special Hobby becoming available.
Highly recommended.
Review sample courtesy of
3 hours ago, Antoine said:
Thanks Julien.
I've just seen Zéphyr N°28 land at LFLO, but he didn't stay long enough for me to walkaround.
I'm sure I'll be able to at the airshow in september.
That would be great. I have a few of Special Hobby's Zephyrs and the new Model Decal sheet also.
Julen
